Electrical question - (Van alert - not bike)
binge
Emo Kiddy
PostPosted: 16:27 - 21 May 2014    Post subject: Electrical question - (Van alert - not bike) Reply with quote
After a simple way (if it's possible) to wire these lights in my van up:
https://scontent-b-lhr.xx.fbcdn.net/hphotos-frc1/t1.0-9/10336826_10152410980280606_1462391329830153781_n.jpg
So that they come on with the interior lights, as the doors are opened.
Go out again, with the interior lights (With the doors closed).
Which is what they are now - Directly wired into the interior lights (Transit had 3 in the back originally).
But I'd also like to be able to turn them on and off with an independant switch, without the two interior lights in the cab coming on.
They are constantly lived up, and are switched on / off at the moment, with the door switches earthing the circuit.
Any ideas.
Thanks.
Aff
PostPosted: 16:44 - 21 May 2014    Post subject: Reply with quote
Relay driven off the interior lights with a switch that bypasses it?
So a SPST with a switch that bypasses the pins or a SPDT with the unenergised position having a switch in it.
:edit: Bad paint diagram
so for the SPDT:
https://imgur.com/QN4rbge.png
And the SPST:
https://imgur.com/4umQX0V.png
Obviously with the battery in the "lights" part of the circuit.
Electric Bike Project
map
Mr Calendar
PostPosted: 16:55 - 21 May 2014    Post subject: Re: Electrical question - (Van alert - not bike) Reply with quote
binge wrote:
After a simple way (if it's possible) to wire these lights in my van up:...
You never heard of the A-Team having this sort of issue Wink
On topic, sort of, I'd think a 3 way switch just for those lights. Off, connect to cab light circuit and On. Or just a two way, missing out off. The On connected direct to a live.
stevo as b4
PostPosted: 19:19 - 21 May 2014    Post subject: Reply with quote
I'm loving the swanky leather clad Van dude, with downlighter's, proper nice for a Transit van, and rather posh but cool! Laughing
binge
Emo Kiddy
PostPosted: 23:37 - 21 May 2014    Post subject: Reply with quote
Getting there :p
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/t1.0-9/10173522_10152411707760606_9078929416303594897_n.jpg
PostPosted: 00:01 - 22 May 2014    Post subject: Reply with quote
That van is fucking amazing Laughing
binge
Emo Kiddy
PostPosted: 18:15 - 26 May 2014    Post subject: Reply with quote
Not got round to doing the lights yet, but today I did do this:
https://scontent-b-lhr.xx.fbcdn.net/hphotos-prn2/t1.0-9/10341762_10152422543805606_3981720174922179609_n.jpg
Head unit is epic. Rear screen shows the DVD at all times. Front can be swapped between DVD and Sat-Nav.
You can also make the rear speakers play the DVD constantly while the front speakers mute out when it wants to give Sat-Nav instructions.
Really good bit of kit.
And a side view from the TV to show how flush it is
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-prn2/t1.0-9/10364081_10152422574715606_3575928666369483356_n.jpg
bamt
PostPosted: 21:19 - 26 May 2014    Post subject: Reply with quote
Two diodes are what you need, assuming that the interior lights are switched on as normal (permanent live, switched ground).
Connect one side of the lights to the permanent positive as normal.
Then, on the negative side of the new lights, use one diode to connect to the existing door switch and another diode to go to your new switch that is just for the new lights.
https://farm4.staticflickr.com/3706/14254097056_c1a09be64e_o.png
Aff
PostPosted: 21:33 - 26 May 2014    Post subject: Reply with quote
Ah, that's much smarter than my suggestion.
bamt
PostPosted: 21:54 - 26 May 2014    Post subject: Reply with quote
Thinking about it, D2 isn't needed; just connect the new lights straight to the new switch. You still need D1 to isolate so that you can turn on the new lights without the standard ones coming on (D1 blocks that) but if the standard ones come on then the new ones come on via D1.
Obviously make sure D1 is rated for the current of the new lights.
PostPosted: 21:56 - 26 May 2014    Post subject: Reply with quote
Uncle Bobby B baby...
binge
Emo Kiddy
PostPosted: 15:00 - 27 May 2014    Post subject: Reply with quote
So I need to disconnect the earth from my 'new' lights, and put a diode in there, flowing from the light, to the earth.
Then add a secondary switched earth, from my new lights, to the chassis.
bamt
PostPosted: 18:47 - 27 May 2014    Post subject: Reply with quote
That's it - assuming that the earth the diode goes to is the switched earth from your other lights, not just straight to the chassis.
stevo as b4
PostPosted: 18:53 - 27 May 2014    Post subject: Reply with quote
Beer fridge, and nice comfy fold up bed sofa, and I'd want to live in there TBH! Thumbs Up
Nb
PostPosted: 14:11 - 03 Aug 2014    Post subject: Reply with quote
What screen is that Binge?
binge
Emo Kiddy
PostPosted: 18:39 - 03 Aug 2014    Post subject: Reply with quote
It's just a cheap Alba / Toshiba thing from Argos I guess, which I pulled all the guts out of.
Most modern LCD teles run 12v now, with a transformer for the 240v plug in.
It's not a bad screen. Takes a while to load up, and I dont have the remote for it, so I've got to click through the source menu each time I want to get it to AV for the DVD player. But it does the job, and I got it for free.
The last post was made 12 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 92.34 Kb
