I need advice
TUG
PostPosted: 23:18 - 23 May 2014    Post subject: I need advice Reply with quote
I bought a bike from a member on here under the premise that all was required for it to pass an MOT was a new rear tyre and a new speedo, it had an oil leak which he said could possibly have been due to oil pressure controlled by and oil pressure relief valve on kawasaki engines as the leak was near the pump on the clutch casing. I thought fair enough, sounds like he's on the ball mechanically and granted he's a nice guy in person.
However I feel like a bit of a mug, If you look in my thread about the project bike at hand as it's turned into, I've replaced much more than just a tyre for it to actually be safe for road use. The bike has been run dry of coolant for quite sometime now and the oil now stinks of petrol, so much so when I went into the garage today I thought my fuel tap repair had failed and had started to leak again. I've messaged the member but I suspect he's just going to say well it was £200 and he didn't know it was out of coolant.
What do? Sad
Haz ER-5, innit!
thx1138
PostPosted: 23:24 - 23 May 2014    Post subject: Reply with quote
Well, it was only £200.
Fix it, or sell it, or throw it away.
PostPosted: 23:31 - 23 May 2014    Post subject: Reply with quote
I bought similar for £200, I made no profit and for £200, its pretty much pocket change.
This is why I tend to try and sell my bikes with a big MOT. At least I know its been checked by another person and is sound in that respect.
Oh and best advice, keep between 2 members that did the sale rather than broadcast and make previous owner look a wang Wink
covent.gardens
World Clap Champion
PostPosted: 23:38 - 23 May 2014    Post subject: Reply with quote
PhilDawson is in my enemy list, so it doesn't surprise me he ran the coolant dry. Everybody in my enemy list is there for one reason or another, usually to do with a lack of intellectual ability, maturity or honesty. Smile
However for a £200 bike, I wouldn't really be complaining.
mentalboy
PostPosted: 23:41 - 23 May 2014    Post subject: Reply with quote
£200 is peanuts for a bike.
I'm sure that had the seller in question known that the coolant was low he'd have mentioned it. Trouble is that unless buyer and seller are savvy mechanics then there are bound to be points missed (and even a savvy mechanic may not know all the faults on his own bike)
Make mine a Corona.
TUG
PostPosted: 23:43 - 23 May 2014    Post subject: Reply with quote
I guess so, maybe I'm not thinking straight due to being tired and I should really just pull the head off and see how the rings are as the oil shouldn't smell like petrol, I used the bike 3 times after I bought it and broke my own number one rule when buying a bike, service it as soon as it's home. Sad
Haz ER-5, innit!
mentalboy
PostPosted: 23:44 - 23 May 2014    Post subject: Reply with quote
Are you in your enemy list? I do believe that you've shown to be wanting in all 3 categories at times Confused
Make mine a Corona.
TUG
PostPosted: 23:45 - 23 May 2014    Post subject: Reply with quote
Very much so, the bike is hard to start but did run ok, I guess it would be difficult to spot as it was leaking oil instead of the coolant that should of been in it's place.
Haz ER-5, innit!
covent.gardens
World Clap Champion
PostPosted: 23:46 - 23 May 2014    Post subject: Reply with quote
The first two are subjective, but please do show me an example of where I have been dishonest...
mentalboy
PostPosted: 23:50 - 23 May 2014    Post subject: Reply with quote
My bad, let's call it two! Wink
Make mine a Corona.
331X2
PostPosted: 06:57 - 24 May 2014    Post subject: Reply with quote
For £200 it was a cheap bike, I considered it when it was for sale but I already have a money pit with a little more character so didn't bother. My bike was £125 as a non runner, getting it running cost me 50p in capacitors but to get it to a roadworthy and reliable condition has cost a good chunk more than the original price, that's how these things go unfortunately but I was aware it would go that way. Stick with it and be happy in the knowledge that the parts you soft won't need touching again for a while.
On a side note, be very wary of people on the internet who shout from the rooftops about their mechanical aptitude, its usually bollocks Thumbs Up
gavbriggs
PostPosted: 14:41 - 24 May 2014    Post subject: Reply with quote
Bandits fill the sump with petrol when the fuel tap leaks/carb floats are stuck/left on prime etc so maybe it's worth looking at that first?
Do a pressure test on coolant system and on the engine. Then if it fails these and there's no external coolant leak you can look at stripping the engine.
It's a bit pointless slating the previous owner. You should always check anything you buy and price/offer accordingly. Even with a £10k used machine you would have to check it over and take the risk.
Your energy is best spent fixing the bike than crying to/about the p/owner!
PostPosted: 15:09 - 24 May 2014    Post subject: Reply with quote
For £200 you get what you get and like it IMO. Can't say you've been ripped off for that money. You can still turn a profit even if the engine's a goner.
Nb
PostPosted: 15:24 - 24 May 2014    Post subject: Reply with quote
Man the fuck up and fix it, i see you have enough diy skills to do the headstock bearings so you can obviously work on your own bike. Just spend a little time and money on it and you will have a reasonable commuter? For 200 quid its hardly going to be a show bike.
69.9mph
PostPosted: 15:37 - 24 May 2014    Post subject: Reply with quote
If I'd spent as much as 200 on a bike then I'd expect it to be pretty much immaculate...
Rolling Eyes
Teflon-Mike
tl;dr
PostPosted: 16:24 - 24 May 2014    Post subject: Re: I need advice Reply with quote
I have followed the thread; as has Snowie as it's been running co-incident with her Strada Salvation one; bought co-incidentally at about the same time, similarly from another forum member.. and she had Spotted Phil's bike as a possible substitute project, unable to afford a Guzzi... As a project for her, I told her quite unequivocally 'no'. Yes it was cheap, but it was pretty obvious given how much ready rider ER5's fetch it wasn't going to be wonderfully economical to do; though might make a better bike at the end if done half reasonably, money put strategically in the right places and no short-cuts taken in the wrong places; but only way to get value from the job would be to ride it out; and for her, as a bike that wasn't the 'dream bike' she wanted, nor a bike she could get the value from as ride into the ground every day commuter; not for her.
What you have done, all looks pretty reasonable stuff; you have dug in to the important bits; brakes, tyres, suspension steering...
And buying any old 'project bike' be it a total derelict in need of resto; a run into the ground MOT fail, needing to be hauled out of maintenance over-draft, or short MOT 'hack' likely to be about to become a run into the ground MOT fail.... pretty much par for the course, stuff you expect to have to tackle, hope 'maybe' you wont, and at £200... did you REALLY expect much 'better'?
Yeah, your a bit of a mug... ALL of us fuck-arseing about up to our elbows in engine oil and grease messing with heaps of old junk not worth the candle.... are!
Sensible folk don't take on other people's 'problems'; and buying old knackered bikes, we are actually PAYING for them! Its a form of masochism! But can be fun.
and you're in the doldrums a bit... its a normal 'project phase'.... but, having batted it this far, what can you do? Chuck it away, or battle it out.
I'd bat it out; and take solace in having a bike 'mechanically' as new, and better than I could buy for the money; even if that means getting a take-out engine from another scrapper (off Ian perhaps?) or biting the bullet and pulling original completely to bits in the shed come winter to do 'properly'. But either way.
No point winging about it; or stirring shit with members on here, folk are quick enough to do that with little enough encouragement as it is; ent going to solve your problems, just make more, so write it off. Deal with what's in front of you, not what's behind, and make the best of.
unluckyluke
PostPosted: 16:40 - 24 May 2014    Post subject: Reply with quote
You're complaining about a £200 project bike? Rolling Eyes At that price anything you buy is a punt and the £200 is probably recoverable by breaking the working parts and weighing in the rest. Nothing ventured/nothing gained sort of thing so what's the problem?
lihp
PostPosted: 17:41 - 24 May 2014    Post subject: Reply with quote
I listed all faults in the advert that I was aware of.
The bike was sold with spare parts I thought was required, and the bike was in constant use everyday for approximately 300 miles per week, never once did I have a reliability issue or an overheating issue while I was using, nor any fuel mixing with oil, or evidence of such.
The issue of the oil leak is what prompted the sale, and that alone as I could not resolve it. However, I made it clear in the advert that I did not know the cause, it could have been serious, or it could have been something simple that I had missed.
It is unfortunate that there seems to be a serious fault, but I was unaware of it, and I sold so cheap as I could not correct the fault, but I did not mislead, and provided details of every fault I knew about, I accurately described the condition of the bike, and when you collected I pointed out every single issue I knew of.
https://www.bikechatforums.com/viewtopic.php?t=288319
Advert is there, as I said, I do not know the fault, only that I could not see any physical damage on the area of the leak (again, pointed out when you collected)
I went out of my way to be sure I did not give the impression that the bike was a "cheap fix" as I stated many times, I did NOT know the cause of the leak, it had done 16000miles previously with no cooling issues.
To summarise, I am sorry that this has happened, and it is unfortunate, but I feel that I did my duty in making you aware of any issues that I knew of, and sold the bike honestly at a fair price, and did not mislead anywhere in the sale.
dydey90
PostPosted: 17:47 - 24 May 2014    Post subject: Reply with quote
JERRY JERRY
CaNsA
PostPosted: 17:53 - 24 May 2014    Post subject: Reply with quote
Why was phil added to your enemy list?
lihp
PostPosted: 18:03 - 24 May 2014    Post subject: Reply with quote
My profile says that I'm not an enemy of his??
HotdogMcDraw
PostPosted: 18:36 - 24 May 2014    Post subject: Reply with quote
£200 for a project bike is a bargain. As stated already in the post going to Kawasaki for 'genuine' parts is going to cost more than sourcing around the net for parts at a cheaper price, that's usually what i do when i buy 4X4's for projects and it's tons cheaper (it's the same for bikes).
If you paid a grand fair enough i would not be happy, but £200 when the faults were listed already? Did you check it over yourself properly or did you just hand the money over and ride off?
https://www.bikechatforums.com/viewtopic.php?t=284963 - What to expect on a MOD 1 (contains video footage) - Posted by BG5067
Honda Rebel 125 (L Plate Warrior) - Nov 2013 to Aug 2014, BMW G650 GS ABS - Aug 2014 to Current
The last post was made 12 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 139.12 Kb
