Doesn't everyone rev match when down shifting?
notbike
PostPosted: 00:47 - 26 May 2014    Post subject: Doesn't everyone rev match when down shifting? Reply with quote
So I've discovered that there's a few different ways to downshift and that I don't know how to downshift properly without rev matching. Naturally I want to understand how this works because it's bugging me, I always seem to fuck it up and the bike dramatically slows down if I don't rev match. (Downshifting too early? Do I have to wait for the revs to drop lower first or something?)
I remember my downshifts were really sloppy when I first started riding a couple of months ago, and then I discovered rev matching and it worked perfectly for me ever since and I've never used any other method for downshifting, which is why I'm confused about this.
But I was told you can downshift without rev matching, and my friend who also started riding recently doesn't understand rev-matching and "downshifts normally" (so we're opposites?) - but really, I have no idea what a normal down shift is because I've never consciously done it. Do you let the clutch out slowly? Wouldn't that just make you lose your speed though? I don't get it, am I being retarded? Someone explain this to me please XD
Also, should I just stick to rev matching, I mean I'm of course way more comfortable with it because it's become a reflex now, but is there any disadvantage to downshifting that way?
Also while on the subject of changing gears, when I did my cbt back in february we were riding these suzuki vanvans.. I can't remember if I was just really shit at riding or if it was the bike itself, but when I was shifting up and releasing the clutch the bike was very jerky if I dumped the clutch too fast, whereas on my own bike I can dump the clutch as fast as I want (sometimes I dont even use the clutch) and there's no jerkiness. Dunno what that was about either, so if anyone knows..?
PostPosted: 01:22 - 26 May 2014    Post subject: Reply with quote
Although poor in quality this excellent video explains blipping the throttle on downshifts. It's short so maybe watch it twice.
It's a skill worth having.
https://www.youtube.com/watch?v=0ABNrYzqJgI
Clutchless upshifts are an excellent way to accelerate quickly and smoothly. I often use the clutch from 1st to 2nd and the rest clutchless.
trevor saxe-coburg-gotha
PostPosted: 06:18 - 26 May 2014    Post subject: Re: Doesn't everyone rev match when down shifting? Reply with quote
The vanvan engine is in quite a few suzukis, and still more chinese bikes under license - it's proven and strong (though not fast, but then what 4t 125s are). But is it "jerky"? Well, some say suzukis are generally a bit "snatchy", power delivery wise - certainly when compared to ye fabled hondas - and there's nothing in the way of a cush drive on either of the vanvan's sprockets. So there's that. However, and for all that, I'm more inclined to diagnose poor technique here. That suzuki engine is smooth if you use the clutch properly.
ScaredyCat
PostPosted: 08:36 - 26 May 2014    Post subject: Re: Doesn't everyone rev match when down shifting? Reply with quote
If the bike slows down like that then you are downshifting early and using the engine to slow the bike. Clutch in, blip the throttle + downshift, release clutch (ease it out don't dump it). Alternatively make sure you are travelling at the correct speed and the revs are correct for the target gear.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Teflon-Mike
tl;dr
PostPosted: 15:04 - 26 May 2014    Post subject: Reply with quote
You CANNOT change gear without rev-matching.
If YOU don't match the engine revs to road-speed in the new gear on the throttle back wheel will.
It HAS to happen. you have a transmission, reduced crank revs, measured in 1000's of revolutions a minute, to wheel revs measured in 100's of revolutions a minute; you halve or double the ratio, the crank revs have to go up or down for the same road-speed.
If you dont 'blip' or at least 'tweek' the twist grip to get that change in crank revs when you shift, then back wheel will lift or drop the engine revs as you feed in the clutch... bang the clutch in, deny the transmission that compliance as back wheel brakes or drives the crank up to new speed; then slip is going to happen between tyre and road...
Carry on doing a throttle tweek or blip... its the 'best' place for matching to happen.
PostPosted: 15:38 - 26 May 2014    Post subject: Re: Doesn't everyone rev match when down shifting? Reply with quote
The way you down shift without blipping the throttle is to throw away any concept of mechanical sympathy or any wish to ride smoothly.
Plenty manage that level of cack handedness Laughing .
Watching people on a track day just stamp down the gears with no attempt to blip the throttle makes me cringe.
RhynoCZ
PostPosted: 16:04 - 26 May 2014    Post subject: Reply with quote
I blip it since the GPz, it's cool, makes downshifting smooth and bike stable + I get the satisfactory feeling of knowing it's good for the bike. I do it so much I once even did it in a car. Thumbs Up
PostPosted: 16:08 - 26 May 2014    Post subject: Reply with quote
I do it most of the time in the car (clutch down, into neutral, clutch up, blip throttle, clutch down and into gear). Depends on the car though, some it is difficult to do due to the pedal layout.
RhynoCZ
PostPosted: 16:26 - 26 May 2014    Post subject: Reply with quote
MC wrote:
Not everywhere/one recommends blipping the throttle, and far as I'm aware it's done more for rear stability than anything else.
You are right, it is done for stability. Thumbs Up
notbike
PostPosted: 16:27 - 26 May 2014    Post subject: Reply with quote
I see, that clears things up then and I know I'm doing it right. I've got into the habit of blipping the throttle every time I downshift so it's all good.
Trevor I would actually like to go back and ride another suzuki how I ride my yammy and see if they are "snatchy" as you put it. I dump the clutch on every upshift with my yammy and I get no snatch or drag feeling at all, its totally smooth. Never ridden a honda.
MC in what instance would you rather not blip the throttle then? I think when I've downshifted too late and the revs drop low I don't blip it, but otherwise I always do it. I mean, in that instance I'd just skip a few gears when I see that shifting one gear at a time wouldn't really work and blipping the throttle for that seems absolutely necessary.
Interesting stuff. Thumbs Up
groovylee
PostPosted: 18:33 - 26 May 2014    Post subject: Reply with quote
Because it's the proper way to do it (in a car at least) and a bit of a lost art. They don't even teach double de-clutching on your driving lessons any more Crying or Very sad
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Doomsnite
PostPosted: 18:42 - 26 May 2014    Post subject: Reply with quote
I thought that was just for old cars which don't have syncros. No need to do it anymore.
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
PostPosted: 19:12 - 26 May 2014    Post subject: Reply with quote
I do it if I can be bothered, or when pressing on. Personally on track I like to control the engine braking with the clutch, maybe I'm just weird though.
PostPosted: 19:57 - 26 May 2014    Post subject: Reply with quote
MC wrote:
ERM, why do you double clutch? Confused
Gives the synchros a far easier life (I got into the habit driving a car with weak synchro on 2nd gear) and smoother. That and it adds some interest to driving
RhynoCZ
PostPosted: 20:09 - 26 May 2014    Post subject: Reply with quote
^ This. Thumbs Up
+ It's just cool, isn't it? Smile
mentalboy
PostPosted: 21:01 - 26 May 2014    Post subject: Reply with quote
I was taught to double de-clutch when I took my HGV Class 1 lessons, comes in handy sometimes.
Another fun skill is changing gear without using the clutch. You'll soon get used to throttle blipping!
Make mine a Corona.
PostPosted: 22:13 - 26 May 2014    Post subject: Reply with quote
Course not - why would they? It's no longer necessary with modern synchromesh gearboxes being so reliable. Hell, some gearboxes have two clutches and pre-engage the next gear for you.
rideslikean00...
PostPosted: 22:55 - 26 May 2014    Post subject: Reply with quote
What's the name for that technique where you blip the throttle, hold the clutch, "preload" the gear (i.e. hold it up), cruise for a bit and then gently release the clutch and apply throttle when necessary? I mean I assume it has an element of rev matching in it because it can make for really smooth changes and it certainly beats holding on the throttle, dumping the clutch and having the engine rev like crazy before dropping back to where it should be, but I don't know what it's called... yet. Wink
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
Mark_F
PostPosted: 23:04 - 26 May 2014    Post subject: Reply with quote
I've done it in the car ever since (near 2 decades ago) a time when I didn't blip, when slowing for a red light on a wet 60 road (obviously at speed), and the wheels lost traction and matched their speed to the engine (virtually idle) revs instead of road speed. Was hairy enough in a car (though it was front wheel drive), not sure I'd want to experience it on a bike...
talkToTheHat
PostPosted: 01:40 - 27 May 2014    Post subject: Reply with quote
Isn't the van van engine related to that of the GZ/GZ/GN? Nice gearbox on the gz, easy clutchless upshifts, downshifts you could be clumsy, not blip the throttle and let the clutch out quite quickly and it wouldn't upset the bike. Was never taught to blip the throttle, just let the clutch out slowly. Then I got an XV535, rode it home with a freshly shined seat, nylon trousers, in a deluge, downshift for first set of traffic lights, haven't got the feel of the clutch yet, and that's my balls on the tank. Soon learnt to be gentle with the clutch as the one thing the bike did really well was engine braking. Taught to brake with all four fingers, so learing how to blip on the downshift was a hard road, but ultimately a much less painful one.
RhynoCZ
PostPosted: 08:20 - 27 May 2014    Post subject: Reply with quote
I experienced it a few times on the GPz on the dry tar. The rear wheel dances around and it does not really give you that much of confidence in front of a corner. I'm only glad my first time was not in wet conditions. Thumbs Down
Today, I've got zxr and they say there's slipper clutch that solves this problem but I blip it anyway. It's one of those habits that could save your arse one day + the zxr goes a bit faster than the GPz I had.
RhynoCZ
PostPosted: 08:24 - 27 May 2014    Post subject: Reply with quote
Never brake with all four fingers, it gives you too much strength to your hand and no control of the front brake. If you need that much of strength to brake, then you should consider checking your brake system. Using all four fingers is like using both feet to brake in a car. Thumbs Up
The last post was made 12 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.03 - MySQL Queries: 15 - Page Size: 141.43 Kb
