SR125 Fork Seal Removal
DanceLikeAMon...
PostPosted: 17:06 - 10 Jan 2005    Post subject: SR125 Fork Seal Removal Reply with quote
Me and my stepdad are in the middle of trying to replace the fork seals on my SR125. I have the forks off, removed the cir-clip and am now at the brute force bit of removing the stantion from the fork.
Have been trying for ages, but nothings budging (apart form the workbench and vice)
I did a search on here and someone said they managed to seperate them by forcing the seal that's already in there. We tried this, but all we have is a mangled up, jammed seal, and the parts still won't seperate.
Please help!!!!!! Sad
Git
PostPosted: 17:35 - 10 Jan 2005    Post subject: Reply with quote
Have you taken the bolt out that holds the two bits of the fork together? if you turn the fork upside down you should see a bolt, this bolt I think should be screwed into the damper assembly inside the fork, if this bolt has not been removed the two halves will not separate, if this bolt has been removed ignore me Wink
DanceLikeAMon...
PostPosted: 17:37 - 10 Jan 2005    Post subject: Reply with quote
Ah! We haven't taken any bolts out. How do you get to it? Do you just need a very long screwdriver?
Git
PostPosted: 17:47 - 10 Jan 2005    Post subject: Reply with quote
The bolt we speak of can be turned from the outside by allen key or whatever bolt it is, but the bit inside the fork, ideally a metal rod with the ends shaved down is my preferred tool to hold it, although there is a way of using a wooden broom handle to hold the bit inside although this is a bit, erm, naughty Laughing
Frost
PostPosted: 18:08 - 10 Jan 2005    Post subject: Reply with quote
yes you have to remove the Damper bolt from the underside of the forks. its normally an Alen bolt. Put in the alen key length ways, then put a bit of pipe or and ajustable spanner ont he end and turn.
I had to use a huge amount of force on mine.
Ones thats done and you have the two fork halves, put a spanner in under the fork seal and lever it out. this too takes a fair bit of force and wil wreck the seal in the process of removal.
The rest is simple after that
DanceLikeAMon...
PostPosted: 18:26 - 10 Jan 2005    Post subject: Reply with quote
Just before I do any damage, can I confirm that I am working on the right bit. If I look down the tube, it looks like a bolt head about 12 inches down (this is in the tube that had the spring and long spacer in it). Is that what I should be removing?
This is what I have: (ignore the 12 inches part, I don't know why I stuck that on!)
https://img.photobucket.com/albums/v158/dance_like_a_monkey/seal.bmp
Is that little bolt head in the middle of the picture the part that I should take out?
Why the f**k didn't Haynes say anything about it???? Got I hate that manual![/img]
Frost
PostPosted: 18:55 - 10 Jan 2005    Post subject: Reply with quote
should be something like this. the damper bolt is normaly a fair way in (up to 2 inches)
Once its undone you will be able to pull the to haves apart
DanceLikeAMon...
PostPosted: 19:01 - 10 Jan 2005    Post subject: Reply with quote
So the end that has the damper bolt head is the same end that the wheels attach to? I was looking in the other end, and the only bolt I could see was half way down the tubes! Rolling Eyes
I have given up for the night , it's too dark and cold, but will look for that tomorrow!
Frost
PostPosted: 19:35 - 10 Jan 2005    Post subject: Reply with quote
yup the damper rod runs up the middle of the spring.
I thought you might have been looking at the wrong end, hence the diagram Razz
DanceLikeAMon...
PostPosted: 19:38 - 10 Jan 2005    Post subject: Reply with quote
Aw nuts! My stepdad has been out playing with it again (the fork that is!) and says there is definitely nothing at that end to remove, twist, tighten, turn etc. So the only possibilty is that bolt about 12 inches down the fork slide!
Is this maybe something specific to the Yamaha and I need to buy a special tool? (it's the 2001 model)
Snip: Here's photos of the bottom of the fork. Anyone see something I could be overlooking?
https://img.photobucket.com/albums/v158/dance_like_a_monkey/motorbikes011.jpg
https://img.photobucket.com/albums/v158/dance_like_a_monkey/motorbikes004.jpg
https://img.photobucket.com/albums/v158/dance_like_a_monkey/motorbikes003.jpg
cagiva gezzer
PostPosted: 20:39 - 10 Jan 2005    Post subject: Reply with quote
https://216.37.204.202/Yamaha_OEM/YamahaDB.asp?Type=13&A=167&B=20
Me thinks its like the old style rockshox mag/quad series where a circlip holds the seals, then the bushes/spacers are forced in VERY snuggly to hold it all together.
By the position of the rebound spring, I would say so.
I KNOW ITS NOT THE SAME BIKE, but it illustrates the point. A very useful sight with microfinches of loads of bikes.
DanceLikeAMon...
PostPosted: 21:40 - 10 Jan 2005    Post subject: Reply with quote
Cheers, but I'm a bit confused by all that Confused
I have taken out the circlip and the spacer, but I still can't seperate the fork as they seem to be physically attached by something.
cagiva gezzer
PostPosted: 23:53 - 10 Jan 2005    Post subject: Reply with quote
Means they are removed by brute force. Very Happy
DanceLikeAMon...
PostPosted: 06:54 - 11 Jan 2005    Post subject: Reply with quote
Ah I see. That is what the Hanyes manaual says, but it was held in a vice and there where two of us tugging it. The workbench was being lifted off the ground we were pulling so hard and it still wouldn't budge. There is defintely a feeling of it being held in place buy something. Confused
Ah well, looks like it's a trip to the mechanics for me!
cagiva gezzer
PostPosted: 11:35 - 11 Jan 2005    Post subject: Reply with quote
Try a series of short sharp tugs. Check the microfinche and make sure there isn't any bolts in the bottom of the stanchions.
An idea that always seems to solve problems! Get an heat gun and try heating up the lower legs. NOT BURNING THE PAINT OFF, just warm it up and try and utilise thermal expansion,
DanceLikeAMon...
PostPosted: 18:20 - 11 Jan 2005    Post subject: Reply with quote
Yup, quite correct! Thumbs Up
As we had had no luck, my stepdad ended up taking it into Ken's in Newcastle to let them have a look. They used one of them reverse hammer type things, and Bob's your uncle.
Since it was there already, he let them put them back together with the new seals. £35 all in and while I've been at work, he's even put the bike back together (although rather worryingly he says that he's been too busy to take it for a test ride, so I will have to test it while he's out tomorrow :LBHH: )
Cheers for the help. ( And apologies to Haynes - they said there wasn't any damper bolt thing in that model and I though they were lying Embarassed )
The last post was made 21 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 88.48 Kb
