| Jambon |
 Jambon Borekit Bruiser
| hmmmnz |
 hmmmnz Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 03:35 - 29 May 2014 Post subject: |
Power is made in the engine, not outside it.
Engine is very carefully developed by the factory to perform as it does, and if there was any quick and easy way to get more power out of the engine, they would have done it; especially on a bike that sells on performance.
Bolt-on tuning then tends to do little but shift compromises around a bit.
Filters might find a tiny little more free-flow capability at 'peak' power, but more likely stocker already has more than engine needs; and a K&N IF you get any gain will simply be from nice clean new filter providing full flow, were one it replaced was probably clogged with crap and needed replacing anyway. If there's any benefit to a K&N and there are very few bikes there is any real benefit; its in thier half life, and how long they take to clog to half flow capacity... and even that... is something of an enigma... they often clog slower by simply letting more fine particulates through the mesh.. ie not filtering as much!
Full-Flow silencer... err, shall we call that a straight through end can? Well, it'll make the bike louder, that's for sure. Potential for flowing more exhaust and getting better scavenging, that might help you find power gains though is limited; that is in the header design and the resonance tuning of them... WHICH adding a baffle-less end can can totaly screw up.
Power-Commander. Well, fuel injection, just like a carburettor, does no more than mix fuel and air in the right ratio to make a bang. You can bung as much fuel in as you like, and on an old carbed engine, dead easy, stick the choke on... wont make a bigger bang.. you just get more black smoke and crap mpg!
Power-commander is modern equivilent of a chap with a bit plastic compartment box of jets, that lets you change the mixture strength... rather a lot of complicated technology actually to do what once upon a time was done with a bit of brass with a hole in it, but still.
Having fucked up the efficiency of your exhaust with the loud end can, and maybe got the motor running a tad weak from a thinner filter, the power commander can then be used to easily let a Dyno Jock, 'correct' the carburation to keep the mixture right accross the rev range.
Manufacturers can be a bit naughty when they put thier fuel map in, and put in lean spots, to get the engine through emmission or noise regs, so the power commander, might be able to iron them out and help find a little mid-0range power, effectively for 'free' and it might help tweek things a bit to get better throttle response.
Other than that? Well, i recall a study a few years back that looked at after-market exhausts, and conclusion was that the very best designed full systems, on an other wise standard road engine, struggled to help an engine gain more than 5%... so the BEST you are likely to get is about 5.5bhp more... at 'peak' revs.
IF the engine is a good'n to start with and got all its factory claimed ponies still... it is a decade old after all.
First rule of tuning. before looking for more than standard, make sure you have what you should AS standard.
If your engine's on its last legs with slappy pistons and clattery cam chain, all you will get is an even noisier sloppy clattery engine, that'll get sloppier and clatterier quicker!
But, assume its a good'n; and 5% for a full system.... you will be lucky to see much at all for just an end can. Like I said, good chance that screwing the harmonics you could actually LOOSE power.
But, depends.... its all swings and roundabouts; 'peak' power is only one number; the max power the engine might make under load, wide open throttle at peak power rpm.
You could loose 5bhp off that peak, and not notice it, cos you rarely use it. But if you gained say, 2bhp over all the crank-speeds the engine is regularly used... could actually make the bike faster round a track, having more 'available' power to actually put to the road more of the time.
Liklihood though, is you will gain perhaps 1-2bhp more at peak revs. AND you will see a 'loss' of perhaps 3-4bhp in the mid-range and at the bottom of the power ramp.
That loss of mid-range is likely to actually make the bike 'slower' in limiting useable power, in how much it can put down and for how long... but pulling the base of the power ramp down, and the peak up a tad, the gradient will be steeper, and the increase in power with rpm, how much more thrust gets delivered from the rate of change of power, will make it FEEL like its pulling harder and SO much more powerful than it actually is...
Greatest 'performance' advantage of an after-market end can? Mainly saving a little weight, rather than improving engine efficiency.
So... what's your objective?
Cos, old bit of pit-lane-lore; want a faster bike? Fit a better rider.
And modding YOU, making you a better rider, is a wonderful mod. You dont have to declare it to an insurer; wont put your premiums up. Doesn't wreck reliability or ruin fuel ecconomy; if anything a better rider, with some sort of advanced riding qualification is likely to get premiums down, and riding more efficiently, get better mpg, wear out less service spares, not break down or crash, and so save SO much money... AND go faster while doing it.
Best of all, better rider works on any bike; not just this one, dont wear out, and only gets better with use.
My advice? If you want to get 'more' from your bike than it has now;
1/ service it properly, make sure it can give all it can.
2/ make sure you have good tyres, good brakes and good suspension. These will let you get far more from standard power than any gains you might chance upon with loud pipe and jst kit.
3/ make yourself a better rider; get the most from what the bike has to offer.
Its a very quick and very capable bike, and on a public road, how much of what it has as stock you can use is limited not by its fueling or exhaust or its suspension, but by how much 'risk' the rider is prepared to take.
That bike, round a track, ridden to the edge by experts taking it to the limit; mods you suggest would at best find tenths of a second a lap; worst loose them seconds a lap... at maybe a lap a minute....
Real world, real road, that difference is riding the thing to the ragged edge, to get to a give way, three seconds ahead of some-one else, who guesses the gap better to get out in front of you.
A suggestion I no doubt expect you will bluster on; BUT remains my advice. Leave it stock.
And if you want to go faster, look at where the biggest gains are to be found.
So back to the top, and power is made in the engine not outside.
Biggest areas to find gains ent likely to be in the engine, or even the bike, so it sure as heck isn't going to be in an empty pipe and a little black box. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| bamt |
 bamt World Chat Champion
| 1198 |
 1198 World Chat Champion
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 08:18 - 29 May 2014 Post subject: |
Don't listen to the above. I read one paragraph and couldn't be bothered.
You'll probably get around a 10% gain with the mods you propose.
With regards to want more power buy a bigger bike, there's nothing like riding a bike with a proper exhaust system and a custom map. World's above a standard bike of any cc. Smooth predictable power. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| el_oso |
 el_oso World Chat Champion
| Robby |
 Robby Dirty Old Man
| chris-red |
| chris-red |
| _Iain_ |
 _Iain_ Banned
| Fisty |
 Fisty Super Spammer
 Posted: 17:01 - 29 May 2014 Post subject: |
| Teflon-Mike wrote: | Power is made in the engine, not outside it.
Biggest areas to find gains ent likely to be in the engine, or even the bike, so it sure as heck isn't going to be in an empty pipe and a little black box. |
You really do talk shit sometimes.
Bikes are built to a set of rules from eurocrats. Exhausts designed to kill emissions also kill power. The fuelling is set up to these exhausts.
The TL as stock has huge heavy restrictive cans and a crap ignition map. I bunged on a used set of cans, a second hand Power commander and a K&N air filter then took it to JHS racing who set it up for me.
The net result was 15BHP extra throughout the rev range an extra 20Nm of torque, better fuel economy and a much nicer bike to ride as the fuelling had been smoothed out perfectly. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
| stevo as b4 |
 Posted: 19:08 - 29 May 2014 Post subject: |
Sorry but in this thread Tef's one size fits all approach is pretty inaccurate IMO!
It reminds me of a bloke at work who heard me talking about my car, and tuning, and every time I spoke to him he kept on talking about how a full Janspeed exhaust system and manifold will give you 15% more power and 10-15% more economy. He was talking about his sole vast engine tuning experience with a 1.8 Carb fed Ford Sierra!
I can't offer the OP any figures for his bike, but back at the NEC show in 2005, I was shown a dyno chart by PDQ who were the u.k Dynojet kit importer at the time, and on a ZX6R J1-J2 like mine a decent race can, K&N drop in the box filter, and a properly set up DJ kit with dyno time, showed +4bhp from 8000-12000rpm and at best exactly the same as std everywhere else.
It's nice to speak to an Honest tuner though, who can back up questions with results, and experience and had a graph of proof to show me. |
| Jambon |
| hmmmnz |
 Posted: 23:01 - 29 May 2014 Post subject: |
generally putting a can on makes a bike run a little leaner,
you can get away with it sometimes, but some times because of the already stock lean spots for emmissions, it causes quite bad flat spots,
for sure do the exhaust, but get the power commander and get it tuned for a nice smooth torque curve,
dont worry about horsepower, smoother the bike the faster you'll be ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Jambon |
| 0l0dom0l0 |
 Posted: 23:18 - 29 May 2014 Post subject: |
| Jambon wrote: | Ah great that makes sense.
If I'm going to the trouble of fitting a straight through end can, buying a power commander and paying for somebodies time on the dyno, would it not make sense to get a K&N air filter then for another £40? |
Yes.
BMC is better for power though I'd say. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| YBR Ric |
 YBR Ric Spanner Monkey
| lihp |
 lihp World Chat Champion
| stu_m |
 stu_m Crazy Courier
| Fisty |
 Fisty Super Spammer
| stu_m |
 stu_m Crazy Courier
| Fisty |
 Fisty Super Spammer
The last post was made 11 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
