Do you aim for the upper or lower limit of valve clearances?
0l0dom0l0
PostPosted: 08:26 - 29 May 2014    Post subject: Do you aim for the upper or lower limit of valve clearances? Reply with quote
Just doing the valve clearances on the TL.
The manual states that the acceptable clearance is 0.1-0.2mm for inlet valves and 0.2-0.3mm for exhaust valves.
I've got all the shims out etc as pretty much all the valves are put of spec and I'm going to have to buy new shims.
But when calculating the new shim thickness where do the clearances want to end up after adjustment? Do they want to be at the lower end of the limit, or middle, or upper?
The Haynes book of lies it telling me to the lower end but I thought you aimed for the middle?
Many thanks
Dom
PostPosted: 08:29 - 29 May 2014    Post subject: Reply with quote
Bucket and shims tend to tighten up over time so I do these to the upper-end of the valve clearance.
Locknut adjusters tend to open up over time so I do these to the lower-end of the valve clearance.
DrSnoosnoo
PostPosted: 09:49 - 29 May 2014    Post subject: Reply with quote
I had the haynes book give me a big table so you could relate current clearance with shim thickness to tell you the correct shim that would get you back to clearance.
Robby
Dirty Old Man
PostPosted: 10:41 - 29 May 2014    Post subject: Reply with quote
As SnooSnoo said, look in the table in the workshop manual. You should find that you can get away with re-using some of the existing shims by moving them around, instead of buying a whole set of new ones.
0l0dom0l0
PostPosted: 12:31 - 29 May 2014    Post subject: Reply with quote
The Haynes table gives me the shim to get them to the tighter limit of the clearance.
I've worked it out to get to the middle anyway as upon more research that's the target.
PostPosted: 14:59 - 29 May 2014    Post subject: Reply with quote
Remember that the shims are not necessarily the size they say they are so it's going to be "ballpark" to a certain extent.
Measure them with a micrometer (both the ones you've taken out and the new ones).
PostPosted: 16:25 - 29 May 2014    Post subject: Reply with quote
Too right Stinky I've found a good proportion of shims are not the size that's printed on them. Nowadays I tend to lap them to the size I need since they almost always need adjusting down in size.
0l0dom0l0
PostPosted: 17:41 - 29 May 2014    Post subject: Reply with quote
Didn't even think to do this!!
Copycat73
PostPosted: 19:51 - 29 May 2014    Post subject: Reply with quote
given the sizes of shimms available aim to get them within spec. that's all..
I`ve seen gaps that shrink and enlarge some what of a lottery.
wemoto shimms were spot on size to a closer spec than the Yamaha which were the smallest fraction over sized.
charts are usefull but after the first you can work out the size in your head without lookin.
caveat emptor
PostPosted: 19:56 - 29 May 2014    Post subject: Reply with quote
My shimcalculator lets you mix and match the wrong-sized shims on paper before you go buying them.
Fizzer Thou
PostPosted: 20:16 - 29 May 2014    Post subject: Reply with quote
I have owned my Exup 1000 for so long I keep a record of clearances and what size shim is fitted where.So in the future I can measure the clearances and see which way they are shifting so as to choose the correct size shim before removing them.With shim-under-bucket placement this makes the job quicker and easier.
Always have a 'Plan B'
Nobby the Bastard
Harley Gaydar
PostPosted: 20:29 - 29 May 2014    Post subject: Reply with quote
How regularly are you doing this?
As an FZ owner, I've done it once and paid someone to do it once, so thats twice in 31k miles.
That's a lot of miles to keep a bit of paper for. I'm luckly if I can remember where I left the spare shims...
Triumph Sprint ST 1050
Fizzer Thou
PostPosted: 21:08 - 29 May 2014    Post subject: Reply with quote
My Exup now has over 52,000 miles on the clock and I have checked and adjusted where necessary every 10,000 miles.I know what it says in both the genuine Yamaha and the Haynes manuals,but I do things my own way,not what is suggested in a book.
If anything,the R1 engine is easier to work on than the Exup,despite the fact that there are 20 valves to check and the frame is tighter around the engine on the R1.
The last post was made 11 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.43 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 78.78 Kb
