Replacement header pipes
Ripp3rCrust
PostPosted: 10:27 - 29 May 2014    Post subject: Replacement header pipes Reply with quote
Hi,
The header pipes have finally rotted through on my CBR and as a result are temporarily patched up whilst I can obtain a replacement. The corrosion seems to be a few holes strung along the bottom of one of the pipes and and a small hole where they join, leading me to assume it will probably be more worthwhile to just replace altogether rather than getting them welded.
I am unsure which way to go about it however. The only breakers I can find at reasonable prices seem to be in the USA meaning it would cost around £70 with shipping (e.g. these: https://pages.ebay.com/motors/link/?nav=item.view&id=121084335205&alt=web ), after taking a gamble on condition. If I were to go this way, I would sand them down and spray with BBQ paint to prevent any further corrosion.
A new set of header pipes can be had for £175 (with gaskets) from Sandybikespares, or £200 from Delkevic.
As a result, I am unsure which option would be best. I would prefer to spend as little as possible as I am pretty broke at the minute, but unsure as to whether going used may be a false economy.
What do you reckon is the best option?
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
trisers
PostPosted: 22:46 - 29 May 2014    Post subject: Reply with quote
I fitted a set of stainless downpipes from Sandybikespares to my 600FK...they seemed well made although a little fettling was required to line up the lower mount to the frame bracket...a case of fit and forget really
Itchy
PostPosted: 23:39 - 29 May 2014    Post subject: Reply with quote
DO NOT use Sandy bike spares, the company are actually borderline scammers. They use inferior materials and poor workmanship.
I put a set on my CBR600FX, they were baaad.
First off they have no balance pipes, the CBR600F4(i) series has balance pipes between 1+2 and 3+4, without them it kills the midrange
Secondly they don't actually last very long. I put new header pipes from sandy on in 2008. I did 1600 miles in 08 then zero in 2009. It was then stored away when I went overseas. In 2010 I did 360 miles to the BCF Barbecue before it was put back into storage.
I came back and took it to an MOT it failed on the exhaust blowing, the header collars on one port had snapped and it was blowing from there. Two other port collars also had massive all the way through cracks and were about to go too.
The bottom of the pipes where they join together there was also hairline crack, the place where you put the link pipe on had also split creating yet another crack.
So they in effect lasted less than 5 years and <2500 miles use, I admit that the bike was stored for a significant amount of time.
barrkel
PostPosted: 00:00 - 30 May 2014    Post subject: Reply with quote
I've had good results from Delkevic. I'd buy theirs again.
CaNsA
PostPosted: 02:12 - 30 May 2014    Post subject: Reply with quote
I had Delkevic on my cbr600, not bad.
not bad indeed.
davebike
PostPosted: 07:04 - 30 May 2014    Post subject: Reply with quote
I fitted both types and think they both could come from the same factory in China !
Of the two Sandy bikes are the cheapest and best to deal with
Dave
I have a sandy front pipe one of my own bikes
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Ripp3rCrust
PostPosted: 09:35 - 31 May 2014    Post subject: Reply with quote
Thanks guys. There seems to be a wide range of opinion! I went for Delkevic in the end, I don't think they have the balance pipes but from reviews I have read this doesn't seem to be a major problem but we shall see.
Once they have turned up and I have fitted them I shall report back on their quality.
I have read that it is best to replace the nuts on the studs with brass ones, where can I get these from?
PostPosted: 10:10 - 31 May 2014    Post subject: Reply with quote
The GPZ500S downpipes that they sold me ran too wide and started to melt through the belly pan. Checking their feedback, this was a known problem which they haven't bothered sorting.
Sandybikespares customer service.
recman
PostPosted: 10:30 - 31 May 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Honda-cbr-600-f3-fv-fw-steelie-steel-frame-micron-exhaust-system-/281347070593?pt=UK_Motorcycle_Parts&hash=item4181979a81
Any good?
The last post was made 11 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 61.96 Kb
