| busbar |
 busbar Two Stroke Sniffer
| sensi5446 |
 sensi5446 Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:02 - 30 May 2014 Post subject: |
I've never used a torque wrench on an axle nut yet. I wouldn't expect a garage to use one either. ____________________ Biking is 1/20th as dangerous as horse riding.
| busbar |
| Bezzer |
 Bezzer World Chat Champion
 Posted: 10:19 - 30 May 2014 Post subject: |
I find them useful for very precise things like cylinder head nuts and for very delicate things like the rocker blocks on my Enfield (which do up to 5ft/lb which is not very tight at all). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Howling TerrorOutOfOffice |
 Posted: 10:29 - 30 May 2014 Post subject: |
For the most part I go by feel but some areas of the bike I prefer some 'mental security' so use the torque wrench on chain adjuster bolts, fork pinch bolts and wheel nuts. ...and calipers..sump plug.  ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| bugeye_bob |
| yen_powell |
| map |
 map Mr Calendar
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| smegballs |
 smegballs World Chat Champion
| m3-paul |
 m3-paul Spanner Monkey
| stevo as b4 |
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 18:16 - 30 May 2014 Post subject: |
just read this ... oh sh1t I`ve got 4 of the things .. 1/4 3/8 1/2 and 3/4 drives  ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| YBR Ric |
 YBR Ric Spanner Monkey
| busbar |
| G |
 G The Voice of Reason
| STONEY! |
 STONEY! Brolly Dolly
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:45 - 30 May 2014 Post subject: |
I have three torque settings:
Finger tight plus a quarter turn
Quite tight
FT
I pick whichever is most appropriate. The only times I have used a torque wrench have been for bits of engine. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:49 - 31 May 2014 Post subject: |
In my day job, I run a garage that works on cars and we hardly ever use torque wrenches, unless it's on nuts/bolts that need very specific torque settings, like cylinder head fixings.
Cars tend to use coarser pitch threads and larger diameter fittings, plus most of the important bits aren't overly exposed to weather, so corrosion isn't often an issue.
On a bike, everything is exposed and it's mostly tiny and cheaply made, from lightweight materials.
If you aren't an experienced spanner man, I would say a decent torque wrench is a very worthwhile investment, along with a good supply of some sort of copper anti seize grease. ____________________ Things get better with age; I'm close to being magnificent........
| Teflon-Mike |
 Posted: 08:38 - 31 May 2014 Post subject: |
They are useful. But, most common torque wrenches are yard-long 'high-range' wrenches covering the sort of torques you have to set on diesel engine cylinder head studs, or brake calliper mounting bolts. Useful if you are fixing head-gaskets or overhauling brake callipers...
Much more 'useful' but much less common, especially on a motorbike, is a 'low-range' 1/4 drive torque wrench; this covers the sort of 5-25Kg-m range that general 'non critical' fasteners fall into, like the ubiquitousness M6 (10mm Spanner) casing screw, used everywhere on motorbikes and everything else these days, and NOT so much to make sure that they are done up 'tight enough' but to make sure they aren't done up too much, and you start stripping threads out of alloy casings.
Topic of conversation yesterday actually with No3 Son; who was getting all over exited being allowed to play with a 125 Super-Dream and 'spanners', and when he reached for the socket set, getting told "NO! I said SPANNERS!", and arguing blind with me they were the same thing, followed by, "yeahbut" and bluster that sockets are 'easier'; leading to lecture on the merit of spanners and 'simple' hand tools.... you are now going to get.
If you are a socket jockey... and so many are these days... then a torque wrench is almost essential.... because with umpety moving parts and loose snap joints between the palm of your hand and the thing you are tightening, you have bog all 'feel' through the tool for it.
If you look at your spanners, the 6mm spanner has a handle that is maybe 2 1/2" long.. the 19mm spanner will have a handle that's perhaps 12" long.
'Torque' remember is force times leverage; so the different handle lengths on spanners are strategically the length they are, so that for the same 'palm pressure' you get the typical fastening torque for the size bolt you are doing up.
And, a single bit of metal; there's nothing else between your palm and the fastener, which you can see, in the jaw of the spanner... so you can see AND feel what's going on.
On usual 3/8 drive ratchet wrench you have a handle about as long as a 17mm spanner, but can have any sized socket on there, from maybe 6mm up to 19mm...
So you don't have the inherent 'palm pressure' torque sense a spanner offers, and you are far more likely to put two or three times the torque a small fastener needs onto it, through a handle as long as one for a fastener three times the size...
You also cant SEE the fastener in the socket.. so you dont know if the jaws are opening or the corners rounding, until the ratchet slips, or the socket splits!
And the force you are applying 'off-set' from the head by at least the height of the socket, if not an extension, so are applying torque in two axis to where its reacted.. making it harder to hold and twist and keep it straight
AND you have any slop and flex in all the moveable and de-mountable 'parts' between your palm and the fastener....
ALL conspiring to rob you of 'feel'.
So a torque wrench is 'more' essential to a socket-jockey, providing the 'feel' they dont have, with an artificial palm in the form of a snap-head!
WARNING: - when it comes to torque wrenches; ALWAYS CHECK THE UNITS.
1Kg-m is 10Nm, is 7 1/4 ft-lb.
As many fasteners are very accurately 'set' to the wrong torque with a torque wrench, than are very inaccurate set, closer to the right one, with a spanner!
I very memorably had to drive 250 miles when I was at college once to find out what one of my mates had done to his Morris Minor, to discover that he had tried to do up the 7/16AF screws holding the oil pump on with a yard long high range torque wrench, set 10x the torque in the book... I think it was something like 6Ft-Lb... but high range torque wrench didn't start that low, so he found the lowest 6 on the scale, which was 6Kg-m!
As has been said by others; no tool is a substitute for common sense. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Sload |
 Sload World Chat Champion
| busbar |
 Posted: 13:40 - 31 May 2014 Post subject: |
Fortunately for me I think I have got a foot in the camp with the ability to use common sense.
As an electrician, and a fairly active DIY-er at home, I'm no stranger to using tools but I just don't have a lot of experience in using them on vehicles. At work I do sometimes get to use spanners and sockets on electrical connections, preferably with the electrcial supply isolated , and it is then that common sense has to kick in to ensure that connections are tight, but not too tight.
As was mentioned earlier in the thread, I guess one advantage of using spanners and common sense is to remove the risk of relying entirely on a torque wrench where poor quality, poor calibration or an incorrect setting could prove costly.
As I get more into the maintenance of my bike I proabably will invest in one but, after taking all this advice on board, I think I'd use it with caution. |
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful? |
