zxr 750 j1 premature limiter
j4m13
PostPosted: 19:11 - 01 Jun 2014    Post subject: zxr 750 j1 premature limiter Reply with quote
Hi. I have recently bought a zxr 750. It is a j1 and is a jap import. Bike revs right to the top in neutral or in gear with the clutch in. However when out on the road every gear seems to hit what feels like a limiter at 8.5 k this equates to 110mph in top gear. Is this a jap restriction. If so how do I get rid of this.
RhynoCZ
PostPosted: 21:24 - 01 Jun 2014    Post subject: Reply with quote
What's your final drive gear ratio?
j4m13
PostPosted: 21:26 - 01 Jun 2014    Post subject: Reply with quote
Std. Does it in every gear though.
RhynoCZ
PostPosted: 21:31 - 01 Jun 2014    Post subject: Reply with quote
I doubt there's an electronic device that'd restrict the engine when at speed. I'd check the ram air intake system, airbox and carburetors for any restrictive stuff. If there'll be nothing, then I'd check the jets.
I can't really think of anything else. There must be some restriction in the intake/fuel system. It could also be ignition.
Coxyzxr
PostPosted: 07:24 - 02 Jun 2014    Post subject: Reply with quote
Check all airbox hoses and areas.
Revving to limiter at standstill but not under load sounds like a fueling ratio issue.
If there was a limiter it would normally be limited in neutral and/or clutch in too on older bikes. Zxrs do not have sophisticated electronics, no gear position sensors or maps for certain gears etc.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
j4m13
PostPosted: 18:29 - 02 Jun 2014    Post subject: Reply with quote
Cheers boys. Will investigate at the w/e as I said though cuts out bang on 8k in every gear but revs right out in neutral and clutch in.
Hugh Farking Cant
PostPosted: 09:06 - 03 Jun 2014    Post subject: Reply with quote
Jap home market bikes of that era were limited to circa 112mph by the CDI. (unsure if TCI or CDI on 750 J ).
Restricted smaller Yamahas of that time limit rpm to 12,500K in all gears if tampered with. The Kwak may be similar.
It does seem ignition related if in all gears.( especially as you state ;
"bang on 8K")
The ZXR400 imports had a limiter, a small sealed box in the region of the speedo .
Has it still got import speedo fitted or been replaced by a mph unit ?
There is a zxr 400 specialised forum; it may be prudent to join simply to pick the bones out of any derestriction threads on there ( must be loads)
The J series has no ram air induction as suggested in earlier posts.
The hoover pipes are cosmetic and blanked at the tank.
Ram air started on the L models.
Look on the ignition unit (CDI/TCI) to see if any numbers are visible still; they are printed and have a tendency to wear off though.
Compare to pics showing numbers on Euro ignitors.
The 900 unit fits the harness but has a lower rev limit, (recommended to swap if engine has been upgraded) so other units do fit and run with that harness.
ADDITION; restricted Yams will rev out;off the clock, whilst stationary but not whilst in gear/ moving ; Kwaks MAY be similar.
Remember; Someone on here always has a blacker cat.
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 51.69 Kb
