Dirt Jumper gears
Bike Chat Forums Index -> The Cycling Forum
Fladdem
PostPosted: 15:19 - 28 May 2014    Post subject: Dirt Jumper gears Reply with quote
Last year, I bought a 2008 P2 frame with DJ3 forks and built her up into a neat little DJ bike. However it gets used for hooning round town, I practise a bit of trials on it, nothing major, due to the single-speed, and even light XC work, just love the frame geometry compared to a proper XC bike combined with my 410mm long seat post, nearly tall enough to sit on.
Now, I'm currently running 34/16, but not properly converted to single speed, it's a 7 speed cassette with a 7 speed chain around on the best gear for the straightest chain-line possible. I was wondering if I could convert to a 1X8 set-up easily.
I know it's doable but whether it is feasible or not I don't know.
Or convert properly to SS, I have spacers, an 18 tooth sprocket and a brand new chain, I just need to hunt down a 34 tooth front with the same pattern, I like running the bash-guard for the trials-y type stuff I do, I catch the guard a lot so it has saved my sprocket a few times.
If I went to gears, I would probably use road bike gears and paraphernalia, because generally there are shorter cages with road bikes and closer ratios, for getting the launches at the 4X track Wink.
Would the derailleurs hold up OK to abuse? I chew threw them like nobodies business, I don't if it is that old saying, buy cheap, buy twice, or whether I could trash an expensive one just as well. which if that is the case, I may as well buy cheap?
Thanks, Adam
KLR600
PostPosted: 22:31 - 28 May 2014    Post subject: Reply with quote
Assuming your dropouts have a mech hanger then there'd be no problem actually fitting gears, the question really is do you really want gears and then what gears to fit which is up to you really. I'm running an old Shimano 105 short cage rear mech on my DH bike which is fine and does what it's supposed to. No reason why you should prematurely kill a derailleur if it's adjusted properly short of smashing it into a rock or something.
Personally I wouldn't bother with gears. I've had jump bikes (started with 14" frames but my current one and the one before this was a 12" frame!) for years and I've used them in the same way you do with a long seat post. Commuting, BMX/4X/pump tracks, dirt jumps, light DH/XC, street riding etc etc. The only thing I don't ride is trials. My preferred gearing on 26" wheels is 36/16 although after a few years of commuting to the same job in Manchester I'd of liked to go down to a 14 on the rear if I'd been using it just for commuting. My current gear ratio is a bit pants and feels far too easy to pedal out (28/13) but it's all brand new so I will replace it with a different ratio when it wears out.
If you're really keen on trials it might be worth looking at getting a trials specific bike. I had a 20" Onza T-Pro for a few years that was great fun to hop about on. The trouble was with the single trials ratio gear it was useless for actually riding to any trials spots (but ace when you got there) so you always had to drive or take the train. I bet you could pick up a used one for between £100-£150 with hydro brakes.
Here's one.
Here's another one.
You could probably convert your bike to SS and buy a used trials bike for the same price that you could convert your current bike to gears.
<Take Cool Photos!>
PostPosted: 00:17 - 29 May 2014    Post subject: Reply with quote
Gears are for poofs. Ride single-speed or fuck-off. Laughing
All my bikes are single speed. It's not about having lots of gears. It's about having the correct gear.
My road bike is running 46/17 on 27" wheels. My MTB is running 22/20 on 29" wheels. My fuck you I'll ride single speed if I want, even up the steep hill to the pie-shop bike is running 32/16 on a 28" wheel.
Fladdem
PostPosted: 18:38 - 29 May 2014    Post subject: Reply with quote
I've got a couple of single speeds. My errands bike, 1958 Raleigh, just gets left alone, the three speed works, I just don't use it, my fixed gear bike, my 26er rigid DiamondBack is single speed, and this Specialized P2 is. The other bikes are geared.
I was hoping KLR would pitch in, I know you ride a lot of DJ bikes, in fact you gave me some good advice when I was building her up.
So, are you suggesting I properly convert to single speed? Go the whole hog and take the cassette off and replace with my spacers? DO you use any sort of device to tighten the chain? I have chain tugs, like on a motorbike, but they seem a bit rubbish really, could be because they were cheap tat. I was thinking maybe get a chain tensioner as well?
Like this?
https://1.bp.blogspot.com/-QTlpqYX4QS4/T37tuq42HzI/AAAAAAAAABw/NkXRDGiDFm4/s1600/SS-tensioner.jpg
I may look into a proper trials bike as well. If I did get one I'd build it up, much more satisfying. I find working on bikes just as enjoyable as riding them.
KLR600
PostPosted: 22:12 - 29 May 2014    Post subject: Reply with quote
Did I? Be careful listening to what I say in here, it can get your arm broken Laughing
Yeah I would, especially if you already have the spacers lying around. You can get the cog in the perfect position for a straight chain line so less wear on your chain and less weight too (not that you'd really notice on a jump bike). Much easier to change gear ratios too as rear cogs are available in just about every size you could want for a couple of quid each from most bike shops.
Fladdem wrote:
Do you use any sort of device to tighten the chain? I have chain tugs, like on a motorbike, but they seem a bit rubbish really, could be because they were cheap tat. I was thinking maybe get a chain tensioner as well?
Depends on what dropouts your frame has. I think the P2 has horizontal dropouts. If it has I would be using chain tugs to make sure the wheel is aligned properly as I've seen countless guys at the trails spending ages struggling to get their rear wheels straight with proper chain tension without chain tugs after fixing a puncture or re-building their bikes from transporting them to the trails. Chain tugs make it a breeze to adjust chain tension as well, much like a motorbike. No need for a chain tensioner if the tugs are working fine.
If you have vertical dropouts then you'll need a chain tensioner like the one you posted as chain tugs won't work. You won't have many options for chain tensioning if you do have vertical dropouts.
I've been lucky with my current and last bike as they've both had adjustable dropout systems. Kind of like chain tugs but the whole dropout assembly on both sides moves so you don't have to loosen the rear wheel to tension the chain. Just a few allen bolts to adjust and away you go. My old NS Suburban and Mongoose Ritual had chain tugs, they'd have been a pain without them.
If you end up trying to build a mod trials bike (20" wheels) then it would almost certainly be cheaper to buy a second hand one by quite a lot I reckon. I can't imagine those rear wheels will be cheap to source on their own and the freewheel is usually on the crank on them so you'll need to find someone who supplies cranks that you can bolt a freewheel to. The bars and stem are both fairly specialised too. Might be worth looking for a bit of a worn out one to overhaul but I wouldn't like to build one from scratch unless you have lots of money to burn.
If you end up building a 26" wheel trials bike then it'd probably be a bit easier in terms of sourcing parts but in my experience trials bikes can be just as expensive as top tier DJ bikes. Their crazy hubs with a million pawls in the freewheel for instant engagement and their extra light frames etc etc don't come cheap.
<Take Cool Photos!>
Fladdem
PostPosted: 21:30 - 31 May 2014    Post subject: Reply with quote
How do I remove my cassette? I have a lock ring remover, but It was done up by a huge guy at the bike shop with a pair of handlebars on the end of the tool. I don't want to take it back, out of principle, not going to go into it, but I don't really have the stuff at home to do it. Now I'm blathering, I may as well just take it back and just see if they're more helpful now, have heard about a new manager, but could be rumours. What am I saying?
So plan is: new chain-tugs, old ones are cheap and nasty and bust. Give the wheel to the LBS, play with spacers, get the line, give the wheel back to LBS to tighten up again.
That sounds awesome. I'd like to get into riding properly, but I could never justify the cost of it all, so I just lusted after fancyier bikes, but mines OK, for a DJ bike built on the cheap.
My mate races, reckons he has over 3000 invested in his bike. He has a trials hub, for launches, runs a 1X9. His bike is awesome to ride, but I don't like his brake, I have never rode a bike with hydraulic discs that I like. I still prefer my BB7's over any other brake I have used.
haroman666
PostPosted: 21:42 - 31 May 2014    Post subject: Reply with quote
Holy fuck...
Good luck on getting that off dude. They're only meant to be tightened up to like 25 - 40Nm from memory... And the mating faces of the lock nut and outer gear are ribbed so it "locks" it into place.
You'll need a chain whip and a cassette tool.
Or maybe a new hub and cassette if the guy at the shop has fucked it.
And I haven't read the whole thread, but going single-speed sounds like a better option considering the weight of the bike and the fact that you more than likely spend most of your time stood up since it's a DJ bike... Especially when putting the power down.
KLR600
PostPosted: 01:34 - 01 Jun 2014    Post subject: Reply with quote
And this is why you work on your own bikes! If I saw someone in a shop doing that to my bike I'd be straight in the workshop and making sure they never went anywhere near my bike ever again.
If you already have the lockring/cassette tool then all you need is a chain whip and some strong arms by the sounds of what the last guy did.
I'd avoid that shop for sure. You really don't need a shop to install those washers and the singlespeed cog. Old cassette slides off - new spacers and cog slides on, tighten the lock ring to between 30-40nm. Simple as that. You don't have to tighten the lock ring at all while you're playing with the chain line as you won't be riding it, I reckon once you've loosened the over tightened lock ring that you can finish the conversion of the wheel in less than 10 minutes including sorting the chain line.
No need if you're not racing IMO. Definitely nice to have for sure but my brand new 2014 top of line model jump bike just cost me €700 (35% discount if you know where to look!) and my DH bike was a bitsa which has cost around £300 in total. My jump bike is amazing to ride and my DH bike is fun too but on it's last legs. I've had it for about 5 years now though and I used to ride it weekly when I was in the UK so it's done me well.
<Take Cool Photos!>
Fladdem
PostPosted: 16:06 - 01 Jun 2014    Post subject: Reply with quote
I almost always try to perform all the work on my own bike. That was just another reason I don't like going to the bike shop. I told him I couldn't get it tight enough, it kept coming loose, so he just bollocked it up tight. Sick
Any recommendations on a chain-whip? It was next on my bike tools list anyway. I tried using an old chain wrapped around the seventh gear and then cable-tied to the rim with about ten cable ties, I snapped the first two and stretched the rest.
I reckon it should be an easy enough job. I can build a wheel, sort of, so I can sure as hell put some spacers on a freewheel, and my spacers a re loads of skinny ones, so should help getting the line spot-on.
I've never owned a brand new anything, I really want to get a new XC bike, a proper one, something that no one else has molested before me, but having always been low on money, could never afford brand new. Even this bike was built out of spares in the garage, cost me about £150 in total, but mostly on bearings and a new back wheel after I folded the XC wheel in half after over-shooting my first jump and landing about 4 feet in the air onto my back wheel at a funny angle. Laughing
el_oso
PostPosted: 12:27 - 02 Jun 2014    Post subject: Reply with quote
I'm fairly sure that the lock ring on the cassette is 'self tightening'. Just putting pressure on the pedals will tighten it up.
I've had more sucess by putting the tool in a big metal vice and turning the wheel.
Duke 390
Car: Jeep Wrangler 4.0L
KLR600
PostPosted: 15:45 - 02 Jun 2014    Post subject: Reply with quote
I'd imagine a chain whip is a chain whip is a chain whip really. I suppose if you wanted to go a bit flashy then you could get a Park Tools one. Once you've got this overtightened cassette off then you would be fine with a cheap one when the lock ring is tightened properly and not by a monkey.
Brand new bikes are really great, I've had a few in my time. I think if I knew I was going to keep a bike for a really long time and I had some money to spend I'd probably go brand new (like with my new jump bike). Second hand stuff is just so cheap though that it's hard to stay away! It seems anything mountain bike related just has no value once it's been used. I've picked up loads of used parts that looked new but were a tenth of the new price. It also helps if you know what was good a few years before as some of the older stuff is still good for most uses.
I used to see a lot of guys on the XC trails with these amazing multi thousand pound bikes and all the latest tech clothing etc and they'd quite often be rubbish riders. It's the same with motorbikes though, plenty of guys out out there on S1000RR's that would struggle to take a Honda CB500 anywhere near it's limits. It doesn't stop me being jealous though Laughing
<Take Cool Photos!>
haroman666
PostPosted: 18:51 - 02 Jun 2014    Post subject: Reply with quote
I believe you're thinking of a "Block". Where the freewheel mechanism is part of the gear cogs and it just screws onto the hub.
A cassette is a set of gear cogs that slot over the freewheel mechanism which is part of the hub in this instance.
el_oso
PostPosted: 10:03 - 04 Jun 2014    Post subject: Reply with quote
I know old/cheap bikes use a freehub that screws onto the wheel.
Just thought cassettes did the same. I've just never had one come loose even when I've forgot to tighten them properly and just used my fingers. If that's not the case then, surely coasting is likely to untighten it.
Duke 390
Fladdem
PostPosted: 17:39 - 04 Jun 2014    Post subject: Reply with quote
I CAN'T DO IT!!! Crying or Very sad Crying or Very sad Crying or Very sad
I have left some diesel soaking into the threads, possibly, at the moment, whether it will make it in I don't know. I cannot apply any more torque, the chain whip feels flexy, I only have a twelve inch adjustable, and nothing bigger with a clean enough jaw to avoid rounding my tool off.
How can I help loosen this lock-ring off?
Fladdem
PostPosted: 21:03 - 04 Jun 2014    Post subject: Reply with quote
DID IT!
I enlisted dad on leaning duty, we couldn't do it.
To the shed of stuff!
Found some old bar that fits snugly over the ends of the tools, he had 18 stone leaning on the spanner with a 12inchish bar hanging off the end, I was leaning 13 on the chain whip with another foot long-ish bar hanging off the end, we bounced it twice, swore a bit, then the crack noise when it breaks loose... the best! Thumbs Up Laughing
Now to find my spacers and chain and have a play.
KLR600
PostPosted: 21:29 - 04 Jun 2014    Post subject: Reply with quote
It does sound like it was overtightened just a tad too much then Laughing Laughing
<Take Cool Photos!>
The last post was made 12 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 112.14 Kb
