| Entertwainer |
 Entertwainer Trackday Trickster
| Lord Percy |
 Lord Percy World Chat Champion
 Posted: 20:47 - 02 Jun 2014 Post subject: Re: a 'pop' and misfire |
| Entertwainer wrote: | twice today this has happened.
both times while accelarating - and a good amount into my commute (so engine nicely warmed up).
give a little throttle to pull away and a misfire and a 'pop'.
is this a dirty carb thing? whats the pop all about? |
Firstly, check that your choke is switched off. If it's an autochoke, check it isn't malfunctioning in some way. If that's all ok, read on.
It could mean your fuel mix is too rich. The misfire would be caused by there being too much fuel with too little oxygen. You would fix it by very gently turning the idle screw on your carburettor by a fraction of a turn (maybe 1/4 of a turn), anticlockwise. This allows a tiny amount more air into the carburettor while the bike is idling, so the fuel-air mix should be at the right level again, hence no problems with it igniting as you pull away.
If you aren't sure where the idle screw is, just google "<your bike model> carburettor" and look for some labelled schematic images.
If the idle screw doesn't fix the problem, remember to turn it back to where it was originally.
The 'pop' sound is presumably a backfire from the exhaust. This would be caused by the excess fuel (which didn't ignite because of the mixture problem) making it straight through the engine to the exhaust, and gathering until it gets a chance to ignite, hence the pop.
Disclaimer: Someone may come along to completely falsify everything I've said. That's all the stuff I'd consider first though. |
| gavbriggs |
 gavbriggs Crazy Courier
| Lord Percy |
| Entertwainer |
| Lord Percy |
The last post was made 11 years, 240 days ago. Instead of replying here, would creating a new thread be more useful? |
