Clutch adjustments
mudcow007
PostPosted: 12:50 - 03 Jun 2014    Post subject: Clutch adjustments Reply with quote
my bike occasionally cuts out when downshifting/ slowing down (when stopping at lights/ junctions etc..)
just found a post on here from yester-year mentioning it could be a badly adjusted clutch
so just checked the barrel adjuster on the bike an its literally wound all the way out Shocked an the bite on the clutch is really far out, (lever is nearly all the way out) but the clutch doesnt feel like its slipping or anything
could the cutting out be a badly adjusted clutch?
stirlinggaz
PostPosted: 16:08 - 03 Jun 2014    Post subject: Reply with quote
hi,
have you tried adjusting it at the other end?
as in, at the engine end. should be able to take up slack from cable (with adjuster on bars set at 1/4 way out)
that will give you back 3/4 of the length of the adjuster, to er......adjust,
cheers,
GAZ
PostPosted: 16:22 - 03 Jun 2014    Post subject: Re: Clutch adjustments Reply with quote
No. It could cause a stalled engine, but you'd know that as it would be dragging the bike forwards and you'd have to hold it on the brakes.
mudcow007
PostPosted: 07:43 - 04 Jun 2014    Post subject: Reply with quote
hmm, i doesnt seem to move forward or anything, will have a tinker tonight
cheers
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 40.68 Kb
