Recommend me a carb balancing kit for a Vara 125
Robster
PostPosted: 11:59 - 04 Jun 2014    Post subject: Recommend me a carb balancing kit for a Vara 125 Reply with quote
Bit new to all this carburettor lark. Mine's running shit again after sticking new plugs and oil in, so reckon carbs need a good clean and balance.
Fingers crossed I got the weekend off and can spend it covered in oil Very Happy
Found this on Ebay:
https://www.ebay.co.uk/itm/UNIVERSAL-MOTORCYCLE-CARB-BALANCER-VACUUM-GAUGE-TOOL-/331219340105?pt=UK_Motorcycle_Parts&hash=item4d1e360b49
But unsure of compatibility with my model?
Tis a 2002 V2 XL125. Recommendations please?
Up the bum no babies.
gavcarter
PostPosted: 12:25 - 04 Jun 2014    Post subject: Reply with quote
It can balance them between each other so they both pull the same vacuum - but as far as I can tell - it cant tell you what that vacuum is.
May or may not be so useful, because in the bike manual there is usually specs for the vacuum strength
E.G the vacuum should be between x and xx mm/hg (what ever it is measured in)
and all carbs should be within xx mm/Hg of each other.
that tool will only enable you to get them same - It wont tell if the vacuum is too high or low.
Something like this is much more user friendly
https://www.ebay.co.uk/itm/CARB-VACUUM-GAUGES-2-Cyl-Synchroniser-Carb-Balancer-/360276994881?pt=UK_Motorcycle_Parts&hash=item53e22eab41
And if it doesnt measure in whats quoted in the manual you can google for a conversion chart...
Edit:
If you want to be really cheap you can use 2 gauges
https://www.ebay.co.uk/itm/Vacuum-Gauge-for-Air-Fuel-Oil-or-Water-40mm-0-30-Hg-0-1-Bar-1-8-BSPT-Bottom-/130956919808?pt=LH_DefaultDomain_3&hash=item1e7da40400
A bit of vacuum hose normal small bore tubing will probably collapse)
and two of these to stop the needles bouncing
https://www.ebay.co.uk/itm/3x-4-6mm-inline-Aquarium-Airline-Connector-Control-Valve-T-style-air-line-regula-/161067807822?pt=UK_Pet_Supplies_Reptiles_Spiders_Insects&hash=item258063b44e
Fasten the gauges to a scrap of wood and have the taps a few inches below the gauges, the rest of the pipe runs down and connects to carbs.
That should keep you out of trouble at the weekend Wink
Robster
PostPosted: 12:40 - 04 Jun 2014    Post subject: Reply with quote
Karma Thumbs Up
Going for the first one you posted. Haven't got much space/tools for a lot of DIY malarkey. Cheers for that!
gavcarter
PostPosted: 12:44 - 04 Jun 2014    Post subject: Reply with quote
have a google about first - was just the first that popped up on ebay, could be cheaper ones about Thumbs Up
mudcow007
PostPosted: 13:26 - 04 Jun 2014    Post subject: Reply with quote
i made my own guages, it literally took about 20mins an cost about £1.50
fishtank airline piping
couple of 3 way unions
a cap full of power steering fluid
https://i25.photobucket.com/albums/c81/mudcow007/20140417_075029_zpse4f2aaf9.jpg
easy peasy an a feeling like your macgyver Mr. Green
gavcarter
PostPosted: 13:37 - 04 Jun 2014    Post subject: Reply with quote
Very similar to the one he original posted in the way it works - absolutely fine for getting them all the same - just sometime you need to know what "the same" is Thumbs Up
gavcarter
PostPosted: 13:46 - 04 Jun 2014    Post subject: Reply with quote
Vincent wrote:
If you get gauges rather than the mercury ones, make sure that they have some sort of baffle fitted....otherwise the needles will jump all over the place and be totally useless Wink
I've never really taken much notice of the readings, just that they're in synch.
Thats what the little taps are for in first gauge i posted Wink
Robster
PostPosted: 16:08 - 04 Jun 2014    Post subject: Reply with quote
Ordered the gauge once Gav posted. Will be dismantling bike on the weekend at a mate's garage.
Engine is very hesitant at low RPM, has a very sooty black rear plug, and to be honest, sounds a bit mullered on the top end. To be expected rom a 125 engine with 58k on though I suppose...
The last post was made 11 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 62.37 Kb
