| JackGarrett94 |
 JackGarrett94 Derestricted Danger
 Posted: 10:48 - 02 Jun 2014 Post subject: Something is making a strange sound, Any ideas? |
Hey everyone, I went on a long ride on sunday with my friend, I done about 90 miles and done about 15 miles of being flat out on my little 125, I was staying between 65mph and 70mph (not bad for a honda xr 125)
On the way back home i heard a clunk and then my bike started to rattle, I pulled over and couldn't find anything wrong with her, I got her home but the whole way there she would rattle when i changed gears mainly from 2nd to 3rd and sometimes 4th, i found out my oil was low so i filled her up when i got back.
I rode her this morning and the rattle dosnt seem as bad it dosnt rattle when change gears to much, I have noticed it rattles on me when i go over a bumb (like a metal hitting something)
Could this be the chain, it is pretty lose, Or have i broke something inside?
Aslo my bike bogs down and dies if i rev it to hard in neutral but she is fine in 2nd gear and up. Strange. Any ideas?
Many thanks |
| Lord Percy |
 Lord Percy World Chat Champion
| mattfender666 |
 mattfender666 Nova Slayer
| JackGarrett94 |
| mattfender666 |
| Carvel |
 Carvel World Chat Champion
| JackGarrett94 |
| mattfender666 |
 Posted: 11:41 - 06 Jun 2014 Post subject: |
| JackGarrett94 wrote: | | mattfender666 wrote: | Where does the clunking /rattling feel like its coming from? |
At first i thought it was coming from the gear shifter, sounded like it was from inside, Im starting to think it is the chain though but I'm still not 100% sure it is the chain.
I tightened the chain up and the chain dosnt touch anything now when i push the chain with my fingers.
But i noticed on the frame where the back wheel is connected (i don't know part names yet) there was oil and the paint had warn away where it looked like the chain had been touching.
Im still getting that strange sounds whenever i go over a bumb and sometimes when i change gears. |
you could run through some checks which might help eliminate some other things.
Wheel bearings: if you can get the big chocked up, shaked the shit out of the wheels, if theres wobble or knocking the bearings are shot.
Sprockets: check the sprockets are all on and securing nuts are tight
Head bearings: With the bike on stands or chocked up, grab the forks and shake just like you did with the wheel bearings, any rock indicates worn steering bearing.
It probably is likely to be something in the engine, as you said in first post you ran the engine on low or no oil, bearings could be scorched or worse. Those checks might not show anything wrong but when your changing gear your disengaging power from the drive and then re-engaging which can sometimes allow you to hear some pretty dodgy crap if things are falling apart.
If no joy, i would next drain the oil and put some nice fresh in, examine old oil carefully for metal filings and other assorted things that shouldnt be in your oil! If still a problem you will probably want to get hold of a service manual or ask on here on what to do next.. |
| devojunior |
 devojunior Brolly Dolly
| Robby |
 Robby Dirty Old Man
The last post was made 11 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
