| hannadarling |
 hannadarling Two Stroke Sniffer
 Posted: 09:53 - 06 Jun 2014 Post subject: replacing Honda CM 125 Conrods with CB125 Conrods? |
Can you replace the CM125 Conrods with the honda CB125 Conrods on the Honda CM125?
Also must it be from the same year of the bike? (1984)
Finding it really hard to find cm 125 parts!
Their either not what I need or overpriced for the condition!
Really appreciate the help and advice
Thanks!  |
| Hokum |
 Hokum Spanner Monkey
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 10:21 - 06 Jun 2014 Post subject: |
I tried to check microfiche for you to see if part numbers matched but crankshafts are sold as complete unit with rods  |
| gavcarter |
 Posted: 10:27 - 06 Jun 2014 Post subject: |
The complete crankshaft unit for a 1982 cm125 also fits the 1985 cm125 plus many later years - not sure if 1984 was different or just followed on....
a CA125 rebel 125 also shares the same part number for the crankshaft unit so rods should be identical - but AGAIN 1984 is not listed - it jumps from 1982 to 1985.....
https://www.mototoro.com/search.aspx?Keyword=13000402702 |
| hannadarling |
 Posted: 10:34 - 06 Jun 2014 Post subject: |
| gavcarter |
 Posted: 10:39 - 06 Jun 2014 Post subject: |
it would be quicker to pull the rods from both engine and compare with a micrometer than read Tef's post, but f**k me the bloke is useful!!!
I enjoy reading his posts to be fair, usually like a mini-book on the subject, very informative  |
| hannadarling |
 Posted: 10:45 - 06 Jun 2014 Post subject: |
My God! This site sells the crankshafts and complete units at a price more then my whole bike cost me!
They must be Joking! £734 my Arse!
And yer I see what you mean by the year skipping, I thought that 1982 to 1984 and even up to 1986 all the parts on the whole bike where the same?
So I get confused when I see a part going and year for it says 1982-3? Does my head in haha
So does it matter about having a part with one year difference? Really?
So I've kinda got two questions rolled into one, both very important in accordance for the engine! |
| gavcarter |
 Posted: 10:51 - 06 Jun 2014 Post subject: |
They actually worked out cheapest for some parts on my bike, other sites are reporting the crankshaft as discontinued or contact for price
In respect to the models using same parts - i Honestly have no clue  |
| Teflon-Mike |
 Posted: 15:05 - 06 Jun 2014 Post subject: |
The cranks are sold as an assembly, because... they is an assembly, and not user serviceable. This is a hint....
And begs the question, why the question? Why do you want to know if CM rods are the same as CB rods....not user serviceable, you probably shouldn't be trying to 'service' them, whether bits of the assembly are the same or not.
How do you expect the answer to help you, or solve your problem..... which one must presume is that the big ends on your CM crank be fucked.
'Fix' as suggested by the parts listings is to get another whole crank assembly....
Getting a crank reconditioned by one of the specialists is approx £300, ISTR.... approx £150 a journal, so double what they would charge to do a pressed up crank on a two-stroke single..... doesn't seem too unreasonable given they have to critically balance and align the pins.
And its NOT a job I would try at home with a vice and a coppa hammer... have seen old boys do old Brits bikes like that.... B-U-T... something of a dark art, and old brit-bikes didn't potentially rev to 14,000 rpm, and still had a big question mark over how long it would be till they cranks shook themselves to bits.... typical shedologist might make one hold together long enough to be nursed to a few classic meets... I wouldn't have much faith in one done by any but a 'master of the art' proving reliable in an every day rider.
And as, for the same price as a pro-recon, I could probably buy two or three complete CB's to 'break'... (or necromance!) I tend to treat CB cranks as disposable assemblies....
What's up with the CB crank? where did it come from? Do you have the rest of the engine it lived in?
My suggested solution is to build up a CB spec motor around a the 'good' CB crank. You'll need the CB cam, to get 180 crank matching valve timing, and you'll need CB ignition to fire 180 sparks; but you'll gain at least 30% more power for the doing of along the way.
If you have CB crank, and the matching bits to build around it from a CB engine, dont really matter which cases you choose to use; and you probably already have most of the bits needed.
If you need to go source another crank? Well, as hinted; these little benleys aren't really in either short supply or commanding premium prices; you might source a good crank assembly from a breaker or e-bay for maybe £100-£150, but you could equally get a whole shed of a bike for that, you could break for the crank...
..if not the whole engine.... and if whole engine was serviceable... need not be a 125 Benley, avoiding the anomoloy of the CB's 180 crank... all the other's are 360', and come in 175, 185, 200 & 234cc displacements; and are pretty much bolt-for-bolt drop in interchangeable.
Which takes us back to your last posts... where you had gear selector problems, and when you pulled the cases apart; motor was pretty much a complete dodo; with knackered selector mech, chipped cogs? (I cant remember) and some disturbing motor-damage, given you had done a complete top end rebuild prior to the shift niggle....
So where are you at? and What are you trying to do? And what's changed since last time? (Like where did that CB crank come from?) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| gavcarter |
| Robby |
 Robby Dirty Old Man
| hannadarling |
 Posted: 12:27 - 07 Jun 2014 Post subject: |
Hm, I thought you could split the crankshaft and just slide off the conrods?
I didnt know that if one thing gets knackered on the crankshaft you have to replace the whole thing.
I have a kind of complete CB engine in the house now with just the rotor cover missing.
Its a seized engine that Ive had for 2 years now, given to me cuz they didnt know what to do with it.
I tried set it up on my cm, but it just wouldnt start with alot of worn and need replacing parts.
So going back to my cm 125 engine, I need to replace the return spring on the gearbox to sort out my gear lever.
I had that piston seize on the conrod that I had to saw off, and the pin that goes through the conrod to secure the piston is stuck on the conrod because the pin expanded from the heat so the pins not going anywhere.
This is why I need another conrod, so you suggest I just get the whole assembly of the crankshaft? Theres one going on ebay but It says 1982-3, hence my other question, can I use a part a different year to my bike? Plus I've asked the guy some questions the other day and though he can submit price offers to me, he wont answer my questions? I've just got another piston set but cant do anything yet because of the conrod.
I have quite an attachment to my cm125, it was my first bike so thats probably why, I've got a cm250 so I can still ride but I dont want to get rid of my cm125 or sell it! I just want to fix it and get it back on the road! It's a weird emotional attachment, maybe because I'm female? aha
Its been re-chromed, repainted, no rust spots, everything on the bike apart from those stated on the engine now works fine because I spent alot of time fixing her up.
Its just the engine, I say its worth it fixing it, Ive spent enough money for the parts why stop now? Its so close to being a normal working bike then a death machine!
Thanks for all the help and advice! but I'm still feeling like I'm in the same spot aha I'm in a bit of a state as you could imagine aha
Thanks guyes, looking forward to your replies!  |
| hannadarling |
 Posted: 22:14 - 07 Jun 2014 Post subject: |
Would it work or fit if I put the cb125 whole crankshaft in the cm125?
And what would I need to change if it did?
I hope someones tested this before or something so I can get a yes or no so I can look more into other ideas?
Thanks  |
| Teflon-Mike |
 Posted: 22:39 - 07 Jun 2014 Post subject: |
| hannadarling wrote: | Would it work or fit if I put the cb125 whole crankshaft in the cm125?
Thanks  |
| Teflon-Mike wrote: | My suggested solution is to build up a CB spec motor around a the 'good' CB crank. You'll need the CB cam, to get 180 crank matching valve timing, and you'll need CB ignition to fire 180 sparks; but you'll gain at least 30% more power for the doing of along the way.
If you have CB crank, and the matching bits to build around it from a CB engine, dont really matter which cases you choose to use |
| hannadarling |
| Teflon-Mike |
 Posted: 10:01 - 08 Jun 2014 Post subject: |
| hannadarling wrote: |  I cant use the cb engine as it is too f**ked.. And I want to keep to my cm125 engine.
So my other idea: so could I put a cm crankshaft in that is a different year to 1984?
I can get the cm crankshaft for £45 but its a 1994, will that fit? If it does I can buy it today, Just need the go ahead aha
Thanks  |
OK, third time lucky.
Yes, you should be able to put the CB crank into 'your' CM crank-cases.
BUT, you would have to build your CM engine up to CB 'spec' using the CB cam and ignition, as the CB crank has one up, one down pistons (Where CM & CD have both up, both down, crank phasing), and the cam is timed to open the valves and the ignition triggered to provide sparks for that crank phasing.
Would mean you would need to use the super-Dream's generator cover and rotor, giving 12v and twin-trigger CDi ignition.
If you dont have the Super-Dream generator, and you want to keep the 'look' of the CM engine, then you may have to go back to 6v electrics and points and source generator from an earlier CB125T
As for the 94 crank; to the best of my knowledge; everything up till 1988 is pretty much swappable between years and models, give or take the crank issue and a few anomalies around the ignition and electrics, vis 6v and 12v and points vs CDI.
From '89, the CB125TD became the TD-J model, and the first major internal changes were made, in so far as the duplex roller cam-chain was changed for a Hi-Vo chain, that has 'teeth' and runs on a mesh form gear, rather than a conventional sprocket.
The crank-sprocket is cast integrally with the middle crank journal, so the cranks for Hi-Vo motors has to be different. (The cam-sprocket bolts on so can be swapped).
I 'Think' that the CM got re-christened the CA, when it got the Hi-Vo engine; but I'm far from 100% sure, and I'm even less sure whether the CA even retained the 360 crank... as we shift into the Jailing chinky-copy era, where there are both 180 and 360 cranked copy engines, and seemingly both Hi-Vo or roller cam-chains.
So, I have no idea whether crank you have found would be of use to you; person who could answer your question is the seller; and the questions you need to ask are:-
a) is it a one up one down, 180 degree crank, or it it a both up, 360 degree crank?
b) whats the cam-chain sprocket? A double sprocket for a roller cam-chain, or a 'gear' for a Hi-Vo one?
If 360 and roller cam-chain, probably good to go. If not might still be useable; but if a 180 crank, then you would need a CB spec cam and ignition; if Hi-Vo, you would need a TD-J cam-chain tensioner, cam-chain and cam-sprocket, or Jailing copy parts. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| hannadarling |
 Posted: 10:58 - 08 Jun 2014 Post subject: |
Would mean you would need to use the super-Dream's generator cover and rotor, giving 12v and twin-trigger CDi ignition. |
Ah I would of been able to do this if I had the super-dreams generator, but sadly, I dont. Though this kind of info is what I'm looking for, brilliant info.
| Teflon-Mike wrote: | If you dont have the Super-Dream generator, and you want to keep the 'look' of the CM engine, then you may have to go back to 6v electrics and points and source generator from an earlier CB125T |
Aha saying that, I've been searching for the engine or complete bike for a decent price on every popular site everyday, I was going to do a straight swap, but nothing's turning up and theres just no luck.. Thats why I've started to think further and just replace the parts as this would be quicker.
I dont really want to change to 6 volt and liking the sound of that, I'm gonna try to avoid this aha
| Teflon-Mike wrote: | As for the 94 crank; to the best of my knowledge; everything up till 1988 is pretty much swappable between years and models, give or take the crank issue and a few anomalies around the ignition and electrics, vis 6v and 12v and points vs CDI. |
Thank you, my question has been answered! I didnt really have a clue so I didnt want to just swap the part round and then find out it doesnt fit or work and Now I know I can use parts up to 1988 intstead of the seemingly rare 1984, Brilliant
| Teflon-Mike wrote: | So, I have no idea whether crank you have found would be of use to you; person who could answer your question is the seller; and the questions you need to ask are:-
b) whats the cam-chain sprocket? A double sprocket for a roller cam-chain, or a 'gear' for a Hi-Vo one? |
Ive just asked these questions so am now waiting a reply, judging from the picture it looks to be both up, I'll upload the pic on here, Ive also asked for more pics as something looks bent at the back? Not quite sure though?
| Teflon-Mike wrote: | If 360 and roller cam-chain, probably good to go. If not might still be useable; but if a 180 crank, then you would need a CB spec cam and ignition; if Hi-Vo, you would need a TD-J cam-chain tensioner, cam-chain and cam-sprocket, or Jailing copy parts. |
Ive got my fingers crossed the guy answers with the one I need! Thank you for answering all my questions, this info Has helped me alot with my forever problems on my engine!
Once Ive replaced the return spring for the gearbox, replace the crankshaft, fit the piston and put the engine back on the bike it should start! And with no problems (I hope.)
Thanks Teflon-Mike for the much needed help! definitely 3rd time lucky getting it through to me  |
| hannadarling |
| Teflon-Mike |
 Posted: 16:54 - 08 Jun 2014 Post subject: |
Cant see the cam sprocket, but looks to have the cam-chain attached, and it appears to be a Hi-Vo chain.
If it comes with the Hi-Vo chain and you can get them to supply, or can source separately, the corresponding cam-sprocket.... and possibly the cam-chain tensioner blades and mech.. then could be useable....it would appear to be a 360 crank. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| bypass2 |
 bypass2 Spanner Monkey
| hannadarling |
| hannadarling |
| hannadarling |
 Posted: 10:26 - 09 Jun 2014 Post subject: |
Morning people,
Theyve replied and confirmed its a 360 crank and hi-vo, I'm gonna have to ask them if they can supply or source the corresponding cam-sprocket and the cam-chain tensioner blades and mech. And then swap all that over, so more work for me
So if this had the roller cam-chain it would be good to go, if only it was that simple.
Ive decided I'm gonna keep searching, now I'm more aware of what kind of crankshaft I'm looking for, and if I'm lucky enough, maybe an engine might come out of it for my patience
Thanks for the help and if anyone has this engine for sale or knows anyone who does I'm interested haha As long as its working unless given all details about it
Thanks for answering my questions Tef.
Thanks everyone else |
| hannadarling |
 Posted: 16:48 - 10 Jun 2014 Post subject: |
I am so glad I didn't buy the crankshaft in the end as I have found and bought a Honda cm 125 with a great working engine for £160!! Just because the guy had loads of projects to do and needs the spare cash I guess. Theres afew bits missing on the bike but who cares? I got an engine with spare parts  |
The last post was made 11 years, 241 days ago. Instead of replying here, would creating a new thread be more useful? |
