| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
 Posted: 17:58 - 07 Jun 2014 Post subject: Kmx problems |
Evening all, i have a couple of troubles just got my engine back from being rebuilt (supposed business & trained mechanic). from the outside all together looked great compression was unbelivably high and looked half decent but noticed in his own clutch cover which he sprayed it has a slit in the metal sitting behind window rather than no metal and clear view of whole window having bits of white paint showing i thought it couldnt be any good in the gearbox oil so delicately took the clutch cover off saving the gasket(hoping its fine to re use) the clutch cover was dirty to say the least and on inspection the clutch cover power valve actuator bearing is gritty & engine bearing for the pva is also similar. The powervalves are quite stiff on push/pull movement after its rebore i had a .5mm oversize piston thats fitted so guessing .5 oversized bore would this make any kind of difference or the steel filings may still be there possibly? He assured me that mains and seals were done but im not 100% as the gear shift drum screw was rounded which i supplied new screw and asked him change its still rounded and that has to be undone to split the cases? In picture im not sure if kick mechanism is inserted right with spring slightly crooked & the inlet manifold\oil intake jet was resin'd in as was sliding out of the rubber. Can anyone shed any light please  |
| bladerunner |
 Posted: 16:44 - 08 Jun 2014 Post subject: .. |
Thanks for the reply & sorry about pictures . Thats whats baffling me if he has replaced the mains like i said how has he got the screw back in and tight other than heating it possibly? The kickstart spring is under tension as it should be just seemed jump out its slot when kick lever was pushed all the way down in its momentum. I didnt rebuild it as didnt have case seperator and didnt want cause damage. He gave me two bearings back which seem be used & not the brand new ones i gave him but i dont trust anybody. The clutch cover was oven baked to replace the mechanical seal, back up seal and bearings which has been done, then sprayed in black but seems he did it with oil filler cap off and abit got inside should i worry about this? How come the clutch cover has the slit in window rather than other one on last picture i added to this any ideas?. And it already had a steel liner fitted just got him do a rebore which seems to be done well looking through the exhaust port |
| bladerunner |
| stevo as b4 |
 Posted: 17:38 - 09 Jun 2014 Post subject: |
Was this a professional re-build by a well known firm, or a mate/mechanic friend doing you a favour etc?
I agreed with bladerunner that the pics were hard to make out, but also that if you want something done properly and to a high standard, you need to either employ someone you trust/has a very good reputation. (usually expensive).
Or you supervise the work going on and watch, or simply you do it all yourself.
I've known people have re-bores and crank re-grinds done, and the dimensions the machine shop have worked to are either wrong for the shells/Pistons etc or they have caused damage to something else doing the work. Many people have re-built engines straight from the machine shop, to find they either smoke, knock or go bang, because they have not checked the clearances after machining before re-building it all etc.
You might as well sort your clutch cover out, and then try the motor out in the bike and see how it goes. You have no idea of if it's a good or bad re-build other than by trying it really.
Don't go back complaining saying you took 1/2 the motor apart to check his workmanship, and that you didn't trust him, as it won't get you anywhere, and he could blame any problems on your work and not his. |
The last post was made 11 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
