| staningrimsby |
 staningrimsby Renault 5 Driver
| duhawkz |
 duhawkz World Chat Champion
| staningrimsby |
| staningrimsby |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:52 - 08 Jun 2014 Post subject: |
How on earth can a valve clearance check require 15-20 hours of labour? You could replace a valve for less than that, so if that's genuinely what is being asked, I'd laugh it off and ride until something goes wrong. You could, quite literally, buy a bike for that money.
Compromise: rather than taking it apart, you could get a compression test done. If that's OK then the valves are closing. ____________________ Biking is 1/20th as dangerous as horse riding.
| staningrimsby |
| Vincent |
 Vincent Banned
 Posted: 20:29 - 08 Jun 2014 Post subject: Re: Honda VFR 800 |
| staningrimsby wrote: |
What I would really like to know is does anyone know if there is anything specific I should look for on these bikes, are they reliable or does anyone have any experience with them good or bad ???
Cheers in advance,
Stan. |
3 Things:-
1; Electrics
2; Electrics
3; You guessed it; ELECTRICS
Esp pre VTEC. Duff Common Earth blocks, dodgy charging system, poorly protected connector blocks, skinny wires, corroded clock PCBs etc. All the problems are known about so the info is online.
VTECs can be a bit pricey when it's valve clearance time so look for one that's at least been checked recently. EDIT; Ah, I see valves have been mentioned already
Oh, and try and get one with a stainless exhaust, if it hasn't had one fitted, it'll need one soon
Loads of used parts around and some very nice examples when it comes to the bikes.
The V4 comes into it's own at higher revs and, to me, feels a bit agricultural lower down....plenty of clutch work needed around town but a real revmeister on the open roads
'Buy mine if you like  ____________________ Space Is Deep |
| Rogerborg |
 Rogerborg nimbA
| Vincent |
 Vincent Banned
 Posted: 21:04 - 08 Jun 2014 Post subject: Re: Honda VFR 800 |
| instigator |
 instigator Super Spammer
| Shaft |
 Shaft World Chat Champion
 Posted: 22:05 - 08 Jun 2014 Post subject: |
| Rogerborg wrote: | How on earth can a valve clearance check require 15-20 hours of labour?
Seems it's not all labour, from what I've read, it's about 3 hours to check them, another 5 hours if they need adjusting, then there's the parts; looks like an absolute sod of a job.
On the other hand, anecdotal evidence suggests they rarely need adjusting before 50K, often not even then, so I guess you can pray to the god of shims and keep your eye on the price of good used engines. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:51 - 08 Jun 2014 Post subject: |
Mmm. My analysis with the GS was that BMW Motorrad wanted £200 for a service with "valve check", but they wouldn't even discuss how much an "adjustment" would be, because "it depends".
On further investigation, that particular cower of shunts had never had a bike in that didn't "need" some amount of "adjustment", so in the event I fucked it off and decided to gamble that the chimps who made the engine did a better job than the monkeys who get to work on it.
Hang on, I'll be back in 5 minutes after I've done the clearances on the Enfield, and got another beer. ____________________ Biking is 1/20th as dangerous as horse riding.
| Shaft |
 Posted: 23:06 - 08 Jun 2014 Post subject: |
You need to try and find a tech with a conscience.
When I was seriously considering a GS boxer, I happened upon a guy called Chris Harris on Youtube; he's a BMW trained tech and tells it like it is, eg if you've been charged for a valve clearance adjustment on a 16V K bike with sensible mileage, you've probably been ripped off.
In the OP's case, a time served Honda tech who is now doing his own thing the right way, would be most useful. ____________________ Things get better with age; I'm close to being magnificent........
| Dibble |
 Dibble Scooby Slapper
| J biker |
 J biker Nova Slayer
| Dibble |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:02 - 09 Jun 2014 Post subject: |
| Shaft wrote: | In the OP's case, a time served Honda tech who is now doing his own thing the right way, would be most useful. |
The suggestion to just do a compression check came from just such a chap, in reference to a workmate's CBR600RR. He (reportedly) said he'd never worked on a modern Honda where the clearances had actually needed adjusted.
2nd hand anecdote, I hasten to add, I'm not making that claim. ____________________ Biking is 1/20th as dangerous as horse riding.
| staningrimsby |
| Busa1340R |
 Busa1340R Nova Slayer
 Posted: 09:53 - 09 Jun 2014 Post subject: |
Not trying to put you off......I loved my 07 Sprint, however if you intend to ride at night, be warned that the (pre facelift) Sprints headlights are abysmal. The main beam switch effectively does nothing....it's like turning on a small torch with flat batteries.HID kits apparently improve greatly if you want to spend the money/can be bothered.
Something else you may want to consider is resale value. I had no interest when it came to selling mine on, even though it was immaculate with low miles and FSH and sensibly priced. Even dealers weren't really keen on PX. Buying one with pannier kit will help even if YOU don't intend to use it. ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
| staningrimsby |
 Posted: 10:06 - 09 Jun 2014 Post subject: |
Thanks for the info I was looking for something around 2005 I believe they changed around then, I will also want panniers etc as I plan on a bit of touring with the missus as well.
Ideally I would love the Honda Pan European 1300 ST but its a little bit out of my price range . ____________________ When you have removed the impossible the improbable however unlikely has to be the truth.
1986 Yamaha DT 80 >> 2009 Honda Varadero XL 125 >> 2003 Suzuki V-Strom 1000 |
| Busa1340R |
| staningrimsby |
| map |
 map Mr Calendar
The last post was made 12 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
