| i.p.phrealy |
 i.p.phrealy World Chat Champion
 Posted: 17:55 - 08 Jun 2014 Post subject: blown head gasket (probably) |
So... bimbling along on my Honda VT500, heading back to Mrs Phrealy's (pending) house via the M42 we were about 2 miles from the exit and as I was overtaking a lorry I lost all power and noticed quite a lot of blue/white smoke in my mirrors.
cue, pulling onto the hard shoulder for a quick look and noticed that there was oil seeping out of the side of the engine, just below the head.
my phone died at this point so no photos but it's pretty obvious the head gasket has gone.
so I have made a mental note of what I need to get to sort it out, have I missed anything:
gasket set.
fresh oil and filter,
fresh antifreeze.
my tools!
is it worth checking with a compression tester to be sure before I start ripping the head of?
anything else I have missed?
any advice or tips on swapping a v-twins head gasket gratefully received.  ____________________ it is impossible to lick your own elbow...
Finally allowed a big bike 19/03/14! |
| moonzoomer |
 moonzoomer World Chat Champion
 Posted: 18:24 - 08 Jun 2014 Post subject: |
Check the radiator and header tank for oil contamination to confirm a blown head gasket which I doubt is the problem, I suspect you have a ruptured broken oil feed pipe, the oil feed pipe on the VT travels from the left hand side of the crankcase running between the pair of cylinders before splitting into two to supply the cylinder heads so check for rot on the pipes or a broken damaged union before going the cylinder head route.
Have a look around the two banjo bolt connections inside the V of the engine as well as looking for damage to the oil feed pipes themselves, see pic....
https://i1142.photobucket.com/albums/n604/mawlarky/oilpipe_zpsd4ddcb52.jpg
| Pete. |
 Pete. Super Spammer
 Posted: 18:35 - 08 Jun 2014 Post subject: |
Since it lost power under load I'd be hoping it's the head gasket. If it lost power due to losing oil pressure from a ruptured line the damage will be much more expensive to fix. ____________________ a.k.a 'Geri'
| i.p.phrealy |
| moonzoomer |
| Boxing |
 Boxing World Chat Champion
 Posted: 20:18 - 08 Jun 2014 Post subject: |
Has it been getting through a lot of coolant lately? If so it probably is your head gasket. I check my coolant before every ride. Along with chain, tyres and bolts.  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:33 - 08 Jun 2014 Post subject: |
I seem to recall it had no coolant in it when he got it.
Cylinder-Rebores / RM Motorcycles Tenlon's Road.
If it is HGF and sounds likely... best to get the head skimmed as course.
If it was run for however long without coolant, it's been 'going' for a while, and it wont just be the gasket getting old and tired and letting go, it'll be thermal expansion 'creep' in the metal warping the head.
Do you need any help?
Have you compression tested it to confirm?
We have compression testers here, if needs.
Check Haynes, dont know if those have stretch studs that have to be replaced with the gasket; but it is the era Honda were very keen on thin-wall die-pressure casting which is very sensitive to correct torque settings and sequences to avoid flex fractures.
Not going to Bassets tomoroow night then, I take it  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| i.p.phrealy |
 Posted: 20:50 - 08 Jun 2014 Post subject: |
Moonzoomer, I'll have a look at the pipework when I go and look at the bike (currently in the inlaws garage), but it was forcing oil out of this point of the engine casing:
https://i1276.photobucket.com/albums/y475/i_p_phrealy/MVC-260S_zpse54991c02_zps2212fe32.jpg
yep it was low on coolant when I bought it, I topped it up and it had been fine.
looking like i'll be scouring ebay for a replacement engine then. ____________________ it is impossible to lick your own elbow...
| i.p.phrealy |
 Posted: 20:52 - 08 Jun 2014 Post subject: |
No Tef, no Bassetts for a bit now.
Bike is in Curdworth. ____________________ it is impossible to lick your own elbow...
| moonzoomer |
 Posted: 20:57 - 08 Jun 2014 Post subject: |
Engines do turn up from time to time, failing that a 650ntv or 600 revere will fit if push comes to shove, where you at as I have 2 spare engines from crash damaged bikes going spare? The area you have indicated as the leak is the rear cylinder and is certainly in the head gasket area though the oil feed in also in the same area |
| i.p.phrealy |
| moonzoomer |
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
