| pastymuncher |
 pastymuncher Derestricted Danger
 Posted: 11:10 - 09 Jun 2014 Post subject: Hartford legion 125 |
Hi guys, new to the forum
I've recently purchased a cheap bike for getting about, a Hartford Legion.
It does have a couple of issues which I could do with some help fixing. I am not the most technically minded soul, in fact you could say I am a bit ham fisted, however funds are tight so need to give it a go.
1. leaking oil from the magneto cover - I'm guessing this is from the gasket. I was given a replacement gasket with the bike (Suzuki GN gasket) and it didn't fit. Not even close. Since there is not many (any?) Hartford dealers, which gasket should I get? I've been told they are CG engines, so would a CG gasket be correct?
2. I'm leaking petrol somewhere. it seems to be coming from the carb. I suspect that it is something simple like pipework plumbing. I have a pipe that comes from the bottom of the carb that goes nowhere and an inlet at the top that has nothing connected. Again, is it a CG based engine and Carb and would it be worth getting hold of the CG manual from the library? Or can anyone post a diagram of how the carb should be plumbed in.
(It can't be far out because it does start and run, but over the course of a few days, all the petrol in the tank drains out)
3. When I have had it running, the neutral light stays on permanently, regardless of what gear it is in. Any ideas? Again would a CG manual help? (Library doesn't list stocking the chinese manual)
Sorry that my first post seems to be asking for help.
Also I see from browsing the forums that 1 or 2 of you have had these bikes before. what are they like in general? In the past I've had a Sym Wolf and a couple of Yamaha SR's (which I found to be a bit gutless)
Thanks for now
pastymuncher |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:19 - 09 Jun 2014 Post subject: |
Yup, that looks like another of the GN/SR/CM copybikes.
The engine does appear to be a 156FMI or 157FMI CG copy engine. They're all much the same.
This CG125 site is a decent resource, or a Haynes for the CG should suffice for the engine.
The pipe at the bottom of the carb is a drain hose. There will be a screw above it to drain the fuel out of the float bowl.
Petrol leaks can be a sod to find because it evaporates quickly. I'd go with cleaning everything up and then dousing the area in talc to try and localise it.
First though I'd give the float bowl a good smack to see if it's just a sticky float.
Neutral light, I'd remove the bulb.  ____________________ Biking is 1/20th as dangerous as horse riding.
| pastymuncher |
| pastymuncher |
| Efes123 |
 Efes123 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| pastymuncher |
The last post was made 11 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
