Creaky/sticking front brake lever & leaky fork seal
TallPaul_S
PostPosted: 11:23 - 11 Jun 2014    Post subject: Creaky/sticking front brake lever & leaky fork seal Reply with quote
Got a couple of issues on my honda at the moment, the primary one is the front brake master cylinder seems to be sticking, normally its been in the extreme end of the range of movement when applying the brake, and a couple of full pumps would get it moving nice and freely. This morning however, it's stated creaking/juddering/sticking right from the initial bike, which has made the brake very grabby. It's not the caliper as I can feel and hear it at the lever end.
Apart from a rebuild, anything else I can do to sort this? I'll try and remove the lever and the weather seal on the end of the piston tonight an lube/grease it, see if that improves things.
2nd issue is my right fork leg seal is leaking oil - I cleaned it inside the seal a couple weeks ago, reseated it by pumping the fork until the upper leg was dry. Started leaking again, reseated it last night and it was dry when pumping the fork. If it starts to leak again, what's the best way to make sure the seal is seated? The seals are only a few months old and are tight as hell (tried to use a seal mate and could not insert it, no chance) so it might be a piece of dirt in the seal. Unless it's leaking from the outer side (inside of the outer fork leg)?
00 Honda VFR800 | 09 Aprilia Tuono Factory
CBT 06/03/2014 | Mod 1 and Mod 2 passed 15/10/2014
Mez
PostPosted: 11:59 - 11 Jun 2014    Post subject: Reply with quote
In my experience, leaky seals are leaky seals and need redoing. It may have gotten nicked on installation. Front brake lever, just take out and give the pivot area a good clean.
My deviantArt gallery - My Youtube profile
Honda CG125 -> Baotian BT49 -> AJS JS125 -> Honda CG125-> Kawasaki ZL400 -> Kawasaki GPZ500
TallPaul_S
PostPosted: 18:18 - 11 Jun 2014    Post subject: Reply with quote
I'll keep an eye on the seals, it was fine the first few weeks, just been the last couple that it's stated leaking.
Took off the brake lever, gave the pivot a good greasing, and it's now as smooth as anything, 5 minute job. Thumbs Up amazing how much the pivot can dry out in this weather.
PostPosted: 18:47 - 11 Jun 2014    Post subject: Re: Creaky/sticking front brake lever & leaky fork seal Reply with quote
TallPaul_S wrote:
seal mate
You mean, a thin piece of plastic cut from a coke bottle or similar, costing nothing but 30 seconds of time?
TallPaul_S
PostPosted: 19:10 - 11 Jun 2014    Post subject: Re: Creaky/sticking front brake lever & leaky fork seal Reply with quote
Rogerborg wrote:
TallPaul_S wrote:
seal mate
Yep, that's it Wink Only the coke bottle is too thick - too thin and it's not stiff even to insert, and if it's stiff enough it's too thick! Confused
Mez
PostPosted: 11:35 - 12 Jun 2014    Post subject: Reply with quote
Hah. I didn't know people jabbed their seals with slivers of sharp plastic to establish if/why they're leaking.
Mez
PostPosted: 13:58 - 12 Jun 2014    Post subject: Reply with quote
Vincent wrote:
I think the idea is to clear out any crud that's sitting between the seal and fork. Anything there will cause the oil to capilarise and leak.
I gathered. What peculiar logic.
Itchy
PostPosted: 14:22 - 12 Jun 2014    Post subject: Reply with quote
I have often found that cheap brake levers which do not have some sort of sleeve inside the lever pivot will tend to warp.
So they are a 0 shape rather than an o shape.
The last post was made 11 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 69.68 Kb
