Header clamps seized - replacing exhaust
Ilyin
PostPosted: 12:20 - 12 Jun 2014    Post subject: Header clamps seized - replacing exhaust Reply with quote
Hi all,
I'm trying too replace both pipes on a GSX600F 1997, there's 4 downpipes, but the bolts that hold the header clamps aren't budging. They're so tight that the allen keys are bending as I'm trying to turn them.
I've removed all of the plastic, and the fuel tank, and was thinking of putting a hot air gun on them to see if it helps.
I just though I'd check with you guys first in case it's a bad idea, or they're's a better method.
Thanks.
SQL
PostPosted: 12:24 - 12 Jun 2014    Post subject: Reply with quote
heat or impact driver
Itchy
PostPosted: 12:25 - 12 Jun 2014    Post subject: Reply with quote
You mean the nuts on the studs?
If the studs are in good condition, then simply cut the nuts off with a dremel tool.
Because undoing them applies lots of force to them, which can mean snapped studs, snapped studs means PITA trying to get them out or drilling them out.
Ilyin
PostPosted: 12:43 - 12 Jun 2014    Post subject: Reply with quote
There is no studding, they're just plain allen-bolts holding them in place unfortunately Sad
Ilyin
PostPosted: 12:44 - 12 Jun 2014    Post subject: Reply with quote
Vincent wrote:
I'd soak with PlusGas for 48 hours then try a decent allen key with an extension bar. Or....use a socket with allen tip.
I've sprayed some PlusGas on, how often do I need to reapply it?
Bezzer
PostPosted: 13:49 - 12 Jun 2014    Post subject: Reply with quote
They're the same as Bandit ones, the time honoured method on them when they are rounding off or just too tight is plenty of Plus Gas some localised heat then bang a 12mm multipoint socket over the bolt head which fits the M8 allen head very snugly. The socket edges dig into the bolt head, the banging helps to loosen as well then use a socket ratchet to unscrew them. Take your time if they move then tighten again just work it back and forth.
Ilyin
PostPosted: 14:05 - 12 Jun 2014    Post subject: Reply with quote
Bezzer wrote:
bang a 12mm multipoint socket over the bolt head which fits the M8 allen head very snugly. The socket edges dig into the bolt head.
Do you mean a normal 12mm socket (like you'd get in a socket set), but the ones with the 12 straight edges instead of 6?
davebike
PostPosted: 14:11 - 12 Jun 2014    Post subject: Reply with quote
There M8 allen bolts (that is a 6mm allen key)
LOTS penetrating oil + heat repeat and repeat again
DON'T brake them
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Islander
PostPosted: 14:17 - 12 Jun 2014    Post subject: Reply with quote
Another thing worth a try is a freeze spray applied to the bolt head. I've had some success with Loctite Freeze n' Release - it's how I got the final header undone on the Hornet. Thumbs Up
Bezzer
PostPosted: 14:35 - 12 Jun 2014    Post subject: Reply with quote
Yep 12= multipoint Thumbs Up
Ilyin
PostPosted: 17:55 - 13 Jun 2014    Post subject: Reply with quote
Thanks so much all.
PlusGas and impact driver was enough for seven of the allen-bolts, the 12mm multipoint was needed for the last one.
Thanks again, I really appreciate it.
The last post was made 11 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 78.53 Kb
