Starting up my VFR after a long time.
EDBANGER
PostPosted: 14:53 - 12 Jun 2014    Post subject: Starting up my VFR after a long time. Reply with quote
So in September some woman smashed my bike and it was written off Cat C. For one reason or another I've not got round to doing anything with it since then so today I decided to try and start it up. I took the battery off in September and have kept it in the house. I charged it today (although I must confess my patience only got as far as half charged). Stuck it on the bike and all the electrics worked but I got absolutley nothing from the ignition switch. No even a clicking or faint hint of "I might have started on a full battery". Is it simply a case of charging the battery to it's fullest or is there likely to be another issue??
Before anyone suggests it. I did check the kill switch.
If you can't spot the sucker in your first half hour at the table, you are the sucker.
PostPosted: 16:09 - 12 Jun 2014    Post subject: Reply with quote
They can suffer from a sticky solenoid. Try shorting between the poles on the solenoid with a bit of metal. The starter motor should turn if there is enough juice to turn it.
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 15 - Page Size: 31.94 Kb
