Welding Alu frame?
kramdra
PostPosted: 05:45 - 08 Jun 2014    Post subject: Welding Alu frame? Reply with quote
Last June I had a minor spill from 30mph and the bike slid on its left side. I did not have side fairings fitted so the frame was exposed an received some scratches and a minor dent One of the scratches was deep and appeared that it might be a tiny crack, this now seems to have spread, so I need to repair asap as I need the bike everyday.
Green-red dots are the crack
https://i1133.photobucket.com/albums/m593/Kramdra/Cbr600/2IMG_20140608_001201_zps0e2eebc8.jpg
I believe the crack should be repairable by TiG welding but the big question is preferably without stripping engine or too much from the frame. Anyone have experience?
thestew
PostPosted: 08:08 - 08 Jun 2014    Post subject: Reply with quote
If you are not sure whether it is a crack or not, I would Sagest getting a die penetrant kit, no point welding it if there's not even a crack. Tig would also be the process of choice.
lihp
PostPosted: 12:15 - 08 Jun 2014    Post subject: Reply with quote
A lot of the frame finish will need to be ground off, as the frame will be andonised and not bare aluminium.
So when the weld repair is done, You will need to get the frame refinished somewhere.
kramdra
PostPosted: 11:07 - 11 Jun 2014    Post subject: Reply with quote
Frame is painted rather than anodised but I dont care too much for cosmetics Embarassed.
Ive found somone who builds and races cars who said he should be able to do the job in a couple weeks when less busy. It seems I will only need to remove the fuel tank and protect/remove the loom, hopefully I can ride in and ride away same day.
davebike
PostPosted: 11:28 - 11 Jun 2014    Post subject: Reply with quote
I TIG weld that looks easy enough to weld
You will need to remove anything the heat can effect form nearby
A fair bit of paint will need to be removed
A fairly simple weld
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
kramdra
PostPosted: 12:39 - 11 Jun 2014    Post subject: Reply with quote
Great. How would you go about the repair? TIG along the crack, or perhaps cut it out with a burr and a plate over the top?
The only things to be removed seem to be fuel tank and the main loom which runs along side the frame. Plus ECU, reg and battery as is normal for any welding
Found this interesting read about Honda frame design, appears it will be a 7xxx alloy. https://210.101.116.115/fisita/pdf/G359.pdf
davebike
PostPosted: 12:48 - 11 Jun 2014    Post subject: Reply with quote
Without being able to actually look at the damage it is difficult to say
It might be a simple v notch and run a weld
It might just be a simple matter of running a weld
Take it to your local welder who has TIG and get his ideas
Dave
Dave
davebike1@gmail.com
kramdra
PostPosted: 00:18 - 14 Jun 2014    Post subject: Reply with quote
https://i1133.photobucket.com/albums/m593/Kramdra/Cbr600/IMG_20140613_161018_zps6908e304.jpg
Cleaned it up a bit.
Fisty
PostPosted: 06:22 - 14 Jun 2014    Post subject: Reply with quote
Personally, I would get another frame.
Fatter and faster than Fret
c_dug
PostPosted: 07:20 - 14 Jun 2014    Post subject: Reply with quote
I agree with fisty, even if you weld the possible crack up, it still looks like it's lost a lot of material to the road, wouldn't want it to buckle under stress from hitting a pothole or something.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Hetzer
PostPosted: 09:22 - 14 Jun 2014    Post subject: Reply with quote
It's a bit like "tap your helmet and in a subsequent crash your head will explode" BS.
The crack in the frame will get worse if not welded but once welded it'll be perfectly safe. Even if fully stressed with balls-out track usage I'd be staggered if it failed. How would it fail? The entire beam would shear apart? Or what? Even if it did it would be unlikely to cause the bike to crash (maybe in a high-speed knees-down corner scenario).
Too much bollocks talked about this kind of thing. B17s made it back to base after being shot to shit by 20mm and 30mm cannon. Composite structures can take a hell of a beating and keep rolling.
tl/dr get it welded.
hmmmnz
PostPosted: 09:54 - 14 Jun 2014    Post subject: Reply with quote
im with hetzer on this,
once welded it'll be as strong as it ever was
i would drill a hole at each end of the crack to stop it spreading, and weld it up
may be keep an eye out for a cheap frame in the future if you ever want to sell the bike, a big weld on the frame, while safe as houses would put people off buying it
the humans are dead
I kick arse for the lord
The last post was made 11 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 82.63 Kb
