Carb needle pic
Dave M
PostPosted: 08:46 - 15 Jun 2014    Post subject: Carb needle pic Reply with quote
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/8F43733A-B590-492A-A493-D9DBFE722798.jpg
Could this have been cuasing the fuel going into oil?
orac
PostPosted: 09:01 - 15 Jun 2014    Post subject: Reply with quote
a litte more context would be helpful too, what bike, is it gravity fed carbs.
over filling may cause fuel to leak down the intake and seep around the rings into the sump oil if the needle didnt seat correctly
Dave M
PostPosted: 09:32 - 15 Jun 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=291168
Hope this helps.
orac
PostPosted: 09:41 - 15 Jun 2014    Post subject: Reply with quote
this wont be very helpful, but i did find your problem
Hyosung gt125
the chances of needles being the primary issue is very slim, clean with some carb cleaner and reiinstal.
have you checked the vacuum pump, ie is shutting off. if it shuts off when the bike is off, you will need to attacth the carb to the fuel feed and position as though they were on the cylinder (but not on the cylinders, pull vaccum (suck on the pipes from intake rubbers), it will take a while for the carbs to fill (once you have a vacuum on the pipe, stick your tonk over the wholes, it make it alot easier to breath), once they are full, they will start to over flow if there is an issue
mudcow007
PostPosted: 09:42 - 15 Jun 2014    Post subject: Reply with quote
basically look at the rubbery end of the valve, if it has lines/ grooves in it, its worn
mine were about £6 offa ebay
Robby
Dirty Old Man
PostPosted: 09:50 - 15 Jun 2014    Post subject: Reply with quote
The only way to tell is to replace it, usually along with its seat. You will need to check/adjust the float height afterwards - sometimes aftermarket ones are a slightly different length, which will screw up the float height.
Dave M
PostPosted: 20:05 - 15 Jun 2014    Post subject: Reply with quote
Valves have no lines/grooves so they seem ok.
Float height is a bit of a grey area. The service manual says 17mm BUT it has been said on numerous occasions that this was a misprint? It says 17mm on 2 different sections in the manual? Can they be wrong twice? No one seems to know the proper height if the height in the manual is actually wrong. Does 17mm sound about right?
I will be checking the pump tomorrow. Carbs have 82.5 main jets in both. Supposed to be an 87.5 in front and a 90 in rear. I was thinking maybe I could use a clamp on the fuel line when the bike is stood to see if that could stop any fuel going to carbs as a temp. measure. Thoughts on this please? Thanks for help and patience!
temeluchus
PostPosted: 22:56 - 15 Jun 2014    Post subject: Reply with quote
Would it be possible to get a decent pic of the needle?
Dave M
PostPosted: 12:10 - 16 Jun 2014    Post subject: Reply with quote
https://i1214.photobucket.com/albums/cc487/weedave1/Mobile%20Uploads/13663577-FC48-418D-89BB-A58BAC94958E.jpg
That any good?
davebike
PostPosted: 13:40 - 16 Jun 2014    Post subject: Reply with quote
If the tip is a discoloured as it looks in that picture it is knackered !
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Dave M
PostPosted: 14:34 - 16 Jun 2014    Post subject: Reply with quote
Hi Dave,
It was green gunk and it came off easily with a good soak in carb cleaner. Looks like new! Is it likely to keep happening? Cheers.
davebike
PostPosted: 14:37 - 16 Jun 2014    Post subject: Reply with quote
The rubber "tip" has been damaged by old fuel Common problem lots of do this it will fix it stories but unless time no problem just replace the needle
Drain carbs if bike is to stand fro more than a couple of weeks
Dave
davebike1@gmail.com
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 78.4 Kb
