XT125 electrical fault
jameswood
PostPosted: 18:18 - 14 Jun 2014    Post subject: XT125 electrical fault Reply with quote
Crashed a little while ago and have fucked my display up but i understand this to be a common fault with them. Took it to the mechanics to get it looked at as the indicators wouldn't work and it would cut out and such. A fuse was changed (ECU turned out to be fine) and we concluded that a new display was needed.
Not got round to buying one yet as they are a pain to get hold of, i contacted the manufacturer earlier to see if they supply privately.
recently the indicators became a bit dicky again and what few lights that work on the display are even more erratic. the indicators flash at a rate directly proportional to the engine rpm until about 4000rpm where they just do jack all.
i have had the dispaly apart to find a lot of water in there, dried it out as best i could without leaving over night.
My question is will the display being ballsed affect the indicators or is the information sent to the indicators separate to the display and there is another electrical fault somewhere?
thanks in advanced!
gavcarter
PostPosted: 18:29 - 14 Jun 2014    Post subject: Re: XT125 electrical fault Reply with quote
i have had the display apart to find a lot of water in there, dried it out as best i could without leaving over night.
thanks in advanced!
not familiar with the electrics on these bikes, but unplug the display all together. I doubt the bike relies on the display to run normally and if it is shorting something out, it wont once its unplugged. If that doesn't work look at the flasher relay itself.
I amuse you havn't upgraded to led indicators or something recently.
jameswood
PostPosted: 19:47 - 14 Jun 2014    Post subject: Reply with quote
thats a good idea, hadnt though of that!
jameswood
PostPosted: 11:20 - 15 Jun 2014    Post subject: Reply with quote
display off, indicators still dicky. New relay?
gavcarter
PostPosted: 11:31 - 15 Jun 2014    Post subject: Reply with quote
If all bulbs work, you havnt swapped them to LED and connections are ok then its worth a try.
That is providing you have checked the obvious such as battery voltage first etc
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 45.02 Kb
