Clip ons
fozzym
PostPosted: 19:23 - 13 Jun 2014    Post subject: Clip ons Reply with quote
Hey guys,
Little questions for you track dayers.
On my zx6r the clip ons are held in place by 2 pinch bolts on the clamps and then a bolt into the top yoke which I guess does two things 1 guarantees the correct postion (or what kawasaki think is right) and 2 further secures the clip on.
So my question: Would you (or do you ) remover the bolt into the yoke?
I can see an advantage of removing them that in the event of an off the clip on isn't anchored quite as much and thus could move a bit rather than snapping or busting the yoke.
Am I on the right track or not worth the mither?
lihp
PostPosted: 19:28 - 13 Jun 2014    Post subject: Reply with quote
Not worth the mither, just take a spare bar.
PostPosted: 14:12 - 15 Jun 2014    Post subject: Reply with quote
Mine are dropped lower on the fork so are not "secured" to the yoke. I personally don't care if I bin it, but then again if I did, clip ons are the LEAST of my worries Laughing
PostPosted: 14:39 - 15 Jun 2014    Post subject: Re: Clip ons Reply with quote
The pinch bolt should generally be tight enough that you'll bend the tube anyway.
I'd remove the bolt to the yolk if I wanted to adjust the angle.
I believe yours take a generic clip on bar paddy - so should only cost a few quid to replace - or buy a 7/8" aluminium tube and make your own by cutting with a hacksaw, then grinding out the notch for the pinch bolt.
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 38.8 Kb
