Fuel leak?
JackGarrett94
PostPosted: 10:26 - 16 Jun 2014    Post subject: Fuel leak? Reply with quote
My bikes leaking fuel but first i will give you a story of what happened because everyone likes a story.
I took my bike green laning on saturday for the first time, I rode up to thetford with some friends it was about 40miles to thetford. The day started of great, Bumping up and down sliding about, it was a bloody good laugh, I hit a log and dropped my bike, she was fine now heres where things went wrong, We where riding down a lane and this sand pop out of know where my friend in front of me wobbled and nearly crashed (i was laughing my arse of seeing him slide about) so i slowed down but it wasn't enough i crashed.. I picked my bike up and she was leaking fuel from the over flow, I assumed the float was stuck, We spent a few hours trying to fix her but couldn't, Ended up getting van to pick me up and take me home, Took 7 hours for a van to show up i didn't get back till half 2 in the morning. Fun times.
Right now what is causing my bike to leak fuel from the over flow? The float seemed fine it wasn't stuck, I couldn't see if anything was broken or not i was really confused, Im going to take her apart tomorrow and have a better look, I assuming the float isn't closing of something when it floats. My bikes a honda xr125.
Any ideas? getting the bus to work today sucked!
mudcow007
PostPosted: 10:33 - 16 Jun 2014    Post subject: Reply with quote
does it have a vacuum operated fuel tap?
the diaphragm could be toast in the tap.....
Islander
PostPosted: 10:41 - 16 Jun 2014    Post subject: Reply with quote
Float valve not seating properly would be my guess.
JackGarrett94
PostPosted: 11:36 - 16 Jun 2014    Post subject: Reply with quote
Im not to sure, i think the fuel works by gravity if thats what you mean?
map
Mr Calendar
PostPosted: 14:23 - 16 Jun 2014    Post subject: Reply with quote
Vacuum operated fuel line is where carb(s) create a vacuum and pull fuel from tank into carb(s). The carb(s) had diaphrams (that split) to achieve this). Fuel tap usually has on, reserve and prime positions. As you need to bypass (prime) to fill carb(s) to get bike started in the first place.
Float in the carb sticking means fuel not forced properly out of carb so just keeps filling and overflowing. Sometimes a sharp tap with a screwdriver handle works to free. Otherwise disassemble and clean.
Could just be dropping the bike has dislodged crud that's affecting the carb.
Islander
PostPosted: 14:38 - 16 Jun 2014    Post subject: Reply with quote
Ermmmmm...
Vacuum fuel taps have an internal diaphragm that keeps the tap closed until the engine is running - the vacuum from the intake manifold operates the diaphragm and opens the tap. The fuel flows by gravity as normal. Nothing to do with the carb diaphragms - they operate the needle part of the main jet.
Fuel flows into the float chamber until a predetermined level is reached when the float tang lifts a needle valve and closes the fuel intake off. When the engine is running, fuel is lifted out of the float chamber by the pressure differential created in the venturi causing the level and float to drop and opening the needle valve on the fuel inlet.
If the carb is overflowing then the needle valve in the float chamber isn't closing the valve on the fuel inlet properly. That's one of several things. Either the float height is wrong, something is stopping the valve from closing (a speck of grit for example) or the valve is worn beyond service limits.
map
Mr Calendar
PostPosted: 14:50 - 16 Jun 2014    Post subject: Reply with quote
Islander wrote:
map wrote:
Vacuum operated fuel line...
Ermmmmm...
Vacuum fuel taps have an internal diaphragm that keeps the tap closed until the engine is running - the vacuum from the intake manifold operates the diaphragm and opens the tap....Nothing to do with the carb diaphragms - they operate the needle part of the main jet.....
Of course, I'm getting my diaphragms mixed up.
YBR Ric
PostPosted: 21:22 - 16 Jun 2014    Post subject: Reply with quote
Time to dig up Ye Olde Ethanol in the petrol attacking certain fuel system parts myth; except having seen what happens to some types of O rings I now know it's no longer a myth Crying or Very sad The impact force may have been the last straw for the float valve.
Ethanol attacks hydrocarbon rubbers - eg nitrile rubber fuel hose along with gaskets and seals made with or from hydrocarbon rubbers.
It's possible the float valve tip has become swollen or distorted and is failing to seat correctly causing a leak.
OR it could just be worn. If Ethanol damaged then a like for like replacement will eventually suffer the same fate. A Viton tipped float valve is needed to prevent this.
The last post was made 11 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 60.26 Kb
