RS125 Blown Over, Cant Get into Gear!
ash t
PostPosted: 17:23 - 12 Jan 2005    Post subject: RS125 Blown Over, Cant Get into Gear! Reply with quote
A friends RS 125 has been blown over in the wind. It has fallen on its left side. We cannot get it into gear at all. Clutch lever feels normal. Any advice??
Confused
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
mchaggis
PostPosted: 17:32 - 12 Jan 2005    Post subject: Reply with quote
I presume that's putting it into gear when it's not running? If it's not running the gearbox often won't work very well anyway. If that is when it is running, then I don't think I can be much help.
I must not be a troll...
Mmmm, Guinness
ash t
PostPosted: 17:39 - 12 Jan 2005    Post subject: Reply with quote
The Selector shaft is rubbing on the footrest hanger. going to look properly tomorro when its light. Get a blowtorch on it and bend it back into shape.
PostPosted: 17:41 - 12 Jan 2005    Post subject: Reply with quote
This can do more serious damage.
It can nock the selector shaft inside the engine, which can mess up the positioning of the selector fork or possible bend them I believe.
If that is the case (nothing else sorts it out) it's going to be a strip and rebuild probably.
Rift.
PostPosted: 18:54 - 12 Jan 2005    Post subject: Reply with quote
ooo Man i really feel for him...
You only live once so get a bike and ride
PostPosted: 00:22 - 13 Jan 2005    Post subject: Reply with quote
On the late RS125 with the 122 engine it is quite easy to change the gear change shaft and it does not connect directly to the shift drum. No need to split the crankcases, just whip off the clutch cover and it will fall out.
The last post was made 21 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 48.71 Kb
