| themajor7 |
 themajor7 L Plate Warrior
| map |
 map Mr Calendar
| themajor7 |
| map |
 map Mr Calendar
 Posted: 14:04 - 16 Jun 2014 Post subject: |
If based on the older CG models I suspect will be squarer YB2.5L-C battery, dimensions approx. L80mm, W70mm, H105MM
Although the 2000+ CGs I believe made in Turkey had a larger battery box so could take something like the YTX5L-BS, L115mm, W70mm, H105mm.
The actual battery code depends on the maker. I'm sure google will throw up a comparisons chart.
TL;DR you really need to check the battery fitted and/or size of the battery box. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| matto |
 matto Crazy Courier
The last post was made 12 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
