| TaeKwon125 |
 TaeKwon125 Borekit Bruiser
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| TaeKwon125 |
 Posted: 16:00 - 18 Jun 2014 Post subject: |
By all means correct me if I'm wrong but,
This link:
https://www.migweb.co.uk/forums/engines-transmission/167433-how-much-current-does-starter-motor-draw.html
Appears to show that a car starter motor can take up to 325 Amps at 12V for a V8 engine. Even if my starter motor used the same then that's 3900W. With a 333W alternator output the alternator would only need to be on for 12 times as long as the starter motor is used to recharge the battery.
I know the battery is also running the lights and spark plugs etc at that time but I'm not convinced it will kill it as quickly as you believe or at all. |
| map |
 map Mr Calendar
| gavbriggs |
 gavbriggs Crazy Courier
| nowhere.elysium |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 14:25 - 19 Jun 2014 Post subject: |
I have done this very experiment, because I was bored.
I fully charged my gixxer's battery, and then disconnected the reg/rec from the stator. It was reading 13.2v when I started.
I did about 10 miles around our site at about 20mph, with no lights as it was daytime.
When I got back, the reading was 12.8v.
This was a brand-new battery. Obviously higher speeds require more sparks so it'll run down quicker and lights will take their toll too, and a well-used battery will have less capacity than a fresh one.
In a real-world situation, running total loss, I reckon you wouldn't get more than 15 miles out of it before it went flat. I suspect that it would start to misfire at high RPM and then get more and more sick as your plug's performance dropped.
I agree with the others though; 1.2 miles isn't nearly enough time to get to get the engine warm; your plugs will coke up and you're running the risk of accelerated engine wear. It takes my bike 3-4 miles before the temp gauge even starts to move, and before that time I limit myself to 50% of the available RPM and short-shift so there's less stress on the engine.
I'd walk.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Baffler186 |
 Baffler186 World Chat Champion
| map |
 map Mr Calendar
 Posted: 16:05 - 19 Jun 2014 Post subject: |
It's not really the distance ridden it's a combination of that and the revs used.
The bike manual may contain the optimal revs for charging the battery.
IIRC it's usually in the 4-5K range for the majority (see, someone will post exception).
Just leaving the bike on idle/tickover will do nothing. As will thrashing it to the redline not charge the battery as well. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Andy9934 |
 Andy9934 Nova Slayer
| Lord Percy |
 Lord Percy World Chat Champion
| P.addy |
 P.addy Red Rocket
| G |
 G The Voice of Reason
| TaeKwon125 |
The last post was made 12 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
