WR125R/X Valve adjustment?
MattWadz
PostPosted: 20:28 - 19 Jun 2014    Post subject: WR125R/X Valve adjustment? Reply with quote
So, my bike has done just under 5k miles, and i dont think the valve clearances have ever been done, anyone personally done them on a WR/R125? Please reply if you know of a guide or how easy it is?
i know you remove valve cover, and slacken the 8mm lock nuts on each rocker, then adjust the square adjuster nuts, but does the engine need to be in a certain place?
TDC/BDC?
anyone know?
Thanks
Karma Thumbs Up
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
gavcarter
PostPosted: 20:33 - 19 Jun 2014    Post subject: Reply with quote
TDC on compression stroke and COLD
MattWadz
PostPosted: 20:55 - 19 Jun 2014    Post subject: Reply with quote
yeah makes sense cheers!
i think its a 4 valve though?
valve clearances are 0.10 for intake 0.20 for exhaust, so do i set the engine to TDC, and how do i know if its on compression stroke?
gavcarter
PostPosted: 21:06 - 19 Jun 2014    Post subject: Reply with quote
take inspection covers off, leave spark plug in - it will come up to TDC relatively easily on exhaust stroke, on compression stroke it will feel much stiffer.
If you are still doubting, remove spark plug, put your thumb over the hole and have some one else turn the engine for you, you will feel the air being pushed up at your thumb and try and pop it off the spark plug hole. This is compression.
Only crank engine towards front of bike, never try to turn it backwards because you just missed TDC, go back round again
Supermoto_Fan
PostPosted: 21:19 - 19 Jun 2014    Post subject: Reply with quote
Why are you doing valve clearances on a 5000 mile old 125cc 15bhp engine? I sold mine at 7k miles with only basic service history
MattWadz
PostPosted: 23:39 - 19 Jun 2014    Post subject: Reply with quote
Sounds a little bit tappy and dont think its ever been done, rather keep on top of things with a relatively new engine changing oil every 1k miles 1 litre of putoline 10/40 and an oil filter costs 15 pounds, not alot for the peace of mind
Crz
PostPosted: 00:18 - 20 Jun 2014    Post subject: Reply with quote
You'll have to take the fuel tanks off and quite frankly the rocker cover bolts are an arse to get to on the one side.
As mentioned, adjust when cold and at tdc. There is a line behind the inspection cover that you can align with another line on the casing.
Other than that it's easy Thumbs Up
Theory: 8/7/13 Mod 1: 26/7/13 Mod 2: 21/8/13
"Life is like a garden, plant your seed in every hole you see"
Codemonkey
PostPosted: 07:41 - 20 Jun 2014    Post subject: Reply with quote
Have a look on yamahar125.com Its the same engine as the YZF-R125 and there's a service manual for it somewhere on that site.
Test Passed 10/05/2011 Current bike: XJ6-N
Supermoto_Fan
PostPosted: 22:25 - 20 Jun 2014    Post subject: Reply with quote
Mine was ticky, turned out to be a exhaust gasket.
MattWadz
PostPosted: 00:15 - 21 Jun 2014    Post subject: Reply with quote
pretty sure its not an exhaust gasket had that issue on another bike before! would valve clearances cause a slight reduction in power/response?
Still seems to easily out accelerate my friends WR125X, same year bike, similar mileage.
are the sprockets different on them?
Supermoto_Fan
PostPosted: 08:16 - 21 Jun 2014    Post subject: Reply with quote
The gearing is different between the YZF/WRR/WRX and the WR/WRX yes.
Check your valves to be on the safe side but I doubt they are out of spec..
Supermoto_Fan
The last post was made 11 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 71.49 Kb
