| Tazzeer1993 |
 Tazzeer1993 L Plate Warrior
 Posted: 12:59 - 20 Jun 2014 Post subject: VFR 400 NC30 running issue |
Hello everyone!
I'm having a rather irritating issue with my NC30. When cold, she will start up fine and run beautifully. When she gets warm however, she coughs and splutters like you wouldn't believe. Bogs down anywhere between 1.5k and 7k revs. And she will just randomly die on me for no apparent reason. I am bewildered as to what could be causing this! the only mod to the bike is a Yamamoto exhaust system. Thanks in advance. Ride safe  ____________________ Challenge accepted! |
| RhynoCZ |
 RhynoCZ Super Spammer
| Tazzeer1993 |
| Suntan Sid |
 Posted: 13:46 - 20 Jun 2014 Post subject: |
With it being a Honda, have you checked the reg/rectifier and CDi, are they getting hot? ____________________ "Everybody needs money, that's why they call it money!"  |
| Tazzeer1993 |
| Suntan Sid |
 Posted: 14:19 - 20 Jun 2014 Post subject: |
If you've eliminated fuel/carbs, timing/compression, then you're left with electrics/ignition.
Honda CDi's, particularly on older models, are notorious for failing and intermittent faults, the reg/rectifiers are much the same.
Have a search round here for reg/rectifier testing, there's been plenty of stuff about it on here. Is it getting very hot? Is the insulation on the wires melted at all?
How many CDi untits are there on your bike?
There were two on my NSR250, one for each cylinder, one of them was intermittently dodgy! It's usually a dry joint on the PCB, a manufacturing defect, you can't fix it, you need to buy another, if you can find one.
Could be a blocked fuel filter, air filter, have you tried new spark plugs?You need to eliminate all the possibles, one by one, until you find the fault. ____________________ "Everybody needs money, that's why they call it money!"  |
| shereen |
 shereen World Chat Champion
 Posted: 14:29 - 20 Jun 2014 Post subject: |
This sounds identical to the problem I had with my first NC30 - it turned out that there was a kink in the fuel hose from the tank.
EDIT: Also join the nc30 group on facebook:
https://www.facebook.com/groups/5345627304/?fref=ts
Those guys know about everything to do with these bikes. ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| Timmeh |
 Timmeh World Chat Champion
The last post was made 11 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
