Any Sparks in the hizz-ouse?
mudcow007
PostPosted: 13:28 - 20 Jun 2014    Post subject: Any Sparks in the hizz-ouse? Reply with quote
Just bought some spot lights for the garden, but they have only come with short length of wire attached (about 6")
so i was thinking of extending them, to a junction box then to a long flex onto a plug - that make sense?
the spot lights are only 10w so not exactly powerful or anything
any ideas?
Hetzer
PostPosted: 13:32 - 20 Jun 2014    Post subject: Reply with quote
Yeah. Go to Maplins, buy the exact length you need of the same wire off one of their reels, splice it in with a multi-connector (about a quid for that), job's done. Oh, wrap the connector so it's water-proof.
mudcow007
PostPosted: 14:21 - 20 Jun 2014    Post subject: Reply with quote
found something called "adhesive lined butt connectors" basically crimp em, then heat them up to seal them.
i will wrap it in amalgamating tape too to cover up my bodges etc...
cheers
Robster
PostPosted: 14:36 - 20 Jun 2014    Post subject: Reply with quote
cheers
I think they sell those in Ann Summers too
Up the bum no babies.
PostPosted: 14:42 - 20 Jun 2014    Post subject: Reply with quote
If it's for outdoor use, you really ought to get arctic grade flex.
I would make the connection inside the light housing if at all possible. Either cutting back the existing cable and joining with a choc-block connector or you might even find it attches to a screw-in connector anyway.
Saves having a join outdoors.
mudcow007
PostPosted: 14:54 - 20 Jun 2014    Post subject: Reply with quote
good point that...
ever heard of hituf cable?
supposedly easier to work with that swa (i hate that stuff) but is tougher than "normal" 3 core flex
gavcarter
PostPosted: 21:33 - 20 Jun 2014    Post subject: Reply with quote
It is sometimes cheaper ( especially with LEDS over any sort of distance) to just use the bog standard wire they supply but put it inside corrugated tubing.
This sort of stuff https://www.ebay.co.uk/itm/BLACK-CORRUGATED-FLEXIBLE-HOSE-FISH-GARDEN-POND-FILTER-PUMP-MARINE-FLEXI-PIPE-/171142284167?pt=UK_Home_Garden_Garden_Plants_Bird_Bath_Feeder_CV&var=&hash=item27d8e00387
Just make sure to fit bungs and silcone to ends to keep water tight.
robs321
PostPosted: 08:16 - 21 Jun 2014    Post subject: Reply with quote
This is the sort of thing your after!
https://www.ebay.co.uk/itm/like/161035969675?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
The last post was made 12 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 57.07 Kb
