SV650 a pig to start
Itchy
PostPosted: 13:02 - 20 Jun 2014    Post subject: SV650 a pig to start Reply with quote
Sometimes it starts on the button, Monday->Wednesday it did this.
Then fires up as if there are no problems.
24h later it does it again, battery left on charge overnight just in case. Reading 12.87v across the terminals.
Any ideas?
Thanks
EDIT turned out to be a bunch of corroded wires and a bad battery,
MaybeGuy
PostPosted: 13:27 - 20 Jun 2014    Post subject: Reply with quote
Loose battery terminals
Itchy
PostPosted: 13:40 - 20 Jun 2014    Post subject: Reply with quote
Nah done up as tight as can be.
DMCpro
PostPosted: 14:19 - 20 Jun 2014    Post subject: Reply with quote
Dodgy starter solonoid/loose connection or wiring try arcing across both solonoid terminals.
Honda CB-1, TS125X
VW Golf Estate
Itchy
PostPosted: 14:33 - 20 Jun 2014    Post subject: Reply with quote
Put a screw driver across the terminals on the starter relay, big spark, no signs of engine turning over.
Teflon-Mike
tl;dr
PostPosted: 14:51 - 20 Jun 2014    Post subject: Reply with quote
'sticky' starter motor.
High resistance from worn brushes / contact ring.
Might be eeked out by stripping & cleaning the starter.
+ dont dismiss the battery. voltage on terminals is NO indication of how many amp-hours are in the battery.
An old battery can loose half its charge holding capacity, the Ah rating falling from, say 10Ah to 5Ah and so appear to charge really fast.
The 'ready' lamp on a charger is also no guide; usually only comes on when the current draw has reduced to a 'trickle'...
Starting puts hi-load on battery, drawing perhaps 30A or more, so a fully charged 10Ah battery would get flattened in 20min, but a tired battery might only have 5Ah in it, and asked to deliver 30A, just not be exited enough to deliver it; and with huge 'load' on it, basically gives up.
PostPosted: 15:12 - 20 Jun 2014    Post subject: Reply with quote
Wiggle back and forth in gear. See if it starts with the clutch in then. Would say pull the starter off and check it.
Itchy
PostPosted: 15:15 - 20 Jun 2014    Post subject: Reply with quote
Looks like its new battery time tbh looking closer terminals are greening, didn't notice prior.
The starter motor or relay? I'm thinking the gubbins behind this is that it 'loosens' a sticky starter motor right?
PostPosted: 15:16 - 20 Jun 2014    Post subject: Reply with quote
Motor is where I would look initially. Thumbs Up
Robby
Dirty Old Man
PostPosted: 08:45 - 21 Jun 2014    Post subject: Reply with quote
If it was a solenoid problem, it would work fine when you bridge the terminals. That didn't work, so starter motor is the next logical place to look. Check over the starter motor wiring before you pull the starter apart.
Fisty
PostPosted: 09:16 - 21 Jun 2014    Post subject: Reply with quote
Had a similar problem with a mates SV, after much faffing it turned out to be the contact on the start button had gone green and furry.
Fatter and faster than Fret
The last post was made 11 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 73.89 Kb
