mileage
mudcow007
PostPosted: 13:23 - 23 Jun 2014    Post subject: mileage Reply with quote
After seeing Itchy's threads about bikes blowing up after a certain mile marker, what is high mileage in bike terms...or is it roughly the same as a car?
My bandit (p reg) is on 36000, is that classed as mega high?
SQL
PostPosted: 13:26 - 23 Jun 2014    Post subject: Reply with quote
anything near 100k
EDIT** Anything near 100k I wouldn't touch myself (Unless it was very very cheap)
Conzar
PostPosted: 13:30 - 23 Jun 2014    Post subject: Reply with quote
Depends on other factors, it could have 13k miles and not been serviced or have 55k and been serviced every 4 thousand miles
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Teflon-Mike
tl;dr
PostPosted: 14:49 - 23 Jun 2014    Post subject: Reply with quote
Depends on the bike.
Bikes dont have the same 'anticipated service life' of a car; they are more highly tuned for a start, even the less highly tuned bikes.
Then smaller capacity bikes tend to get thrashed more than bigger ones; sportier bikes tend to get thrashed more than more sedate ones; variables are huge, and bikes can suffer as much from lack of use as over use.
Bikes is not cars, and car 'thinking' often doesn't translate. Which is especially true of mileages and age. You have to think of them as leisure equipment, more like a multi-gym or a fishing rod, where anticipated service life may be from light and occasional duty in the cheapest in the argos catalogue, through to whatever pro gym's use, designed for heavy every-day use.
'Average' miles for a bike these days is 3,000-6000 a year, compared to 12 - 15,000 for a car, (reflecting how much bikes are now used purely as leisure equipment rather than every day transport) yet factory anticipated service life are still of the same 'duration', approx 10 years; so anything much over 50K on a bike would make wonder... but not enormously, and be just one factor I paid little attention to in my buying decision.
I mean, 30K on a hard worked little YBR is a lot of miles; but one used as every day commuter could crank that up before its first MOT is due; Same miles on a Pan Euro, it would barely be run it, but some chap using it for an annual touring holiday and the odd sunny day trip; could take ten years to get them miles on it!
Doovy
PostPosted: 15:06 - 23 Jun 2014    Post subject: Reply with quote
My 2005 CBR600 RR is on 44,000 miles.
map
Mr Calendar
PostPosted: 15:19 - 23 Jun 2014    Post subject: Reply with quote
I would also say that the type of owner is a factor.
BMWs have a reputation for being cosseted, garaged, cleaned regularly (I'm told a clean bike shows any issues easier), serviced. So picking up a higher mileage one of those would in theory be less of a gamble.
To contrast sports bikes (and 125s), because of their nature, have a reputation to be thrashed and/or thrown down the road/track. So knowing the seller, or getting an idea of how they (ab)use the bike would help.
IMO there comes a point where mileage doesn't really matter. It's how used, maintenance and condition.
PostPosted: 15:33 - 23 Jun 2014    Post subject: Reply with quote
Leaving the engine aside, bikes have a lot of consumables.
50K with the tyres, sprockets, chain, shocks, brakes, clutch and bearings just replaced vs 25K with them all just about to go: which would you rather buy?
Itchy
PostPosted: 15:47 - 23 Jun 2014    Post subject: Re: mileage Reply with quote
My experience is NOT representative of others and everyone's experience differs. Sickpup for example had the Donkey, which last I remember got sold to Ann. It was OK with 238,000 miles on it it still ran. However miles on a bike are non transferable, those 238K belong to Sickpup. He also has/had an ER5/6? which goes to the moon and back every month and it still runs.
Dave Lambeth has an XT6003AJ which was around 200K without a rebuild.
Myself I am a bodger and product of a different time when BCF ... different*
Anyway...
Pre 2005 the word maintenance did not exist in my vernacular. NTV 2 (as NTV1 was run over by a lorry) was 'maintained' using an 8 spanner a 12 spanner and some allen keys for a long time. IIRC I let go of it with well over 100K on it or there abouts I don't remember. I highly suspected this bike had gone all the way round and reset to 0. Similar to the stories of people opening clocks to 'adjust the mileage' and seeing a sticker saying oh no not again!
I realised that essentially everything on a bike is a consumable item if you ride it long enough.
The with about 100K on it consumed:
2 Starter relays.
2 Batteries
1 reg/rec
1 clutch cable
1 choke cable
2 headlight bulbs.
Bushes and fork seals
airfilter
7 oil filters
Countless brake pads (I was too cheap to replace the seals so they went back in)
Head stock bearings
2 tank rubbers
8 spark plugs (twin spark)
3 sets of BT45s**
Oil changes every so often
Due to my own ineptness it also consumed
4 brake levers
5 clutch levers
2 gear change levers
1 set of clocks.
1 set of bars
One radiator
When I got rid of her, it was weeping oil from the top of both cylinders, the collector box had rotted through, the tank had a massive fist sized dent in it, the valves hadn't been done for about 75K+ the sparks hadn't been changed. The clocks were held together with gaffer tape, but it STILL started up and ran and it only failed to start about 10 times in 1000s of starts due to the above, it also caught fire more than once.
It was simple uncomplicated and I would own one again. 100K with just fuel and about £800 of consumables, uber cheap biking. The dude who I sold it to fixed it by sawing the exhaust off and using VW beetle pipes.
My CBR could have gone to 100K easily if I had the facilities to maintain it, I didn't... and the nightmare of changing downpipes haunts me today so was sold. It had been crashed a few times at very high speed.
*when I say BCF is different now, BCF today is different to how it was then, as was SWB and HP clans. For instance back in 2005/6 we were young and stupid. Ride outs in the norf clan were a WEEKLY affair, people would ride whatever they had no matter WHAT the weather conditions or the condition of the bike primarily because we were young, poor and bored.
For instance I turned up to a ride out on my NTV with bars so bent they touched the tank when pointing straight forward, I turned up to meets with busted fork seals, which in those days were cured by putting kitchen towels under the dust seals. Rides without brakes, I crashed at high speed, went home on my wreck, got my other bike and continued to ride
My riding bud Trev turned up with bald tyres on his A1P so bald you could see the steel wires.
People would use a stanley knife to cut extra tread into their bridge stone tyres as they were so poor.
A certain rider turned up with de laminated tyres there was a HAND sized missing piece of tyre, you could see white canvas underneath.
Scaffold poles were perfectly acceptable substitutes for exhaust downpipes.
Brake pads were used to the metal and beyond.
Old lambskin jackets, ASDA (not Tesco) 2litre milk bottles would be made into hand guards... bikes literally held together with tape and glue.
It was great, BCF ain't like that anymore what with people asking about how they should prep bikes for 200 mile rides Confused
Musketeer
PostPosted: 16:57 - 23 Jun 2014    Post subject: Reply with quote
Depends on engine capacity and how tuned the engine is. Also depends on general build quality (i.e. Chinese bikes)
For sport 600-1000cc I would say anything over 30k miles is high, but don't let it put you off.. I would still buy one for a good price. My ZX6R had over 30k miles and before Cadwell Park it was perfectly fine and I was going to keep it for another 20k miles at least.
Chinese bike with 30k? No way. I'm not sure if I've ever seen any with that mileage Wink
Touring bikes 750-1300cc? 50k woudn't put me off at all.. closer to 100k and I would want it cheaper.
Small 125cc bikes? I think 20k is high, but some people do 70-80k without any problems. All those C90s in India, Thailand, Vietnam do probably over 100k in their life time, carry 4-5 people etc. Wink Two strokes - anything over 15k I would consider a full rebuild candidate (additional cost).
yen_powell
PostPosted: 19:04 - 23 Jun 2014    Post subject: Reply with quote
My Varadero is up to 77,000 miles. I would consider that high mileage and shagged only if I was looking to buy it.
If selling it I would say that it shows the proven reliability and ease of use that it had gotten the mileage so high. Also that it has only been used by a vicar to and from the church on sundays.
XT1200Z and a DR350 in bits
stevo as b4
PostPosted: 19:17 - 23 Jun 2014    Post subject: Reply with quote
Everything is indeed a consumable on a bike, and you can totally strip and re-build a bike fairly easily several times over it's life or age. Also some bikes with hi output 2stroke motors, might have received several complete re-builds in 100k, and had 3 or more new crank assemblys etc.
You don't get people do the same sorts of things with car's, they are also generally not as maintenance friendly or easy to work on as bikes. That's why when car's have a fault or something goes wrong that's not a simple quick fix, they are often seen more as throwaway items, where as bikes are not, and even most ratty scabby bikes can be brought back onto the road with some work, where as a neglected tired car with damaged or seriously corroded bodywork, is rarely bothered with or deemed worth the hassle of fixing.
jimspeed
PostPosted: 21:03 - 23 Jun 2014    Post subject: Reply with quote
I bought a pair of GS500e's for my uncle to learn on, the one had 15K on it and the other had 95K and was 2 years older, the best one by far of them was the high miler as it had been used every day etc the low miler had several folk look at it before I found someone willing to take it away.
Use and servicing has to be the key to bigger miles/
My ZZR6 knackered its gearbox at 33K but that was my fault riding in work boots and not clicking it in enough at 12K rpm Embarassed that motor showed absolutely signs of being even close to worn, no smoke/rattles etc.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
DMCpro
PostPosted: 21:21 - 23 Jun 2014    Post subject: Reply with quote
Sold my old cg 125 with 45k on the clocks was completely shagged riding to and from Hastings (2013) fucked it since the valve stem seals had gone a lot of oil was missing and all I could buy was vegetable oil. Still! Better than nothing. Got me home anyway then sold it a week later
Honda cb-1 /cb400f has around 96k starts and runs like a dream. Great bike did have to do a lot of work to get it running though. But now it's perfect
Old teacher at college had a bmw k100rt with around 170k he used daily
Depends on the bike and how much your willing to spend maintaining it
Honda CB-1, TS125X
VW Golf Estate
sabian92
PostPosted: 21:25 - 23 Jun 2014    Post subject: Reply with quote
Personally I'd rather buy an old, well maintained bike than a newer one that's clearly been neglected.
Somebody who takes pride in their machine is somebody who won't let it become a hazard.
PostPosted: 21:36 - 23 Jun 2014    Post subject: Reply with quote
While bikes are shorter lived than cars, part of that is that with bikes there is a good selection of low mileage bikes to choose from, and the absolute difference in price isn't that massive. If the difference is £500 between a bike with 40k on the clocks and one with 20k on the clock, most would chose the one with 20k.
As to what age I would touch. With most cars I wouldn't worry too much at buying one with 100k on the clocks. But very few bikes would I consider with that mileage.
Fisty
PostPosted: 21:43 - 23 Jun 2014    Post subject: Reply with quote
BodyGuard wrote:
My varadero is on 61K.
The trouble is bikes in your hands age in dog years. So your bike now looks and goes like one with 427k on it.
Fatter and faster than Fret
Supermoto_Fan
PostPosted: 21:57 - 23 Jun 2014    Post subject: Reply with quote
I wouldn't go out to buy a bike with anything over 30,000 miles on, purely because I do around 15,000 a year and within 3 years you'd have a bike on it's way out even though when you bought it it was in reasonably good nick.
Gazz
PostPosted: 22:17 - 23 Jun 2014    Post subject: Reply with quote
My Deauville is over 100K.
Bought the bike with the understanding that in the worst case scenario; that the engine would be fucked (or would soon be fucked due to high mileage).
Priced some engines on ebay (usually around £200) so thought it was worth a punt at this price.
3 years on, I've had almost 100% trouble free riding.
A battery, couple of sets of tyres and a reg/rec and thats about it.
PostPosted: 22:31 - 23 Jun 2014    Post subject: Reply with quote
BodyGuard wrote:
I spent £250 on consumables last week for the MOT
That's a lot of cider and Chicken McNuggets to get through in 20 minutes.
Fisty
PostPosted: 22:39 - 23 Jun 2014    Post subject: Reply with quote
BodyGuard wrote:
I spent £250 on consumables last week for the MOT needless to say it passed.
And? Your bike is still fucked. Even after lobbing £250 on it. Mine with 68k on it still looks good and is not fucked.
Fisty
PostPosted: 22:52 - 23 Jun 2014    Post subject: Reply with quote
BodyGuard wrote:
It passed MOT not fucked. It is good.[/i]
And? An MOT means the square root of fuck all. Your front sprocket is welded to the output shaft. Badly. If that is not fucked then I am not sure what is!
Christ a bike can pass an MOT with a none functioning gearbox.
The last post was made 12 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 140.71 Kb
