Spongey front brake - master cylinder?
smithyithy
PostPosted: 18:00 - 23 Jun 2014    Post subject: Spongey front brake - master cylinder? Reply with quote
Recently my front brake has gotten quite spongey, in that there is somewhat excessive travel in the lever..
Pads look fine, fluid level also fine, what looks like the master cylinder at the base of the lever does look worn though, like the rubber around where the bottom of the lever pushes in..
Would this be responsible for a spongey feeling and if so is it just a case of replacing that part?
Bike is a 1990 Honda CBR400RR.
Cheers.
SQL
PostPosted: 18:05 - 23 Jun 2014    Post subject: Reply with quote
Bleed brakes first its cheap and easy and normally the issue
andym
PostPosted: 18:18 - 23 Jun 2014    Post subject: Reply with quote
I've had this on a couple of bikes (including the current 1), I found replacing all the crush washers and bleeding the brakes sorted it out
smithyithy
PostPosted: 18:34 - 23 Jun 2014    Post subject: Reply with quote
Bled the brakes with no improvement Neutral
What is the crush washer?
PostPosted: 19:32 - 23 Jun 2014    Post subject: Reply with quote
The rubber bit you can see around the base of the lever should affect the brakes being spongy in the short term. It is there to protect the rear seals from grit and other rubbish.
If you have bleed the brakes thoroughly with no improvement then hopefully can count that out.
Whip each caliper off and check that they are free to slide on their carriers. If they seize on the sliding pins then the brakes can feel spongy.
How old are the seals in the calipers?
smithyithy
PostPosted: 20:38 - 23 Jun 2014    Post subject: Reply with quote
Don't know how old the seals are, I've never had the callipers off before, as I say it's only more recently the front has been like this..
I made GIF's of the CBR lever / rubber compared to the Daytona, sorry if they take a bit to load, I did try to reduce the frames per second...
https://farm6.staticflickr.com/5485/14490288952_a2fe6fda02_o.gif
https://farm4.staticflickr.com/3884/14488132471_24246d0252_o.gif
https://farm6.staticflickr.com/5515/14491503445_84a5a9f558_o.gif
moonzoomer
PostPosted: 20:42 - 23 Jun 2014    Post subject: Reply with quote
The copper washers that seal around the banjo bolts, have the brake lines been replaced or are they the original rubber items as these would almost certainly need to be replaced given the age of the bike
smithyithy
PostPosted: 21:05 - 23 Jun 2014    Post subject: Reply with quote
As far as I know, everything is original, expect pads obviously which have been changed incrementally.
This will become my track bike as soon as I get the 675 on the road, so it'll be having full brake overhaul and everything else serviced, upgraded or properly setup..
Ideally I just need it to tide me over for a 2/3 weeks.. Does that rubber piece look excessively worn? If so I can get a replacement ordered first and foremost..
moonzoomer
PostPosted: 21:12 - 23 Jun 2014    Post subject: Reply with quote
If there are no leaks from the master cylinder I doubt if that is the problem, check your brake lines for expanded areas when applying the brakes and as already mentioned check the brake calipers themselves for free mechanical movement along the brake pad pins and check that all the pistons are moving freely and without leaks.
PostPosted: 21:13 - 23 Jun 2014    Post subject: Reply with quote
Can't really see in the video. However whatever condition it is in, on its own it will not make the brakes spongy. It could be the m/c (but wouldn't bank on it), but if so it would be the seals inside that would likely be the issue.
The bike is ~25 years old so the hoses are probably past their best, but I am not a fan of braided hoses fixing everything; rather that they are just a cheaper replacement than the original hoses.
Itchy
PostPosted: 21:15 - 23 Jun 2014    Post subject: Reply with quote
Bleed the brakes properly?
While you will get massive bubbles to start with, they will decrease in size until they are fizzly drinks bubble size, even then leave it over night with a belt around the brake lever.
moonzoomer
PostPosted: 21:20 - 23 Jun 2014    Post subject: Reply with quote
Does your bike have 2 brake lines connected to the master cylinder or just one? If you only have one brake line then there should be a connector which joins the 2 brake lines from each brake caliper, so try bleeding the brakes at this joint as the air bubbles will be rising to the highest point which is this union. The brake line union is usually located around the bottom steering yoke.
smithyithy
PostPosted: 21:38 - 23 Jun 2014    Post subject: Reply with quote
Yeah the 2 brake lines join then meet the master cylinder as 1.
I've got another day off tomorrow so I'll get the callipers off and inspect everything.
Cheers.
gavcarter
PostPosted: 22:14 - 23 Jun 2014    Post subject: Reply with quote
check discs for a lip - I went back and forth on this for ages after fitting new pads only to find I had worn discs lol
The last post was made 12 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 83.3 Kb
