| RealAshGraham |
 RealAshGraham Borekit Bruiser
 Posted: 14:18 - 21 Jun 2014 Post subject: Left heated grips on |
Oops, I left my heated grips on yesterday after being out on the bike.. battery is dead out flat.
Never bump started a bike before and the RAC said upto a three hour wait Any quicker way I can get on the move?  |
| The Artist |
 The Artist Super Spammer
| RealAshGraham |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:30 - 21 Jun 2014 Post subject: |
Conventionally, put it into second, pull the clutch, run along and jump on while letting the clutch out.
Personally I normally leave it in neutral (easier to push), run along and jump on once speed has built up, then drop down onto the seat as I knock it into 1st gear.
Note, not specifically for a bike, with fuel injected vehicles you might have a an issue as it needs enough power in the system to prime the fuel pump and pressurise the system. And on vehicles with cats, bumping them can damage the cat.
| mattyfattyboo... |
 mattyfattyboo... Scooby Slapper
| Nobby the Bastard |
| hedgehugger |
 hedgehugger World Chat Champion
 Posted: 15:46 - 21 Jun 2014 Post subject: |
Nobody surprised at heated grips? in this weather!
I guess it can get a little chilly @ night/early morning. |
| talkToTheHat |
 talkToTheHat World Chat Champion
 Posted: 11:49 - 23 Jun 2014 Post subject: |
You need to wire your heated grips so they are switched by the ignition, possibly through a relay. Yeah 20:20 hindsight, but all it takes is catching a switch when you get off the bike and flat battery next morning.
Also, use 2nd for bump start depending on the bike, it's easier.
I would recommend, however, using jump leads from a car. Conventional wisdom appears to be to keep the donor vehicle turned OFF if you are starting a delicate motorcycle.
https://www.theaa.com/motoring_advice/breakdown_advice/using-jumpleads.html
Personally, I have a car battery I keep indoors and charge every now and then. The mere threat of using it causes my motorcycle to start, but one day it will be useful. |
| map |
 map Mr Calendar
| weasley |
 weasley World Chat Champion
| iooi |
 iooi Super Spammer
| mattyfattyboo... |
 Posted: 21:40 - 23 Jun 2014 Post subject: |
I'd hope he isnt still trying and has either bumped it or got recovered  |
| talkToTheHat |
| clancy |
 clancy World Chat Champion
 Posted: 18:15 - 24 Jun 2014 Post subject: |
It's 24 degrees, what are you using heated grips for  ____________________ KLX 300r |
The last post was made 12 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
