hit a bump, bike goes to sleep...
ukzzRider
PostPosted: 22:58 - 23 Jun 2014    Post subject: hit a bump, bike goes to sleep... Reply with quote
hi guys, back again with more problems Evil or Very Mad
If I hit a bump on my moped (50cc sym jet 50 basix 2 stroke) the bike will die, like fuel starvation. but if I turn it off & back on it's fine Confused
It's not a major problem, just something that is really annoying!
I'm just waiting for it to do it again, but not fix it's self once restarted, like a ticking time bomb.
I've already tried cleaning the carb & it's spotless! Spark plug is fine.
And the petrol tank is full!
I'm out of idea's.
Any help would be great.
SmileSmile
Dave M
PostPosted: 23:00 - 23 Jun 2014    Post subject: Reply with quote
Sounds more like electrical. Battery connections nice and tight?
grr666
PostPosted: 23:43 - 23 Jun 2014    Post subject: Reply with quote
I'd say check your earth connection.
ukzzRider
PostPosted: 02:18 - 24 Jun 2014    Post subject: Reply with quote
yes the battery is tight, I've had a look at the rest of the wiring too, can't see anything that looks remotely loose...
SmileSmile
PostPosted: 08:10 - 24 Jun 2014    Post subject: Reply with quote
I'd go with electrical. I had similar symptoms when I fitted an aftermarket CDI that I mounted in exactly the right place to be pressed by the seat. Hit a bump, seat pressed on connector, engine cuts out. Get off the bike, everything runs fine. Did my nut in trying to figure it out. Brick Wall
blueglue
PostPosted: 10:34 - 24 Jun 2014    Post subject: Reply with quote
does the stand have a cut out switch. I was just thinking going over bumps may cause the stand to flap about causing a cut out?
Sorry im new to biking myself if thats a dumb reply.
ukzzRider
PostPosted: 11:08 - 24 Jun 2014    Post subject: Reply with quote
on the carb, ive got 2 wire, ones a slide over clip, the other just clamps onto a ball connector, if that makes ANY sense. I could it be any of those? like a bad connection?
& I don't have a cut out switch in the stand, the bike doesn't literally cut out. the power just dies, so long as I don't rev the engine, it will still run. I have to restart the bike to go anywhere on it.
SmileSmile
Timmeh
PostPosted: 12:32 - 25 Jun 2014    Post subject: Reply with quote
I believe I am right in saying that your bike has an auto-choke, which is a solenoid running to the carb. That's the 2 wires you'll see.
It is possible that something is shorting, causing the choke to open and bog the engine down.
Can you disconnect said cable from the loom? It may be hard to start when cold, that's the only issue.
The last post was made 12 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 56.41 Kb
