34mm Carb on a 2003 RS125 (aprilia)
Dan_RS
PostPosted: 11:19 - 13 Jan 2005    Post subject: 34mm Carb on a 2003 RS125 (aprilia) Reply with quote
Im looking at 34mm Dellorto Flatside carbs on ebay and was just wondering if anyone has fitted one onto a 03/04 rs125, if so can you tell me what power difference i should expect, if it makes the bike harder to start and whether they're worth the money (usually around £60)
cheers
Dan
PostPosted: 11:48 - 13 Jan 2005    Post subject: Reply with quote
They should make quite a noticeable difference. The old AF1 went up about 20% in power when they switched to the 34mm carb. Down side is a heavier throttle.
If set up properly then they should be fine for starting. One thing I find is that if you brake very hard to a standstill they do seem to be marginally more likely to stall.
Dan_RS
PostPosted: 15:31 - 13 Jan 2005    Post subject: Reply with quote
Cheers for your help mate as soon as i get it i'll get it set-up to run with the pipe im using
Rift.
PostPosted: 17:59 - 13 Jan 2005    Post subject: Reply with quote
waaaawaaaaweeeewaaaa Thumbs Up Thumbs Up
You only live once so get a bike and ride
The last post was made 21 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 39.03 Kb
