Bandit 600
SQL
PostPosted: 08:37 - 27 Jun 2014    Post subject: Bandit 600 Reply with quote
Right going to look at a Bandit 600 1998 Model tonight,
What things to look out for specifically on a Bandit of this vintage with 21k on the clock?
hazza
PostPosted: 11:32 - 27 Jun 2014    Post subject: Reply with quote
Collector boxes are prone to rotting on Bandits. Suzuki's of the 90's seem to be built better than the new ones today to be fair though, at least compared to my SV. Just check the normal stuff like pads, chain, fork seals etc and on the test drive that the clutch doesn't slip or any strange engine noises. Use the condition of the chain/sprockets and tyres to barter on price. They are a top end noisy engine being air/oil cooled but just use your judgment in what is normal and isn't. Most will have been ragged all their life and probably will have a few tacky street-fighter extra's but they are generally bullet proof engines and doing the valve clearances on these is about as easy as it gets on a big bike.
mudcow007
PostPosted: 12:42 - 27 Jun 2014    Post subject: Reply with quote
aye 2nd whats alredy been said, also check for rust in around the frame, mines a wee bit scabby
i think* the engine sits in a cradle - this is generally where all the rot seems to be (so im told)
expect tat by the bucket load to have been stuck on
Bezzer
PostPosted: 12:56 - 27 Jun 2014    Post subject: Reply with quote
The main frame itself is not a particular problem it's the removeable cross member piece that bolts across at the front and joins the two front downtubes behind the headers that rots out pretty quick if not kept on top of.
PostPosted: 15:27 - 27 Jun 2014    Post subject: Reply with quote
Check the oil cooler where the pipes bolt up for oil mist or cracks/lumps out of the alloy. Corrosion on the oil drain tubes on the front of the engine and on the rocker cover molts especially the front one middle left. Exhaust collector rots out and the brakes seize.
The last post was made 11 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 44.38 Kb
