YBR125 Speedo not working - Not the cable
Stobo91
PostPosted: 09:09 - 26 Jun 2014    Post subject: YBR125 Speedo not working - Not the cable Reply with quote
Hi all,
Bought my YBR125 last month knowing that the MPH dial doesn't work. (Rev counter does work)
Automatically bought a new cable before doing any diagnostics but turns out the old cable was fine. If I turn the cable by hand while its connected to the clocks then the needle does flicker so im guessing that means the part in the front wheel hub is at fault.
Just wanting to double check this is the correct part I need, and if so, is it easy enough to change?
Bike isn't easily accessible at the minute so I can't just go and have a look until the day I actually replace it.
Heres the part ive found on ebay - https://www.ebay.co.uk/itm/BRAND-NEW-SPEEDO-PICK-UP-DRIVE-GEAR-for-YAMAHA-YBR125-/330672517994?pt=UK_Motorcycle_Parts_13&hash=item4cfd9e336a
But my local parts shop have them in stock for about £11.
Cheers.
Stobo91
PostPosted: 08:14 - 27 Jun 2014    Post subject: Reply with quote
Bump
gavcarter
PostPosted: 08:38 - 27 Jun 2014    Post subject: Reply with quote
Very easy to change wheel off, swap unit, replace wheel.
I would have the old wheel out first and make sure no-one has missed the little ring when they've had the wheel off.
gavcarter
PostPosted: 08:41 - 27 Jun 2014    Post subject: Reply with quote
obviously your will be different but they look along the lines of this https://www.triumphrat.net/attachments/twins-technical-talk/96329d1379367866-do-i-need-new-speedo-drive-101_9537.jpg
It fits between the wheel and the speedo drive unit Thumbs Up
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 39.82 Kb
