Gsxr1000 k5 cutting out
el_oso
PostPosted: 07:50 - 27 Jun 2014    Post subject: Gsxr1000 k5 cutting out Reply with quote
So the gixxer keeps intermittently cutting out. Still have all lights on the dash just no bang. On the display where the trip usually is it displays 'check'. Not 100% certain on this but the red ignition light also blinks. The bike has an alarm system so that could be causing it. The side stand switch doesn't seem to work either. I'm guessing it's one of these two. Going to check for continuity on the brake switch. How do I check the alarm system? Anything I should check?
Duke 390
Car: Jeep Wrangler 4.0L
temeluchus
PostPosted: 15:27 - 27 Jun 2014    Post subject: Re: Gsxr1000 k5 cutting out Reply with quote
A pals K5 did this when his tip sensor went on the blink.
Bendy
Mrs Sensible
PostPosted: 15:30 - 27 Jun 2014    Post subject: Reply with quote
Grungy kill switch?
Conzar
PostPosted: 15:39 - 27 Jun 2014    Post subject: Re: Gsxr1000 k5 cutting out Reply with quote
This Thumbs Up
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Bendy
Mrs Sensible
PostPosted: 15:59 - 27 Jun 2014    Post subject: Reply with quote
OP - is it doing it when you're riding it, or when it is parked. You don't specify.
I too was the victim of a tilt switch, but only when the thing was moving (switch was the wrong way up, cut out at 10 degrees rather than 80 or whatever).
el_oso
PostPosted: 10:54 - 28 Jun 2014    Post subject: Reply with quote
both.
Once I was stopped at a set of traffic lights. Went to pull away and it cut out, at first I thought I just stalled it. Also when I've been riding. All times (so far) have been going in a straight line.
I checked continuity on the switch and was giving a reading ranging from 20ohms to 200ohms when closed. So far I've disconnected the switch and bridged it with a pair of mini spade crimp connectors. Went for a 50-60mile ride out last night and everything seemed fine. Going to leave this for a week and see what happens.
Duke 390
Snorty
PostPosted: 11:21 - 28 Jun 2014    Post subject: Reply with quote
CHEC can also appear when the kill switch is on or the side stand is down. May be worth checking these if the TOS isn't the cause.
The last post was made 11 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 52.82 Kb
