Should I get a Ducati 900SS
BillyJ
PostPosted: 19:33 - 26 Jun 2014    Post subject: Should I get a Ducati 900SS Reply with quote
Been offered a nice Ducati 900SS from a friend who needs more space, it has a small dent in the tank but other than that all is perfect.
It's one of the nicer old models not the disgusting newer ones.
£1000
16,000 miles
Minor problems with starter motor wiring and front wheel isn't perfectly straight but it has passed MOT and been driven a lot like that so obviously is not a big issue.
What do you guys think?
I would have quite a few months to do it up before riding it.
EDIT:
pic:
https://i844.photobucket.com/albums/ab5/billyjeans1/ducatii_zps3345add0.png
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
Matt B
PostPosted: 19:47 - 26 Jun 2014    Post subject: Reply with quote
For a grand I'd buy it and throw it round a few track days.
They are Marmite bikes - you are going to love it or hate it.
Islander
PostPosted: 20:10 - 26 Jun 2014    Post subject: Reply with quote
For that price I'd buy it. Fun bike. Thumbs Up
PostPosted: 21:10 - 26 Jun 2014    Post subject: Re: Should I get a Ducati 900SS Reply with quote
BillyJ wrote:
Been offered [an Italian bike] Minor problems with [electrics]
Thinking
Eh, have it, you're not going to lose money on it.
sickpup
Old Timer
PostPosted: 15:14 - 27 Jun 2014    Post subject: Reply with quote
I f you don't want it I'll have it.
Looks like between 92-96 model year probably at the earlier end of the scale.
69.9mph
PostPosted: 16:27 - 27 Jun 2014    Post subject: Reply with quote
For that price you can't really go wrong. Get it bought (only if you like it though).
Ed Case
PostPosted: 17:49 - 27 Jun 2014    Post subject: Reply with quote
Terrific bikes but can be great wallet-emptyers, they need to be carefully looked after and you'll probably find that there's always 'A -job-to-be-done'. They are nowhere near as 'bullet-proof' as Jap stuff. A Grand is a ridiculously low price though, I'd buy it
ps In my time I've owned a Bianchi 175, two Ducati 250's, and three Laverdas, Oh and I'm also skint !.
instigator
PostPosted: 18:51 - 27 Jun 2014    Post subject: Re: Should I get a Ducati 900SS Reply with quote
Sick
BillyJ
PostPosted: 20:12 - 27 Jun 2014    Post subject: Reply with quote
It's the 96 model and I think I'm going to get it.
Islander
PostPosted: 20:48 - 27 Jun 2014    Post subject: Reply with quote
Don't think, just do it. Thumbs Up
Do your own maintenance and they aren't any more expensive to run than any other bike.
PostPosted: 21:02 - 27 Jun 2014    Post subject: Reply with quote
Check the engine casing near the swingarm for cracks.
I'd recommend pulling the fairings off and smear dielectric grease on every connector. Strip the earth strap off and clean it.
'96 so may still be using the 2 phase system which was poor at charging the battery. Regardless what wattage it outputs I'd replace the 2 or 3 yellow wires that run from the alternator to regulator/rectifier with a thicker gauge. It is very cheap and easy to do.
Always start it with a strong battery. Weak battery as many a KTM, Aprilia and Ducati owners know leads to sprag clutch problems.
It will love being thrashed i.e Will not like city commutes or anything resembling 30mph.
MPG Smile
BTTD
PostPosted: 21:09 - 27 Jun 2014    Post subject: Reply with quote
Lovely bike, but not sure I'd agree with you on the maintenance. Don't they need regular and complicated valve adjustments that are a total ball ache?
Actually, maybe you're right. Consumable parts probably no worse than most.
Islander
PostPosted: 21:23 - 27 Jun 2014    Post subject: Reply with quote
Desmos aren't that much harder than normal valve systems. In fact, there's no heavy spring to deal with. They just have an opening rocker and closing rocker with a shim for each. Plenty of online guides.
Belts are a doddle - the hardest part is getting the covers off.
PostPosted: 21:27 - 27 Jun 2014    Post subject: Reply with quote
Proper belts are inexpensive and the valves rarely need adjusting.
Cheaper than many Japanese 4 valve motors.
BillyJ
PostPosted: 22:40 - 27 Jun 2014    Post subject: Reply with quote
Thanks so much for the advice guys Thumbs Up I'm going to drag it out his garage on Sunday and have a look, we've agreed on £700 and £300 worth of work as I'm free until September.
He said the worst thing about it was a leak that led to oil in the piston on one of them and was fine as long as it was driven regularly but if left for months the bike would start and die after a minute if not ridden, he said it might need the piston to be overhauled but I have until May to get it roadworthy!
TUG
PostPosted: 00:05 - 28 Jun 2014    Post subject: Re: Should I get a Ducati 900SS Reply with quote
instigator wrote:
Sick
He has a point, the newer ones are just awful.
Haz ER-5, innit!
Fowlersrs
PostPosted: 08:19 - 28 Jun 2014    Post subject: Reply with quote
Oil on the piston, sounds shagged to me. That or you've got plenty of work ahead. Alright if your after a project for the money I'd guess!
MaybeGuy
PostPosted: 08:24 - 28 Jun 2014    Post subject: Reply with quote
Hardly.
Ducatis are generally easy to work on compared to jap stuff, esp on a 2 valve twin.
Robby
Dirty Old Man
PostPosted: 13:42 - 28 Jun 2014    Post subject: Reply with quote
It looks nice. They're fairly simple mechanically- lots of bits, some of them small, but still simple. If you have the time to fix it up, do it.
Do however bear in mind that most of your riding is on 30/40 limit roads in London, some of which have terrible surfaces. This would not be a comfortable bike for your commute.
For the money you could buy it, fix it up, get a fresh MOT and sell it on at a profit.
RhynoCZ
PostPosted: 14:19 - 28 Jun 2014    Post subject: Reply with quote
I'd get one if I could. Thumbs Up
The last post was made 12 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 114.08 Kb
