Drill bits
CyrilSwan
PostPosted: 13:44 - 28 Jun 2014    Post subject: Drill bits Reply with quote
I need to replace the drill bits I currently have.
Mainly used for masonry work around the house but would like to have the best bits for the job (or close to if too expensive).
I've seen that cobalt drill bits seem to be the best but these are for metal. Would they work on masonry/wood?
Can anyone recommend a good set that would last (don't want cheap bits that break or don't cut through the material very well).
EDIT: Been looking at these:
https://www.toolstation.com/shop/Power+Tool+Accessories/Cobalt+Drill+Bits/Cobalt+Pro+Drill+Bit+Set+19+Piece/d80/sd1230/p94153
or
https://www.its.co.uk/pd/300025-19-Piece-Cobalt-Drill-Bit-Set-_ULT300025.htm
Not sure on the brands though and if the last is too cheap?
Current: Honda 2015 MSX125.
Previous: Honda 2012 CBF125.
PostPosted: 14:07 - 28 Jun 2014    Post subject: Reply with quote
those are metal drilling bits. They'll drill timber but will bind if it's too thick. Don't try drilling masonry with them you'll wreck them instantly beyond even re-sharpening. Masonry bits are a completely different material and design.
CyrilSwan
PostPosted: 14:15 - 28 Jun 2014    Post subject: Reply with quote
Knew that (masonry) but wasn't sure on using cobalt on other materials so thanks.
Any sets you can recommend that have a bit of each (metal, masonry, wood) or individual sets?
Nexus Icon
PostPosted: 14:21 - 28 Jun 2014    Post subject: Reply with quote
Go for tungsten carbide tipped drills for masonry but don't buy cheap ones or the tips will just fall out.
Greetings from Shitsville!
PostPosted: 14:39 - 28 Jun 2014    Post subject: Reply with quote
I never bought a set. Buy the best you can afford, that doesn't necessarily mean the most expensive you can find.
For masonry I'd be tempted to buy used good SDS bits off eBay or gumtree. Something like https://r.ebay.com/7r5wad
Sload
PostPosted: 15:29 - 28 Jun 2014    Post subject: Reply with quote
I tend to use Bosch SDS bits for drilling concrete floors, they hold up well as long as you try not to drill through the steel re-enforcement.
You could try these https://www.screwfix.com/p/bosch-sds-hammer-drill-bit-set-brute-tough-box-8pcs/92406
Or these https://www.screwfix.com/p/dewalt-extreme-2-sds-plus-masonry-drill-set-4-pc/44568
Remember though, drill bits are consumables so dont get hung up on them lasting.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
pdg
PostPosted: 10:11 - 29 Jun 2014    Post subject: Reply with quote
https://www.screwfix.com/c/tools/multi-material-drill-bits/cat5920044
Steel, wood, masonry, uPVC, ceramics and concrete multi-layered materials.
Have fun.
It's all well and good saying how brilliant SDS bits are, but if you don't have an SDS drill you might as well use a pencil.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
jimjam93
PostPosted: 10:38 - 29 Jun 2014    Post subject: Reply with quote
I've not replaced all of mine to Dewalt Extreme 2 drill bits, they chew through near enough anything and make it look easy!
Costly but very much worth it!
They do them for all applications you'll need it for Smile
Only thing metal nose it failed on was a screw extractor bolt that had snapped.. but then that's seriously hardened anyway! Otherwise anything else it has torn through for me in a home environment
PostPosted: 11:35 - 29 Jun 2014    Post subject: Reply with quote
Have fun.
Or just put them in a 13mm chuck.
The last post was made 11 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 64.27 Kb
