kmx125 wont start
scottc1088
PostPosted: 22:05 - 13 Jan 2005    Post subject: kmx125 wont start Reply with quote
my kmx 125 wont start, iv just got it off a mate cheap, it has a good spark and very good compression!
but when he had it he set the carb on fire but put it out stright away but the fuel pipes were no good! can someone tell me where the pipes go
also i think fuel is coming out of the overflow(so im told), could this be why its not starting
hope you understand
thanks
2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
Breaking 2000 senda r
PostPosted: 22:31 - 13 Jan 2005    Post subject: Reply with quote
If fuel is coming out of the overflow either the float is sticking (try gently tapping the side of the carb and see if the fuel flow stops), float height is too high or there is damage to / something in the needle valve.
In your case, it is also possible that the fire could have damaged the folats which are most likley made of plastic.
scottc1088
PostPosted: 22:33 - 13 Jan 2005    Post subject: Reply with quote
ill try and check tomorrow to see if fuel is coming out but shouldnt it still run anyway?
my m8 had put a pipe from the overflow to somewhere else on the side of the carb Question
scottc1088
PostPosted: 23:12 - 14 Jan 2005    Post subject: Reply with quote
anyone else got any ideas??
Frost
PostPosted: 01:05 - 15 Jan 2005    Post subject: Reply with quote
Well worst case scenario... look on ebay and see if you can find yourself a KMX carb. shouldnt cost more than £20.
scottc1088
PostPosted: 08:05 - 15 Jan 2005    Post subject: Reply with quote
thats what i was thinkin, ill have a mess around with it 1st tho
if theres spark and compression then its got 2 be the carb right??
RascalsCustar...
PostPosted: 23:23 - 15 Jan 2005    Post subject: Reply with quote
Blimey. Must be your lucky day. I've got one of those (carb) stripped out on my kitchen table...and another one on another of my other kmx's which'll be i'll be striping tomorrow. Buggered float needle I reckon. Wink
Can take a few pics if it's any help so you know what you're doing with yours, if you decide to strip it?
None of the hoses attached to the carb should go back into it. They should all be exposed to the atmosphere.
Saying that those carbs seem to suffer badly from getting clogged main jets. The one above that I pulled out a kmx that's been standing for months, was caked in gunk.
scottc1088
PostPosted: 23:29 - 15 Jan 2005    Post subject: Reply with quote
i stripped it down n cleaned it out earlier 2day
and the casing on the side that says kips on it was leaking fuel????
so i ad a look n there was only half of a gasket so i made one outta card, didnt bother kicking it up just tryed bumping it n it blew loads of petrol, oil n other shit out of the exhasut then started Embarassed (it starts wiv the kick now tho)
the throttle cables melted n it doesnt return to idle it jus stays where you pulled it to even if you push it back but iv just ordered one of these
thanks for youl help
scottc1088
PostPosted: 23:36 - 15 Jan 2005    Post subject: Reply with quote
also is the throttle cable the complete kit which splits into 2 for the oil pump or is it 2 seperate ones?
RascalsCustar...
PostPosted: 23:45 - 15 Jan 2005    Post subject: Reply with quote
No worries matey. I got 2 of the bloody things.
RascalsCustar...
PostPosted: 23:47 - 15 Jan 2005    Post subject: Reply with quote
Should be 1 cable with a little plastic bit where it splits into 2 cables. As you said, one for the carb, the other for the oil pump.
Make sure you get the freeplay adjustment right for the oil pump though eh...
scottc1088
PostPosted: 23:50 - 15 Jan 2005    Post subject: Reply with quote
ok cheers, shud b ready tuesday
The last post was made 21 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 73.86 Kb
