ZZR600D rough running issues
sgtcalle
PostPosted: 16:25 - 01 Jul 2014    Post subject: ZZR600D rough running issues Reply with quote
Hi all, I have a '90 plate 600D. I'm currently having running problems as follows:
At low RPM in first and second gear (generally when revving from idle - i.e. pulling away from lights etc) the bike loses power and bogs down. This only happens once the bike is hot, the first 5 minutes of riding is fine. At higher revs, or just cruising, the bike performs fine.
I first noticed the problem a few weeks ago, and its been getting progressively worse. The bike is used for a short 15 minute commute, so I have read there may be condensation forming in the float bowls. I have taken it out for a couple of longer 40-50 mile runs, which hasn't made an improvement (made it worse if anything).
Its just been in the garage for an MOT, and i asked them to take a look/give me their opinion on the running problem. Very occasionally, after turning the ignition nothing happens which suggests to me a dodgy connection. However i stress this happens very occasionally, and hasn't been getting any worse. The garage suggested that this could be the cause of the rough running, but i dont see how this can be the case? They also suggested that the clutch plates could do with being replaced. They're probably right, but i doubt this is related to the rough running, as with the bike in neutral and the clutch disengaged, the bike still bogs when revved from idle. Am i correct in my thinking here?
Thanks for any help.
CBR600F '02
Manchester
temeluchus
PostPosted: 16:46 - 01 Jul 2014    Post subject: Reply with quote
The ignition thing is likely to be seperate.
What you are describing is rich running. I'd suggest inspecting and replacing the float needles as first port of call. They are a prime cause of grief in older bikes.
sgtcalle
PostPosted: 17:15 - 01 Jul 2014    Post subject: Reply with quote
Ok thanks. How difficult a job is this? Thanks
CBR600F '02
Manchester
temeluchus
PostPosted: 17:21 - 01 Jul 2014    Post subject: Reply with quote
not hard. Tank off, airbox off, drain carbs and pop em off. Take the float bowls off, remove the floats and the needles. Carefully inspect the tips. Look for a circular ridge worn into the tip.
They might be the rubber tipped jobbers but again look for wear. I would suggest replacing them all as a matter of course.
Get some carb cleaner and give it all a blast anyhow, whilst its apart.
sgtcalle
PostPosted: 14:21 - 10 Jul 2014    Post subject: Reply with quote
I took the bike into the garage as i didn't have time to do it myself, they inspected the carbs, balanced them and cleaned them. Apparently the float needles were in good shape, and the carbs generally not too bad. I also replaced the air filter. The bike is still running like a dog however.
I cant afford to pay mechanics to do anymore, they suggested the next place to look is the plug caps, as apparently they are in pretty poor shape. Does anyone have an opinion on this? Is it likely to cause the symptoms listed? Also, slightly silly question, but when installing spark plug caps, you just press them onto the plugs untill they lock do you not?
Thanks.
CBR600F '02
Manchester
gavcarter
PostPosted: 15:56 - 10 Jul 2014    Post subject: Reply with quote
Thanks.
Yes just pop them down onto the plugs. 4 new caps should sting you less than a tenner, get a pair of wire snips and trim about 1cm off the end of the old cable before screwing the new caps on.
Just press down onto the spark plug until they click, give a little tug to check they are on.
Personally I would fit new plugs too you would be looking at £30 for caps and plugs Thumbs Up
jjdugen
PostPosted: 16:50 - 10 Jul 2014    Post subject: Reply with quote
Just throwing this into the mix. Check your chokes are returning fully. These engines are really touchy if even one of the chokes is not fully home once the engine warms up a bit. The slider bar that operates the chokes can get clagged up as can the choke pistons. I spent a day trying to find that one on mine, same symptoms as you describe.
cheers.
andys675
PostPosted: 18:06 - 10 Jul 2014    Post subject: Reply with quote
did they have a look at the carb diaphragms?
sgtcalle
PostPosted: 09:00 - 11 Jul 2014    Post subject: Reply with quote
Ok thanks lads, somewhere to start i suppose! I assume the garage looked at the diaphragms, nothing specific was mentioned though. I seem to remember a thread on here where a split diaphragm was causing issues?
Also, are there standard spark plug caps i can buy? Searching for ZZR6 plug caps doesnt seem to yield many results
CBR600F '02
Manchester
The last post was made 12 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 61.68 Kb
