Removal of a seized tank cap
nowhere.elysium
The Pork Lord
PostPosted: 19:32 - 01 Jul 2014    Post subject: Removal of a seized tank cap Reply with quote
My wife's CBF125 has managed to seize up its tank cap. I'm not sure how, but no matter what I do, I can't get it to unlock.
I've tried penetrating oil, shock and unlock, physical shocks, and general gentle persuasion so far, to no avail.
Does anyone have any suggestions? I'm a little reticent to drill it out, because swarf in the tank isn't much fun by any measure. Am I stuck with hammering a screwdriver in until the lock gives out?
PostPosted: 19:38 - 01 Jul 2014    Post subject: Reply with quote
Whilst heat is out, how about a bag of ice on it? Might cause enough of a part of the lock to contract and free up whatever is seizing it.
Formerly known as
P.
PostPosted: 19:39 - 01 Jul 2014    Post subject: Reply with quote
My SV one was REALLY stuck, I used that compressed air but upside down. Got it really cold, few hits with a rubber mallet then out it popped. Lubricated all the little bits whilst turning the key, the little catch etc, now it works fine Thumbs Up
PostPosted: 19:48 - 01 Jul 2014    Post subject: Reply with quote
I've recovered a lock by packing it with grease. Whether it was lubrication or viscous coupling moving the pins, I know not, but it worked.
gavcarter
PostPosted: 22:03 - 01 Jul 2014    Post subject: Reply with quote
Try the spare key Wink Or cake the original key in the thickest grease you have
SQL
PostPosted: 23:18 - 01 Jul 2014    Post subject: Reply with quote
Does the key turn? but not unlock.
nowhere.elysium
The Pork Lord
PostPosted: 06:40 - 02 Jul 2014    Post subject: Reply with quote
I'll try grease, but I'm not hopeful. The key doesn't turn, so my thinking is that the pins have seized.
davebike
PostPosted: 07:26 - 02 Jul 2014    Post subject: Reply with quote
I had a few " been standing " bikes in with this problem
most if you have time free of with lot ao soaking with good penetrating oil over several days
Pressing the cap down HARD whilst trying to turn the key helps as it removers load from the lock
If no luck the lock will drill out and you have to get another cap / key
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Formerly known as
P.
PostPosted: 07:43 - 02 Jul 2014    Post subject: Reply with quote
The SV cap hadn't been opened in a long time so was a bitch to do but I'd definitely give it the cold treatment Thumbs Up
EazyDuz
PostPosted: 09:08 - 02 Jul 2014    Post subject: Reply with quote
A long spray of penetrating oil got a dodgey cap off in the past.
nowhere.elysium
The Pork Lord
PostPosted: 09:48 - 02 Jul 2014    Post subject: Reply with quote
Feel free to actually read the first post, next time.
Suntan Sid
PostPosted: 10:14 - 02 Jul 2014    Post subject: Reply with quote
If you can replace it cheaply, jam a flat blade screwdriver in it and turn, buy new cap!
Both my CBR 600 and YPVS came to me like that, any key or blade would open the cap.
nowhere.elysium
The Pork Lord
PostPosted: 14:48 - 02 Jul 2014    Post subject: Reply with quote
Weirdly enough, I tried it with the key once more, and it opened. It then seized again. Go figure.
Good thing I replaced the entire lockset today, then.
The last post was made 11 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 78.04 Kb
