RXS wont start
Marc_Buck
PostPosted: 19:43 - 13 Jan 2005    Post subject: RXS wont start Reply with quote
Right before we start, i havn't upjetted it, like i was going to.
OK, went to start bike, and it wont start, it back fires every 3rd ish kick and every now and then starts, rev up to 2k revs on its own the dies. Shocked Anyone know the problem? petrol tank is full and has oil.
94 fzr600r
PostPosted: 19:53 - 13 Jan 2005    Post subject: Reply with quote
Is it points ignition? Sounds like the timing has slipped. Check the marks line up properly. If it is a CDI ignition, ignore this.
Marc_Buck
PostPosted: 20:21 - 13 Jan 2005    Post subject: Reply with quote
Sorry mate i didn't understand a word of that.
94 fzr600r
PostPosted: 21:51 - 13 Jan 2005    Post subject: Reply with quote
Hmmm, difficult to describe, easy to point to. Under the left hand engine cover you will find the flywheel for the alternator (which generates the electricity). If it is a points ignition, there will be a set of points mounted somewhere in the middle of the flywheel.
It would take ages to describe how to check your static timing in laymans talk if it is a points ignition but it is not difficult. There are good pictures in a workshop manual.
Points look like this, the brown plastic bit presses against the cam on the bolt in the middle of the flywheel (which turns round with the engine):
https://www.kmproducts.co.uk/images/Rotax-ignition-points.jpg
DM
PostPosted: 00:32 - 14 Jan 2005    Post subject: Reply with quote
Or you can tell us what year it is Smile. I think anything post 1990 or around then has a CDI ignition.
Anyhow, tell us a bit more info, like: Has it been sitting for awhile? Did you have any trouble the last time it ran? It could really be any of a wide array of problems, so the more information the better.
Most likely it's just a case of blockage in your carburator, though.
Marc_Buck
PostPosted: 00:35 - 14 Jan 2005    Post subject: Reply with quote
It's an 89 last time i ran it was fine.
94 fzr600r
DM
PostPosted: 07:08 - 14 Jan 2005    Post subject: Reply with quote
Well, the first thing I'd do is strip and clean the carburator. Just gotta make sure everything is nice and tight when reassembled Smile.
The last post was made 21 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 50.2 Kb
