Weak brakes
Ottocle
PostPosted: 18:37 - 07 Jul 2014    Post subject: Weak brakes Reply with quote
I took my brake calipers off to give my bike a good clean. Upon replacing them, the brakes have become a lot weaker. Will they correct themselves after a little riding or do I need to bleed the brakes (fingers are crossed it's not the latter)?
PostPosted: 18:39 - 07 Jul 2014    Post subject: Reply with quote
If you removed the pads did each pad go back where it came from?
Andy_Pagin
PostPosted: 19:51 - 07 Jul 2014    Post subject: Reply with quote
I'm assuming you didn't disconnect the hydraulics.
Did you put each pad back exactly where it came from?
Ottocle
PostPosted: 20:02 - 07 Jul 2014    Post subject: Reply with quote
Had to use a clamp to push front brake pistons in but lost no fluid and put brakes back just as they were.
PostPosted: 21:42 - 07 Jul 2014    Post subject: Reply with quote
Pull the lever in as hard as possible and cable tie.
Leave it overnight and see if that helps.
Val
PostPosted: 20:33 - 10 Jul 2014    Post subject: brakes Reply with quote
you have not used jet wash on the calipers do you?
I hope is something simple try to pump your brake handle
Nobby the Bastard
Harley Gaydar
PostPosted: 21:46 - 10 Jul 2014    Post subject: Re: brakes Reply with quote
Wot he said.
Triumph Sprint ST 1050
iooi
PostPosted: 05:35 - 11 Jul 2014    Post subject: Reply with quote
What did you use to clean the calipers, disks & pads......
ws4936
PostPosted: 08:12 - 11 Jul 2014    Post subject: Reply with quote
......then you need to pump the piston back out by the method valko mentioned.
If everything seems under control, you're just not going fast enough.
Slacker24seve...
PostPosted: 12:56 - 11 Jul 2014    Post subject: Reply with quote
Butter?
Banger rallies are ace
Val
PostPosted: 13:50 - 11 Jul 2014    Post subject: Re: brakes Reply with quote
Wot he said.
You can damage piston seals with jet wash hope that is not the case
Val
PostPosted: 13:56 - 11 Jul 2014    Post subject: Reply with quote
Slacker24seven wrote:
Butter?
that and milk
The last post was made 12 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 74.09 Kb
