Idle Speed Questions
loply
PostPosted: 17:04 - 14 Jan 2005    Post subject: Idle Speed Questions Reply with quote
Hi folks, strange subject I know, but none of the books Ive ever read really discussed it.
What effect does putting the idle speed above normal have?
Does it change how the engine takes up slack in the drivechain etc when cornering in first gear?
How would it feel different when cornering with no throttle, if you had a really high idle speed (ie 3000 or so)? I guess it would unload the front more?
Does the way the carb works mean that increasing idle speed changes the fuel:air ratio at all?
Also, race engines idle at speeds like 6,000 right? Does this not wear the engine heavily when its cold?
Just something thats kinda been on my mind all day Confused
Yamaha SZR660 Caution to the wind, the throttle pinned!
cunni
PostPosted: 19:01 - 14 Jan 2005    Post subject: Reply with quote
You might suffer from loss of engine breaking if you do this?!
All I know about this one is: I need to tune my TL1000R, as I stuck various performance parts in and now it ticks over at 3000rpm. Sounds absolutly mental, but I know it'll feck it up, so it's still off the road!
I wouldn'tmess with idle times unless your going from summer to winter riding or vice versa!
TL1000R Parts For Sale!
loply
PostPosted: 19:17 - 14 Jan 2005    Post subject: Reply with quote
Why are summer and winter riding idles different like? Just higher for winter?
cunni
PostPosted: 19:32 - 14 Jan 2005    Post subject: Reply with quote
This might not be true any more, but on older car's I've owned it was. Newer (digitally injected) bikes probably don't need changing, butolder ones with carbs could probably do with the idle time adjusting to a greater tickover for winter. Not too much mind, you don't want it revving like stink!
Oh year, You olny really need to adjust the idle time if you notice it nearly cutting out at stand still or if it revv's too fast.
8316
PostPosted: 23:03 - 14 Jan 2005    Post subject: Reply with quote
ok, i might only have a little 125, but when i was playing with my idle (very,very easy) i could lose a noticable amount of engine braking when going into corners
well, thats my experience. means i went flying to corners.... Rolling Eyes
Now own a Fireblade!! Speed Limits? Bah!
Dom_
Points Mean Prizes
PostPosted: 00:08 - 15 Jan 2005    Post subject: Reply with quote
I noticed my engine was idling super low this winter, about 1k, just stuttering ready to cut out. It needs adjusting but i can't be arsed.
PostPosted: 02:01 - 15 Jan 2005    Post subject: Reply with quote
If it is set too high, the bike will keep runnng on when you close the throttle to slow down. It will also be a lot more likley to overheat when you stop.
If it is too low, the bike will keep stalling when you stop.
Set it according to the book or adjust the idle down to where the engine starts to stutter then back up a wee bit from there so it maintains a steady tickover without offering to cut out.
DM
PostPosted: 08:24 - 15 Jan 2005    Post subject: Reply with quote
1,500 - 1,800 rpm is a good range for most conditions.
stryker
PostPosted: 11:45 - 15 Jan 2005    Post subject: Reply with quote
Agreed, my FZR idles around 1250 - 1500 depending on air temp and humidity.
Now what?
cunni
PostPosted: 23:39 - 16 Jan 2005    Post subject: Reply with quote
bloody hell, my TL idles below 1000rpm, around 900 usually, except for the recent mods, I still need to get it back down from 3000! Confused
AD
PostPosted: 23:48 - 16 Jan 2005    Post subject: Reply with quote
My SV650s idles at about 1000rpm too, may be a twin thing Question or maybe talking rubbish.
It was like that before i got here!
Frost
PostPosted: 00:58 - 17 Jan 2005    Post subject: Reply with quote
Typicaly the tickover should be proportional to what a bike revs to.
something with a huge etuned engine that only rev's up to 6k, would only need a tickover of about 800rpm. where as so shit hot screaming race bike needs a much higher tickover.
My bike ticks over at just under 3k. very high i know, need to do something about that! Laughing
dodsi
Dirty Carny
PostPosted: 01:12 - 17 Jan 2005    Post subject: Reply with quote
ER-5 idles at 1K
PostPosted: 01:23 - 17 Jan 2005    Post subject: Reply with quote
It is more to do with the length of the stroke, a long stroke bike will tickover at a slower rev speed although the piston velocity is probably similar.
If you ever get the oppertunity to listen to an old slope-engined Panther 650 single (a mans bike!) which has a hugely long stroke, you can hear the individual detonations. Compare this to my modern 660 single which has a comparativley short stroke and ticks over at around 1000rpm (same engine as yours loply), a 650 twin will tickover higher still and a four even higher. The piston is moving at the same speed but takes longer to cover the distance involved in an engine revolution.
At least, that is my understanding of it.
Jrod
Page 3 Girl
PostPosted: 02:04 - 17 Jan 2005    Post subject: Reply with quote
I could of really done with this when I first joined this forum, my first question was about idle revs and no one replied! Razz Guess thats what happens when you post in the workshop section. Wink
PostPosted: 11:45 - 17 Jan 2005    Post subject: Reply with quote
Think it is more to do with the weight of the flywheel needed to stop a long stroke engine stalling. Most cars have heavy flywheels and idle at low revs, and I suspect that most V twins have hefty flywheels to stop them shaking to pieces and to provide the crank with enough momentum to turn over for the next combustion cycle.
The last post was made 21 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 89.92 Kb
